8000 mile road trip - JeepForum.com
post #1 of 27 Old 08-04-2010, 01:52 PM Thread Starter
Madmanmiller802
8000 mile road trip
I have 35,000 miles. I will do a synthetic oil change before I leave, and one halfway through. I know air pressure in tires, and I will grease it.
Anything major I should check?? It will be a three week road trip of 8,000 miles.
I have an auto. transmission. Diff fluid? transmission fluid?
Maybe the blinker fluid?
thanks
chris
2004 Jeep Wrangler Rubicon
Yellow Wrecked For Now
Madmanmiller802 is offline
post #2 of 27 Old 08-04-2010, 02:04 PM
snowrydr01
hot damn, thats more then i put on it in the last two years...
Maybe some spark plugs and a new air filter? basic maintenance stuff
snowrydr01 is offline
post #3 of 27 Old 08-04-2010, 02:09 PM
bige2533
Check your belt and be sure your tires will last another 8K.
bige2533 is offline
post #4 of 27 Old 08-04-2010, 02:13 PM
lumpster
lumpster's Avatar
i wouldnt bother replacing the motor oil unless you are pulling a trailer or really pouring the coals to it. i would just change it when i got back. I would suggest changing the transmission fluid before you go, and if you havent changed the diffs and transfercase recently (20,000) miles i would do that too.
I bought a roll of rescue tape
Welcome to Rescue Tape!
to keep from having to worry about the hoses
lumpster is offline
post #5 of 27 Old 08-04-2010, 03:08 PM
timberwolf0122
Will you be driving off the beaten track? if so make sure your battery is in good order and take a jump start pack just in case.
Atheist Jeep Club Member #2
Doctor Who has died 13 times, is on his 14th regeneration and has a time machine, beat that Jesus.
timberwolf0122 is offline
post #6 of 27 Old 08-04-2010, 03:22 PM
blubaru2002
check your coolant level. overheating on a roadtrip sucks!
Originally Posted by Patrick Bateman
I have to return some video tapes.
blubaru2002 is offline
post #7 of 27 Old 08-04-2010, 03:47 PM
jerseyjeep22
your most likely going to have to fill your tank a few times during the trip, make sure not to let the gas needle hit the big E while your driving
jerseyjeep22 is offline
post #8 of 27 Old 08-04-2010, 04:41 PM
kittyhawk
Change the tranny filter if you have not done yet. Flush the coolant and maybe swap out the plugs if they are the orignal.
Check tires rotate then air up, check spare.
I drove from the North VA to SE NM in late May and back in late June and did all the above and had zero problems.
I had 33" tires on my with 3.73 gears, I was able to get a set of 30" firestone at's for the road and wow they did great. I got around 15 to 16.5 mpg most of the way.
Was able to run most of the time with the AC off and windows cracked and back window rolled up. I wore ear plugs tho......
Hope this helps.
Dave
kittyhawk is offline
post #9 of 27 Old 08-04-2010, 07:01 PM Thread Starter
Madmanmiller802
I got ear plugs.
I got a jump pack.
I just rotated my WAHWAH MTRs
tranny fluid/filter (this is new to me)
Diff Fluid t-case changed.
Plugs
Flush coolant
Thanks for all the replies.
Chris
Oh yeah I plan on going topless till my brain rattles around and my ears bleed
post #10 of 27 Old 08-04-2010, 07:39 PM Thread Starter
Madmanmiller802
Drain auto tranny fluid and filter at 60K in maitnence manual is that still recommended here on JF
I will do diffs, plugs and a coolant flush and a 27 point inspection.
Thanks
post #11 of 27 Old 08-04-2010, 07:39 PM
lumpster
lumpster's Avatar
Originally Posted by Madmanmiller802 View Post
I got ear plugs.
I got a jump pack.
Plugs
Flush coolant
Chris
I suggest sunblock, I bought a safari top to use instead of sunblock, but im a weenie.
lumpster is offline
post #12 of 27 Old 08-04-2010, 07:40 PM
chris142
8000 hwy miles on synthetic oil shouldn't be a problem. I'd run the larger oil filter though. Although Probly not needed. The extra 1/2 qt of oil with the larger filter wouldn't hurt.
I'd like to see a used oil sample report after the trip.
chris142 is offline
post #13 of 27 Old 08-04-2010, 07:40 PM
lumpster
lumpster's Avatar
Thanks
i dont care what is recommended, i change my automatic transmission fluid every 30k, its what i do on the wifes GC, and its what ill do on my next DD. the jeep is a 6 speed.
lumpster is offline
post #14 of 27 Old 08-04-2010, 07:52 PM
bravobravo
^ i agree with them
Mainly because when i brought the jeep at the stealership he said to flush the trans every 30k and not to have them do it because a shop literally three blocks away did it for 40$ cheaper
^ it made more sense in my head
removed for stirring the pot
bravobravo is offline
post #15 of 27 Old 08-04-2010, 07:54 PM
bravobravo
oh and i only changed my oil with them because i had a few free oil changes for buying the gas chugger
road trip , miles , maintenance , oil change , tj , wrangler
2500 mile road trip, tj wrangler facts and questions 06TJwrangler TJ Wrangler Technical Forum 17 01-05-2012 10:07 AM
About to pull a 2500 mile road trip around Europe... Cleggmeister JK Wrangler Technical Forum 12 06-28-2010 06:52 AM
mile marker pe 8000 champelite210 YJ Wrangler Technical Forum 13 01-29-2008 12:43 PM
300 mile trip brcfan0142 YJ Wrangler Technical Forum 14 07-28-2007 01:26 PM
5,000 mile road trip mjkolb02tj TJ Wrangler Technical Forum 6 07-24-2007 07:04 AM
