97 to 02 and 03 to 06 Transmission Pan Help - JeepForum.com
post #1 of 1 Old 10-11-2011, 01:04 PM Thread Starter
nickrad8
I am replacing the frame on my 99 sahara with the frame from a 4 cyl 05 TJ. The only detail i have yet to square away is the transmission pan. i have been looking for the proper placement of the holes on the pan but havent found anything. does anyone know where to drill the holes in the pan so it will match up with the transmission mount and the new frame?
nickrad8 is offline
frame , mounting holes , tj , transmission , transmission pan
Driveshaft from Automatic transmission to a Manual Transmission !! Popo TJ Wrangler Technical Forum 7 10-03-2011 04:37 PM
Skyjacker Transmission Oil Pan for 32RH transmission sgort2 TJ Wrangler Technical Forum 3 09-28-2011 04:47 PM
bolt size for transmission mount to transmission? YJ89jeepTX YJ Wrangler Technical Forum 3 08-26-2011 08:22 AM
Installing transmission: to install transmission and t-case as a unit or separately? Arron TJ Wrangler Technical Forum 8 10-03-2009 05:10 PM
new transmission going in... advice for transmission n00b? VABYJ YJ Wrangler Technical Forum 5 07-10-2007 08:43 PM
