'97 still giving me problems - JeepForum.com
post #1 of 17 Old 11-28-2005, 08:44 PM Thread Starter
MadDawg
I'm STILL getting codes 11 and 12 and I've had the Jeep at the Dealer 3x. They've replaced all the sensors 2x, checked the Jeep on their computer and whatever else it is that they say they do. I get an hour out of the Jeep and the codes are right back!!!!
There is NO NOISE, NO POWER LOSS, NOTHING!!!
Any ideas???? They wanna leave the Jeep there and let a Tech come in, but I'd like to have some info so they don't experiment on MY Jeep!!!
Thanks
MadDawg is offline
post #2 of 17 Old 11-28-2005, 09:07 PM
kreepykrawler
what do those codes mean?
Are you an
kreepykrawler is offline
post #3 of 17 Old 11-29-2005, 05:44 AM
BORY
TJ Wrangler
i know from shop and work that every time you clear codes from a computer it takes 45 minutes of driving at different speeds and braking and accelerating to make a new run through for the computer so i was say check all the fuses and check at the connection sfor the sensors and i dont know what else so say but GOOD LUCK!!!
BORY is offline
post #4 of 17 Old 11-29-2005, 06:14 AM
blang4d
I have a '97 TJ and have had the check engine light come on too, but not in a while. I've heard that TJs are prone to this and a lot of times, there isn't really anything wrong, other than some glitch that turns the light on. The last time this happened to me, I just disconnected/reconnected the battery. That resets the computer and should turn the light out. If there's a real problem, the light should come on again...if it's just the glitch, it should stay out.
blang4d is offline
post #5 of 17 Old 11-29-2005, 08:20 AM
J33ptj97!
J33ptj97!'s Avatar
Here's what code 11 means -
11 No crank reference signal detected during engine cranking. Intermittent loss of either camshaft or crankshaft position sensor. CKP sensor target windows have too much variation.
97 Sport on 31s, REBB, Skyjacker SS
J33ptj97! is offline
post #6 of 17 Old 11-29-2005, 11:02 AM Thread Starter
MadDawg
Both the dealer and myself have reset the computer a dozen or more times. They can't seem to find anything wrong. They replaced the crank and cam sensors along with a handful of other things they figured they could sell me while I was there!!! I've resorted to pulling the bulb from behind the cluster so I don't have to see the light. Every other day, I just cycle the codes to make sure there isn't anything new... but this is getting old FAST!!!
Anyone...??? Bueller....??? Bueller...???
MadDawg is offline
post #7 of 17 Old 11-30-2005, 05:55 AM
BORY
TJ Wrangler
it happened twice since i owned the jeep in 2 weeks and after a day of normal driving from home to skool then to work and home again the CEL goes out i was like wtf.
BORY is offline
post #8 of 17 Old 11-30-2005, 07:08 AM
htownjeep
What's that noise?
htownjeep's Avatar
From what J33 said maybe it's got a bad sensor still or some bad/crimped wiring. I know you said they replaced it but it's possible they could still be bad. Did they check the wiring pretty good?
Drink upstream from the herd.
htownjeep is offline
post #9 of 17 Old 11-30-2005, 06:49 PM
BORY
TJ Wrangler
correction 3 times now as of today
BORY is offline
post #10 of 17 Old 11-30-2005, 11:04 PM Thread Starter
MadDawg
Well, like I said, I've had it back 3 times and the guy I go to is the best in the area (referred to me by a close friend). He's been working on Jeeps for 30+ years. He keeps saying that the computer is saying everything is OK, but the darn light just keeps coming back on!!!
MadDawg is offline
post #11 of 17 Old 12-01-2005, 05:52 AM
BORY
TJ Wrangler
could u swap a computer from a 98 or 99 4.oL or something
BORY is offline
post #12 of 17 Old 12-01-2005, 07:14 AM
servozn
Here is a good link for codes:
http://www.dirtroadmagazine.com/codes.htm
As for the light coming back on, it sounds to me like you have a short somewhere between your crank sensor and computer. Since your jeep is running fine, I am presuming your crack sensor and computer are both working fine. The only problem you are having is the CEL, so that would make me believe you have a short somewhere...
electrical problems are a HUGE PITA. Good luck.
HTH
97 TJ 4.0l
I've gotta stop running into things...
servozn is offline
post #13 of 17 Old 12-01-2005, 11:20 AM Thread Starter
MadDawg
Funny, because there is an alarm installed and I can't use it, because I always said it seems like there is a voltage problem. The thing will chirp for no reason and activate even if it's on a flat surface and nothing or no one near it. Maybe, I'll reverse the install and see if that does anything!! It was there when I got the Jeep, so I'll be jumping in to this one blind!
MadDawg is offline
post #14 of 17 Old 12-01-2005, 12:16 PM
J33ptj97!
J33ptj97!'s Avatar
Dawg, funny you mention this because I had a very similar issue when I got my 97 TJ and it wouldn't pass inspection. I yanked all of the alarm wiring and cleared the codes, and then it was good to go. I think even the slightest bad wiring/grounding can cause the computer to give all sorts of unrelated errors.
post #15 of 17 Old 12-01-2005, 07:29 PM
BobboTJ
I would put money on this being a wiring issue (grounds). The other day I had the code 11. I knew the connectors on my battery cables were kind of crappy, so I replaced them, bam no more code. When you take it to the dealership tell them to start testing the sensors with a voltometer(sp?). They should have specs there that say what they should be running at. Good luck
'97 TJ Sport....I take care of her and she takes care of me
-3" Full Traction
-33" Kumho MT
-Black Steelies
-Custom Fabbed Front Bumper
-Herculined Tub
Comin soon-4.10's, 1" BL/MML, Skids
BobboTJ is offline
i am giving away a membership, RnEmOvr Wrangler General Discussion 0 10-07-2008 07:43 PM
so im giving up mtn_wrangler YJ Wrangler Technical Forum 42 09-04-2008 09:59 PM
giving the 4.2 some power? bigrobby YJ Wrangler Technical Forum 10 02-05-2008 06:45 AM
Stock Bumper is giving me problems! tastybrownies TJ Wrangler Technical Forum 4 01-05-2008 12:44 PM
Stock Bumper is giving me problems! tastybrownies TJ Wrangler Technical Forum 6 01-05-2008 10:52 AM
