09-07-2007, 07:33 AM
#1
The 888888 problem, I've read and read
I know this has been discussed many many times, but I have replaced all fuses and I'm stilling getting the 888888 on the odometer. I'm trying to buy this Jeep from my work but they can't/won't get rid of it until they know what the mileage is. I've pulled the gauge cluster and put it back in and unhooked the battery and then re-hooked it up. I've replaced the IOD fuse and just about all the other fuses to just to make sure, but it still has the 888888 reading in the odometer.
Has anyone ever heard of the stock radio causing any problems with this? I only ask because when I turn the Jeep on the radio starts clicking and tries to eject a cd that isn't there and I know replacing the stock stereo sometimes causes problems.
Any help would be greatly appreciated. The next thing I was going to try is to replace the gauge cluster but I don't know if that will help or not. I just sold my 97' Wrangler and I need to figure out what is wrong with this Jeep so I can make it mine, it's so frustrating!
Thanks,
Rob
Rob
Fishers, IN
2004 Sport automatic, Moab wheels with 265's, 2.5" spring lift, quick discos, and etc. More to come over time...
09-07-2007, 07:48 AM
#2
Maybe it really has 888888 miles on it. . .
I got the reading after replacing my stock head unit and didnt notcie for a couple days, but all i did was unplug the unit, the battery, and then reconnect and it was fine. . .
97 TJ 4.0 5 Speed 2" Spacer 1.5" BL 33" Trxus MT's
subs, comps. gotta hear it on the highway.
To Do- New Lift, Tube Fenders, D44, 4.56
09-07-2007, 09:21 AM
#3
I think the head unit issue is just a coincidence.
I'd just plan on replacing the cluster. My understanding is that any mileage logged while the odometer was offline does not get recorded at all. The dealer re-programs the cluster when it's installed.
I'm not certain this is the case, but in my dealing with the issue myself and talking with people, thats how I think it''ll work out for you.
I never replaced mine but I'm almost certain that's the problem. I plugged another persons cluster in mine and it worked fine, but displayed their mileage.
Tom
09-07-2007, 09:33 AM
#4
I called the dealer and they won't sell me a cluster without a worker order registered with them and they have to switch it out and the part alone will cost $670! That is such crap. Anybody have any other ideas? I don't have one I could switch out with because I sold my 97' already and I don't have any friends around here that have a TJ. This sucks!
Rob
Fishers, IN
09-07-2007, 10:53 AM
#5
salvage yard?
09-07-2007, 11:19 AM
#6
I've been calling salvage yards all day and none around me have any. I'm going to keep trying to find places that might have one but no luck as of yet.
Rob
Fishers, IN
09-07-2007, 11:23 AM
#7
try out ebay..
09-07-2007, 11:41 AM
#8
Problem is the mileage is stored seperately in the cluster and the pcm. If you replace the cluster it will show the mileage of the new cluster. Are you sure its just not a bad connection. I know some model years the cluster pins wouldn't make a good connection and over time you had to pull the cluster and fix the pins.
2004 Black Rubicon w/ 5 spd
RE 3.5 SuperFlex & Front Trackbar / JKS 1.25" BL & MML / 35x12.5 MTRs on 15x8 AR-23s / Currie Anti-Rock / Jeeperman Bumpers / Rokmen Sliders / York OBA / Harbor Freight 8k Winch
09-07-2007, 01:24 PM
#9
I'm going to try that again and see if it works. I only cleaned the connection the first time. Luckily I called and talked to the service manager at another dealership and he had me go there and he hooked up the computer to it so he could get the mileage for me. Hopefully now I can at least complete the sale. Thanks for everyone's help. I'll try the messing with the connection some more and let you know what happens.
Rob
Fishers, IN
09-07-2007, 01:53 PM
#10
Why don't you look here in the "part out" section. There are a few people with totaled Jeeps that could probably sell you one.
-mpyusko
_________
'97 SE Black, 4cyl/5spd, Soft top, Jeeperman Rear Bumper, 33x12.5x15 Trxus M/T's, 4" Lift, 1" JKS MML
BLACK JEEP Club V2.0 #84
Rust-Bucket Build-Ups Club Member #1 Pictures of my JeepSAVE PARAGON AP!!
09-07-2007, 02:42 PM
#11
Vintage Member
drive it a mile, then it will say 888889
How's that Hope and Change workin for ya?
Black Jeep Club v1.0 and v2.0 #1776
DR Z MUST BE STOPPED #7
09-07-2007, 02:44 PM
#12
Take the cluster off again and really clean the conections then slightly twist the pins so that they make more contact and put dialectric grease on them and put it back together..
09-08-2007, 06:10 PM
#13
Tried it and no luck at all again. I guess I'm just going to try to find a cluster either here in the parts section, salvage yard, or ebay. I did however run the codes and this is what I got:
Of course at the beginning I got the Sof 4.0,
then it gave me the numbers: 794654 Does anyone know what this means?
Then at the end I got 05-00
Any code help would be great.
Thanks!
Rob
Fishers, IN
