'93 hard top to 2000 TJ? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > '93 hard top to 2000 TJ?
Eliminate Hood Flutter!!!WJ Shackle Tabs: Tow-Hook Replacements2014 Spartan Locker Special - While Supplies Last! Dana 3
Unread 11-17-2013, 11:58 AM   #1
Arjay70
Looking at a 2000 Wrangler, but want a hard top. I know someone with a '93 with a hardtop. Will it fit without modification? If needs a mod, what and how hard is it?
Thanks!
Arjay70 is offline   Reply With Quote Quick reply to this message
Unread 11-17-2013, 12:34 PM   #2
durango-bob
No. It will not fit and would require quite a bit of work to make it work. Are you good with fiberglass work?
durango-bob is offline   Reply With Quote Quick reply to this message
Unread 11-17-2013, 03:29 PM   #3
Neil F.
No fiberglass work required. You have to cut/sand the front edge. There are several threads how to do it. Just google yj, tj hardtop
Neil F. is offline   Reply With Quote Quick reply to this message
Unread 09-25-2014, 09:16 PM   #4
Arjay70
Thanks
Actually just got my Jeep and it's a 2001. I believe a hard top from 1997 to 2006 will fit, so looking.
Unread 09-25-2014, 10:07 PM   #5
onemorejeep01
Best of luck enjoy the Jeep!
That's all it costs??
onemorejeep01 is offline   Reply With Quote Quick reply to this message
Unread 09-26-2014, 09:44 AM   #6
bbradUSMC
Older model will work just requires trimming the front edge.
bbradUSMC is offline   Reply With Quote Quick reply to this message
Unread 09-27-2014, 12:10 PM   #7
Arjay70
Thanks for the help! I have lots of little ideas in mind and this forum seems to be a goldmine for ideas. If there ever was a vehicle that makes personal modifications easier, the Jeep has to be it.
Unread 09-27-2014, 06:00 PM   #8
aalbinger
Flatlander
aalbinger's Avatar
http://www.jeepforum.com/forum/f9/convert-yj-top-tj-1280238/
98 TJ Sahara
Black Jeep Society
aalbinger is offline   Reply With Quote Quick reply to this message
