97 OBD II plug - Page 2 - JeepForum.com
post #16 of 18 Old 07-28-2010, 09:43 AM Thread Starter
CuminsChris
I am happy to say I found the problem. I removed one at a time and replaced each wire in the OBD II plug. Cleaning each connector. There must have been some corrosion that I was unable to reach externally.
PROBLEM SOLVED !!!!!! Passed emissions !!!! Thanks for everyone's help Chris
CuminsChris is offline
post #17 of 18 Old 07-18-2014, 08:19 PM
cubbygirl14
Hey there CuminsChris, I'm having the same issue as you had. How did you take each wire out? Thanks in advance.
cubbygirl14 is offline
post #18 of 18 Old 07-19-2014, 10:37 AM
athos76
You can get pin removal tools online for pretty cheap. I have to replace my obd II port soon because a friend kicked it when climbing out one day.
2006 I6 6-Speed X, 33" Goodyear Duratrac, 8.8.
athos76 is offline
OBD II , error , malfunction , tj , wrangler
a/c plug (lighter plug) how to make it stronger herculz TJ Wrangler Technical Forum 8 12-10-2009 01:07 PM
Spark Plug & Oil Drain Plug Torque Specs bfewkwa TJ Wrangler Technical Forum 7 08-28-2009 06:19 PM
Where is the drain plug and fill plug on manual transmission Mr_E YJ Wrangler Technical Forum 2 07-11-2009 03:26 AM
large drain plug and fill plug stu'sjeep TJ Wrangler Technical Forum 4 04-21-2008 08:14 PM
HVAC fan inop except on High, found the wiring & plug fried... need plug. Jerry Bransford TJ Wrangler Technical Forum 18 02-21-2005 02:44 PM
