97 OBD II plug - JeepForum.com
post #1 of 18 Old 07-20-2010, 12:31 PM Thread Starter
CuminsChris
97 OBD II plug
This has been driving me crazy! I own a 1997 TJ, 4cyl. manual Trans. In the State of Georgia, if you live in the Atlanta metro area. You have to have your vehicle emission inspected. They do this by hooking up to the OBD II plug. Mine does not work! Code readers will not even work! I have check and there are voltages on this plug, but I do not if they are correct. The Jeep runs great! Dash works properly. Lights come on and go off normal when it is started. But the OBD II plug will not connect to any device. Has anyone ever heard of or come across this problem before?
CuminsChris is offline
post #2 of 18 Old 07-20-2010, 12:36 PM
DevilDogDoc
Does your check engine light work?
An ugly Jeep with some stuff.
DevilDogDoc is offline
post #3 of 18 Old 07-20-2010, 01:05 PM
lostone73
First, check your cigarette lighter. does it work? all fuses must be good for the ALDL(assembly line data link) to work right. checkall of your fuses. I speak from having the same issues when I moved to Tx. from La.
Let us know,
Bert
lostone73 is offline
post #4 of 18 Old 07-20-2010, 01:31 PM
JohnF
I work in a repair shop. Every instance of the OBD plug not working has led to a blown fuse. Many share with cigarette lighter or power outlet. Check your fuse listing, it may read DLC(Data Link Connector) or similar
JohnF is offline
post #5 of 18 Old 07-20-2010, 02:33 PM
Jonny Jeep
Jonny Jeep's Avatar
The data link connector gets power from fuse 17 in the PDC. Same as the courtesy lamps and radio/cluster permanent live.
Online factory service manuals and parts lists -
If it doesn't work properly, look for the service manual link at the bottom of the page.
Jonny Jeep is offline
post #6 of 18 Old 07-21-2010, 06:07 AM Thread Starter
CuminsChris
Thanks for all the good info guys. I have checked Every fuse in both boxes, The one under the Hood and The other behind the glove box. I will check again. I have noticed while having the entire dash torn apart that there is a cluster of plugs that are secured into a wire distribution block behind the left audio speaker. There is one plug the bottom plug that has been cut. I believe this goes to the Original radio. There is a aftermarket radio that was install prior to my ownership of the vehicle. You guys have got the brain working again. This could possibly be the area to look. I will rewire the radio as it should be. Let me know if you guys can come up with any other info.
Thanks again for your help
Chris
post #7 of 18 Old 07-21-2010, 11:41 AM
Jonny Jeep
Jonny Jeep's Avatar
If you need help finding out what all the wires go to have a look at the factory service manual on line at Jeep Service Manuals
post #8 of 18 Old 07-21-2010, 11:56 AM
finalreckoning
1997 TJs didn't have OBDII, they had the older OBDI.
Good luck finding an OBDI reader.
Green Jeep Member #273
High School Jeepers #169
finalreckoning is offline
post #9 of 18 Old 07-21-2010, 12:04 PM
George Dickel
George Dickel's Avatar
Huh? This is news to me. They both utilize a 16 pin data connector...
'98 Wrangler Sport, 4.6L Stroker
12 Counterweight 258 Crank (cut snout-casting #3214723), Sealed Power +.030 Hypereutectic Pistons, 5.875" Connecting Rods, CompCams 68-231-4, Ported/Polished Head, Edelbrock Header, 24# Ford Blue-top Injectors, 63mm bored OEM Throttle Body, Port matched Intake, Autolite Platinum plugs, Accel Coil, LiveWires Distributor & Wires, Centerforce Clutch, Hurst Shifter, modified Mustang GT Air Cannister - CAI, 18" Magnaflow and 2 1/2" exhaust, Balanced Rotating Assembly, Custom PCM tune.
Yeah, I built it!
Exhaust clip:
'04 Mustang GT, 4.6L
Light modifications
Read more, Post less, Search often
George Dickel is offline
post #10 of 18 Old 07-21-2010, 12:07 PM
DevilDogDoc
Incorrect obd2 started in 96 my 97 is obd2 compliant. Look at the sticker under the hood
post #11 of 18 Old 07-21-2010, 12:20 PM Thread Starter
CuminsChris
The Tj rolled off the assembly line in 3-96, but was sold as a 97 year model. As far as I can see, They did not sell a 96 model. that was the year they switched over to the new style. Round headlights, coil springs etc. I am also pretty sure that the OBD I & OBD II plugs are way different.
post #12 of 18 Old 07-21-2010, 12:24 PM
DevilDogDoc
I am not an idiot I am fully aware of when TJ's came out mine was made 5/96 and titled as a 97 what I mean is industry wide obd2 came out in 96 which applies to our TJ's
post #13 of 18 Old 07-21-2010, 12:37 PM
freeskier93
97 is OBDII, in Colorado they hook to the car during emissions and It clearly says on the TV screen when they plug in, "OBDII Connection complete". I've also used OBDII scanners at advanced auto parts to clear codes. PLUS you can read codes through the odometer, which I believe can only be done with OBDII cars.
freeskier93 is offline
post #14 of 18 Old 07-21-2010, 12:39 PM Thread Starter
CuminsChris
Sorry, I was referring to Finalreckoning post. Not yours Devil Dog. I totally agree with you
I know it is a OBD II. I need to figure out why it will not connect with any devices. ie. Emissions, Code readers
post #15 of 18 Old 07-21-2010, 02:51 PM
finalreckoning
Sorry about that. I had been told somewhere that the 98+ were OBDII, not the 97.
Thanks for correcting me!
(I'd always figured that's why 97 had the error code readout, and 98 didn't, and after 98, they were P- codes)
OBD II , error , malfunction , tj , wrangler
a/c plug (lighter plug) how to make it stronger herculz TJ Wrangler Technical Forum 8 12-10-2009 02:07 PM
Spark Plug & Oil Drain Plug Torque Specs bfewkwa TJ Wrangler Technical Forum 7 08-28-2009 07:19 PM
Where is the drain plug and fill plug on manual transmission Mr_E YJ Wrangler Technical Forum 2 07-11-2009 04:26 AM
large drain plug and fill plug stu'sjeep TJ Wrangler Technical Forum 4 04-21-2008 09:14 PM
HVAC fan inop except on High, found the wiring & plug fried... need plug. Jerry Bransford TJ Wrangler Technical Forum 18 02-21-2005 03:44 PM
