90,000 Miles Maintenance - JeepForum.com
post #1 of 6 Old 09-10-2010, 08:14 AM Thread Starter
kehoe
Hi all,
I have search and looked through the maintenance schedule, but I would like your input to see if I am missing any major maintenance items.
I have:
Serviced both diffs this past winter (probably do them again in the winter) (<15,000 miles ago)
Serviced transmission this summer
Serviced transfercase last summer (<15,000 miles ago)
Replaced coolant this summer
Change oil/filter, lubed up the front end, and rotate tires every 3-5k miles
Replaced brake fluid last summer (<15,000 miles ago)
Will be replacing air filter before winter
Changed power steering fluid this summer
My spark plugs (Autolite platinum plugs) probably need to be looked at, I changed them about 30,000 miles ago
I checked my brake pads and rotors and they are still good
I know I need to change my serp belt soon, but I am monitoring that
I think that includes all the major maintenance I have done recently. Any help on what I am overlooking?
Thanks!
kehoe is offline
post #2 of 6 Old 09-10-2010, 08:31 AM
bniedert
bniedert's Avatar
my 2000 TJ FSM calls out...
90,000 Miles (144 000 km) or at 72 months
Change engine oil.
Replace engine oil filter.
Replace engine air cleaner element.
Replace spark plugs.
Inspect drive belt, adjust tension as necessary (2.5L only).
Inspect drive belt and replace as needed (4.0L
only).
Lubricate steering linkage.
Drain and refill transfer case fluid.
Inspect brake linings.
Lubricate steering and suspension ball joints.
Oswego, IL
2000 TJ 4.0 5 Speed - currently
Formerly: 2000 TJ 4.0 Auto REBB
2001 XJ 4.0 Auto
bniedert is offline
post #3 of 6 Old 09-10-2010, 10:12 AM Thread Starter
kehoe
Thank you for the quick reply. I have reviewed the FSM, but I was wondering if there is anything which people change more frequently than the FSM which I may have missed. For example, I do not believe the FSM ever calls for changing manual transmission fluid, yet many people do this every 30,000 miles.
kehoe is offline
post #4 of 6 Old 09-11-2010, 04:27 PM
Night Wolf
probably be a good idea to change the 4 coolant hoses as preventative maintenance
Night Wolf is offline
post #5 of 6 Old 09-11-2010, 06:16 PM
StickIt
Inspect all the steering linkages and ball joints also, maybe an alignment. I think all the other comments have you covered fairly well.
Most of the time we overlook all of the things. Great job researching and asking questions!
StickIt is offline
post #6 of 6 Old 09-11-2010, 08:23 PM
gmiller0737
Your list covers about everything I would test the battery & clean the terminals if needed.Replace cooling system hoses if they are original,If it's a stick check clutch fluid,check all lights to see if any bulbs need replacement,wiper blades?
gmiller0737 is offline
maintenance
Comin up on 45000 miles...maintenance? SloLearner TJ Wrangler Technical Forum 8 06-15-2010 08:18 PM
I'm approacing 65k miles. What maintenance should I look into doing? Butchy_Boy TJ Wrangler Technical Forum 4 01-24-2010 04:37 PM
2002, 69k miles, Routine Maintenance? outlanderbz TJ Wrangler Technical Forum 4 08-13-2009 07:37 PM
30000 miles...what to do for maintenance Jetscuh TJ Wrangler Technical Forum 7 09-25-2008 04:12 PM
Normal maintenance @ 60k miles Clocks TJ Wrangler Technical Forum 11 05-07-2005 01:08 AM
