'97 - '02 TJ Auto trans differences? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > '97 - '02 TJ Auto trans differences?
FS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitFS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 08-16-2014, 04:35 PM   #1
Bigflo
The 32RH Auto trans in the '98 TJ bit the dust so time for a new/used trans. I saw the standard trans specs on the Sticky Note at the top of the forum, which says the 32RH ws used from '97 thru '02.
Does anyone know if there are any differences between the years that need to be considered - electrical connections, fasteners, etc? I'd hate to be in the middle of the install and find it doesn't work for some reason.
Bigflo is offline   Reply With Quote
Unread 08-17-2014, 12:28 AM   #2
Robm225
My 2002 has a 32RE, I'm not sure what other years have.
Robm225 is offline   Reply With Quote
Unread 08-17-2014, 12:51 PM   #3
JBTJ
JEEPer For Life
JBTJ's Avatar
Really? can you post a pic of it? Or, any info about it?
JBTJ is offline   Reply With Quote
Unread 08-17-2014, 01:54 PM   #4
LaddieHanus
Service manual for 2002 shows a 32RH. Doesnt make sense since that was the last year of the trans to change it to electronic shifting but I have seen stranger things from Chrysler. Car-part.com also shows 98 -2002 interchangeable.
Laddie Hanus
97 TJ Sahara
89 YJ
2000 Dodge/Cummins Lance Camper
2004 GC Limited (Wife Jeep)
LaddieHanus is offline   Reply With Quote
Unread 08-17-2014, 09:09 PM   #5
UTWeezul
They should all be the same. Mine was when I had to replace it due to a cracked transmission housing. Why not just have it rebuilt? I had the "new to me" trans rebuilt for under $1,000 and installed it myself.
35" MTR Kevlars
TNT Phantom Fenders
PSC full corners w/ 3" flares
HP30 and 8.8 w/ lockers
UTWeezul is offline   Reply With Quote
Unread 08-17-2014, 09:37 PM   #6
Jerry Bransford
Do it right or not at all
Jerry Bransford's Avatar
What makes you believe it's a 32RE? The last member here who thought he had a 32RE eventually figured out that he had the normal 32RH afterall.
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is online now   Reply With Quote
