an $80 snorkle? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > an $80 snorkle?
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRuffstuff 10 year saleRough Country Lift Kits and Parts!
Unread 01-05-2016, 08:01 PM   #1
Ross
an $80 snorkle?
I am planning a run down in the Ozarks and may encounter some deeper water. Any thoughts on this snorkle? http://www.amazon.com/Intake-System-...rds=tj+snorkel
01 TJ, 34 Super Swaper 34x10.5 bias, Winch, locked, belly up, some armor.
Ross is offline   Reply With Quote Quick reply to this message
Unread 01-05-2016, 10:05 PM   #2
Mousejockey
How deep? the air intake from the factory is roughly waist level when in the drivers seat.
Mousejockey is online now   Reply With Quote Quick reply to this message
Unread 01-05-2016, 10:20 PM   #3
Jerry Bransford
Administrator
Jerry Bransford's Avatar
There's no water deep enough to require a snorkel I'd drive my TJ through.
Getting Savvy...
Jerry Bransford is online now   Reply With Quote Quick reply to this message
Unread 01-05-2016, 10:22 PM   #4
Ross
Last time I went down that way there was a quick drop off one of the water crossings. It was deeper than it had been it recent time. When you entered the water it was deeper than the front of the hood. It did become shallower but the entrance was deeper than expected. The others in the group had snorkels, I went to shallower area to cross. I don't intend to go in deep up things happen and rivers can change. I have experience doing water crossings but I want to be more prepared for the unexpected. With a good bow wake you can go through deeper water with out issue but when it starts deep you can have issues.
Unread 01-06-2016, 08:06 AM   #5
fromme
Seems like the best option is to continue going to the shallower area to cross.
"The Wicked Flee When No Man Pursueth, But The Righteous Are Bold As A Lion."
fromme is offline   Reply With Quote Quick reply to this message
Unread 01-06-2016, 08:34 AM   #6
Ross
and that is the plan but things change mid river. Hopefully it is not needed but it happens.
Unread 01-06-2016, 08:45 AM   #7
Ironhead
ever looked into a cowl intake? only moves the intake up 8" or so, but it puts it behind the firewall, which eliminates the nose down water issue.
just as important, have you moved all of your breather lines? if those get submerged, you'll be looking at a very expensive day
Ironhead is offline   Reply With Quote Quick reply to this message
Unread 01-06-2016, 08:50 AM   #8
glook
Looks like one of many chinese clones of arb safari. You'll probably have to replace the flexible duct and elongate the slots on the "head". Other than that, it should work fine.
2002 TJ 2.5L
glook is offline   Reply With Quote Quick reply to this message
Unread 01-06-2016, 08:54 AM   #9
glook
I'd say it creates more problems than it solves. Ever had you cowl drain clogged?
2002 TJ 2.5L
Unread 01-06-2016, 08:56 AM   #10
Ben
Hack
Ben's Avatar
Make sure you smother your distributor in asbestos waterproofing compound too.
But seriously bring a can of WD40 in case you get water in your distributor.
5.3L TJ
Ben is offline   Reply With Quote Quick reply to this message
Unread 01-06-2016, 08:59 AM   #11
Ross
good with breather lines. I am not a fan of re-moving my air box. Jeep did good with their air box. Water crossing are not new for me. Usually not much deeper that the floor board, if even that deep. My concern is that hole that wasn't there last time.
Just looking for info on that particular snorkel.
Unread 01-06-2016, 09:02 AM   #12
jjvw
jjvw's Avatar
Keep the cowl drain clear.
'03 Rubicon
jjvw is offline   Reply With Quote Quick reply to this message
Unread 01-06-2016, 09:27 AM   #13
MurdaJs
I've heard from guys in Alaska that the issue with cheap China snorkels is the plastic gets brittle in the cold, more so than the arb snorkel.
[QUOTE=Marauder_Pilot;33845457]I'd suck an acre of cocks for a nice expo-built Tacoma[/QUOTE]
MurdaJs is offline   Reply With Quote Quick reply to this message
Unread 01-06-2016, 10:15 AM   #14
TheBoogieman
Evil Inside!
TheBoogieman's Avatar
I already bought an $80 snorkel. You can't ever be too prepared.
If you don't like the opinions expressed here,then you really don't want to hear the ones I keep to myself.
TheBoogieman is offline   Reply With Quote Quick reply to this message
Unread 01-06-2016, 10:24 AM   #15
TheBoogieman
Evil Inside!
Maybe?
Maybe an XJ would be OK.
