97 TJ Alternator Replacement Amperage - JeepForum.com
post #1 of 4 Old 07-13-2010, 01:50 PM Thread Starter
rocketag98
I have a 97 4-cyl TJ that I recently resurrected from the dead (it has been garaged and not started for two years). Now that I have it running, I am running down my list of parts to replace and thought I'd go ahead and take care of the alternator since it was already showing signs of failing before the Jeep got garaged. I went on one website for alternators and after navigating to my year, make, and model, it gave me three options for alternators: 75, 90, or 160 amps. I believe, from what I've been able to find on the internet, that the stock alternator is somewhere around 100 amps (can't get a straight answer on that one). Since I ultimately plan on putting in a winch and additional lights, should I just go ahead and get a 160 amp alternator now to be prepared for when I make those additions? Is there anything special I should consider when getting such a high amperage alternator prior to having the equipment to utilize that extra amperage?
rocketag98 is offline
post #2 of 4 Old 07-13-2010, 01:52 PM
mschviuz
Sounds like you just need to start making a list of the goodies to put on the jeep!
mschviuz is offline
post #3 of 4 Old 07-15-2010, 03:11 PM Thread Starter
rocketag98
So then I take it that if I go from a 90 amp alternator to a 160 amp alternator, that is not a problem??? Oh yeah, I have my goody list all lined up...
post #4 of 4 Old 07-15-2010, 03:32 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
The basic alternator size is 84 amps with the upgraded alternator for a non-stripped down Jeep being 117 amps.
Jerry Bransford is offline
tj , wrangler , 2.5 , alternator , amp , amperage , replacement , replacing
'98 TJ alternator replacement suggestions? CdnEh TJ Wrangler Technical Forum 10 06-24-2009 02:00 PM
Arb lockers and amperage. OBA and amperage. jeepster93 YJ Wrangler Technical Forum 1 02-29-2008 03:23 PM
High Amperage Alternator ScotZ YJ Wrangler Technical Forum 18 05-15-2006 09:36 PM
More amperage? PlanetDac YJ Wrangler Technical Forum 7 05-22-2005 06:04 PM
Switch Amperage?? skotsour YJ Wrangler Technical Forum 3 03-12-2004 12:05 PM
