#1 | |
97 TJ all over the highway, help
Hey guys i have a 97 TJ, with 120k miles.
The Jeep seems to sway back and forth all over the high way, it tracks from lane to lane. I seem to have to make minor, like 1/2 inch corrections in the wheel the entire time its on the highway to keep the jeep straight. Its kinda scary driving above 60, having to move the wheel, left, right, left, right, just to track forward. It does not seem to do it that bad in town, below is what i've replaced so far with no change in handling. Jeep has a 3 inch lift, that came on it when i bought it, and stock tires. 4cyl engine. There is no radel, does not feel like a wobble, just sways back and forth? New Drag Link New Track Bar New Tie Rod Complete new set of Tie rod ends, inner and outer New upper and lower front ball joints New front axle u- joints to front wheels. New Steering stabilizer New Steering shafts New front hubs and bearings new rotors Fresh front end alinement Balanced tires. If i'm correct, all that could be left is sway bar links, and steering box. Everything looks tight, i had someone move the wheel, while looking under the jeep, and i don't see much play in anything, the steering wheel does have some slop, maybe 1 inch each way, where tires do not move. What else can i do, i hate to get this thing on the interstate because its so weird to drive. Thanks so much
#2 |
Something really basic but what are the tire sizes? and do you notice this on all highways where you're going more than 60mph?
I ask because because I noticed that with wider tires, they tend to get stuck in those groves (caused by a lot of heavy truck traffic) in the highway easily, kinda meets the description you had.
There is nothing worse than a brilliant image of a fuzzy concept. - Ansel Adams Bay Area JP Club |
#3 |
Tire pressure?...
#4 |
Tire pressure is good, they are ballanced just fine, new allinment. Tire size is like a stock size, something like 235/something/15. Just silent armor good years
#5 |
Try adjusting the steering box screw. That worked wonders on mine
#6 |
#7 |
What pressure?...
#8 |
well for one thing its lifted, with a higher center of gravity its hard to keep it perfectly stable since jeeps are not aerodynamic at all. with my 4" im constantly correcting at those speeds. jeeps just don't drive like any other vehicles.
#9 |
No, it will get rid of the slop - provided that the box isn't shot. Loosen the lock nut, turn the allen head screw in until it just stops (don't crank it down!), then back it off 1/8 to 1/4 turn. Hold the screw with the allen wrench and tighten the lock nut. All you are doing is compensating for the wear in the gears. If that doesn't do it then I'd look into a new box.
#10 |
justjeepin.org
Do you have the spec sheet from the alignment? If so, let us know the readings.
99 TJ 4.0 5 Speed Sport, 2.5" Rough Country Lift, 1.25 Body Lift, 1" MML, SYE and CV shaft,JKS Quicker Disconnects, 33x10.50 BFG Mud Terrains,4.56 gears, Super35 w/ Ected Locker, Warn 8274 and some other stuff. 99 TJ 4.0 Auto Sport, 2.5" Rough Country Lift, 1.25 body lift, 1" MML, 33x10.50 BFG Mud Terrains, JKS Quicker Disconnects, wife's Jeep 2011 JK Sport, Auto, Teraflex leveling Kit, 285/70-17 Kelly Safari TSR |
#11 |
I dont have the specs, after i changed all the tie rod ends, ball joints, tack bar, drank link, i took it too good year for allinment, and tire ballance. They said it was adjusted. Do you think thats the issue, and i need to take it back to good year?
#12 |
Fool Injected
Need more info. Do you have stock suspension or is it lifted, with a drop pitman arm. I have a 4" lift that had a DPA and couldn't keep the thing on the road. Took off the DPA and everything is tight, with no play and no more road wandering.
#13 |
has a 3 inch, old man emu lift that came on the jeep when i bought it.
Im allmost positive the pitman arm on the steering box is stock. |
#14 |
someone said the frame could be flexing when you turn, and i need a steering box brace? anyone head something like that?
#15 |
I would bet your caster is off. Get some adjustable upper control arms. Dial in a balance between a correct pinion angle and the necessary caster. you will be good to go. I know you said you got an alignment done, but they cannot adjust caster without adjustable CA's ( I know some guys have cam bolts but I would toss them in the trash.
Cheers, Mike |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
