8000 mile road trip - Page 2 - JeepForum.com
post #16 of 27 Old 08-04-2010, 07:55 PM
Bane7962
Spare belts, Ujoints, etc.
Working with cars is a little like a really awesome date: you start out expecting this to be something simple and straightforward; four hours later you're laying under her, panting and cursing, and things are a lot more complicated than you thought.
When my Jeep stops making strange noises, I become concerned. That usually means I have to go back and find whatever fell off.
Bane7962 is offline
post #17 of 27 Old 08-05-2010, 12:43 PM Thread Starter
Madmanmiller802
Okay, I have the appt to do diffs both, transfer case fluid change, transmission oil change and a coolant flush. I will stop by the parts store and get my 6 qts of synthetic, and my K and N oil filter for 30 bucks. Filter alone is 10 bucks normally. and plugs and wires.
I can picture Lumpster sticking it to DC. IDC what they say. But better safe then sorry. I have a spare u-joint, but god I would hate to change that on the road. I know some of the hardcore off roaders do it on the trail, and I did my axle u-joint in the driveway, but i would hate to do it on the road.
2004 Jeep Wrangler Rubicon
Yellow Wrecked For Now
Madmanmiller802 is offline
post #18 of 27 Old 08-05-2010, 12:48 PM
MountainMan864
Exactly what is your route? 8k roundtrip or one way?
MountainMan864 is offline
post #19 of 27 Old 08-05-2010, 12:56 PM
BriansCJ
1994 XJ Cherokee
Do the diffs and transfercase yourself. You will save at least $150 if you dealer tries to charde what mine did. BTW, If Im 15 and can do it with ease, you should have absolutely no problem with a razor blade, rag, 13mm socket(diff bolts), and 30mm socket(back of tcase), a botle of brake cleaner(to clean out diffs), tube of RTV, and 2 quarts of ATF(t-case), and around 3 or 4 quarts of gear oil.
- Daily Driver & Weekend Wheeler
- Slow
BriansCJ is offline
post #20 of 27 Old 08-05-2010, 01:37 PM
scs2016
btw, the air filter was a good idea -- especially if you're hitting a lot of dusty areas. Quality paper is better than a K&N, you can search the forum for the endless debate.]
You said you have freshly balanced tires, that's great. Keeping your front suspension components lubed is important to ward off the dreaded DW.
scs2016 is offline
post #21 of 27 Old 08-05-2010, 06:27 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
You don't have plug wires...
Knuckelhead is offline
post #22 of 27 Old 08-05-2010, 06:29 PM
Knuckelhead
AFSOC Retired
He's talking about the oil filter...
post #23 of 27 Old 08-06-2010, 08:04 PM Thread Starter
Madmanmiller802
Got the diffs fluid changed and t case fluid
Got the tranny flushed and radiator flushed.
Total 400$
Oh well good to go now. Transmisssion flush is 160 alone.
I put in a WIX air filter and the Kand N is oil. which I haven't heard bad things about and costs 13.99. but they have the full synthetic with this filter for 26.99.
I bought Bosch plug which i realized are.
so I will go back and get champions
also I will be following this guide Jeep Spark Plug Remove and Install
for my wireless plugs. I wondered why no one carried wires for this year.
Thanks everyone.
The route is roundtrip
Vermont to Moab to vegas to LA to lake tahoe to colorado to NC to vermont
YEEEEEHAAAAAAAAAAAH
post #24 of 27 Old 09-02-2010, 04:05 PM Thread Starter
Madmanmiller802
ended up being 10K whoops
Changed it when I got back
pretty dark....
No issues mechanically
The axle shaft seal i beleive was leaking the whole time, but it made it okay.
Slept in the jeep like 14 out of the 21 nights
post #25 of 27 Old 09-02-2010, 04:14 PM
bige2533
Now that's a bonding experience with a Jeep (and anyone else that went with you)!
bige2533 is offline
post #26 of 27 Old 09-02-2010, 04:29 PM
smotrs
How big are you? That had to be one cramped sleeping arrangement.
smotrs is offline
post #27 of 27 Old 09-02-2010, 05:36 PM Thread Starter
Madmanmiller802
5' 10" I made a 6' bed worked great. Me and the girlfriend slept in it.
http://www.jeepforum.com/forum/f68/b...te-up-1097095/
road trip , miles , maintenance , oil change , tj , wrangler
2500 mile road trip, tj wrangler facts and questions 06TJwrangler TJ Wrangler Technical Forum 17 01-05-2012 10:07 AM
About to pull a 2500 mile road trip around Europe... Cleggmeister JK Wrangler Technical Forum 12 06-28-2010 06:52 AM
mile marker pe 8000 champelite210 YJ Wrangler Technical Forum 13 01-29-2008 12:43 PM
300 mile trip brcfan0142 YJ Wrangler Technical Forum 14 07-28-2007 01:26 PM
5,000 mile road trip mjkolb02tj TJ Wrangler Technical Forum 6 07-24-2007 07:04 AM
