8.8 swap - pinion angle - JeepForum.com
post #1 of 31 Old 10-27-2010, 01:01 PM Thread Starter
alex_c
I'm doing an 8.8 swap on my TJ with a 2" BB, and 1" MML/BL. I tacked the brackets on with the pinion angle set at around 13-14*. I will be running an SYE and adjustable UCA's. Will this work well? I will probably go for a 3.5-4" lift in the future, so I thought that It would be wise to account for that.
Anyone running a similar setup with an 8.8, what did you set your pinion angle at?
alex_c is offline
post #2 of 31 Old 10-27-2010, 01:27 PM
stuntjumper
I'm having mine built now and it is set to 15deg. I'm not running adjustable UCA's or SYE and I'm about 3" suspension lift + 1" MML/BL.
stuntjumper is offline
post #3 of 31 Old 10-27-2010, 01:34 PM Thread Starter
alex_c
Your pinion angle should be higher with 1" more lift and a longer output shaft on the transfer case. The thing I'm worried about most is my adjustable control arms will not be short enough to bring the pinion angle down if needed.
alex_c is offline
post #4 of 31 Old 10-27-2010, 02:13 PM
TJftw
mine is 17 degrees with a 3.5" RE lift, works well thus far
(no SYE yet)
Black Jeep Society Member #398
*Jeep Wave*
TJftw is offline
post #5 of 31 Old 10-27-2010, 02:35 PM
liredneck
im installing mine now the pinion in as 15 and the tcase is at around 4 or 5 theres lots n lots of vibes , im waiting for my adj control arms to get here and has anyone noticed how far over to the pass the pinoin is its very noticeable on mine
97 tj 6 cyl 5 SPd 4" supelift 35" baja claws 8.8/hp 30 ,4.10 lockrite in the rear , RR sye and adams dc shaft ,10k lb viper winch and other crap
liredneck is offline
post #6 of 31 Old 10-27-2010, 02:40 PM
TJftw
yes the pumpkin is offset about 3" to the passenger side. Every jeep is different so it's hard to say what will work. As I said before I am running a 3.5" RE lift, with the stock driveshaft. Pinion is about 17 degrees. I also have a 1" mml and a 1" t-case drop. No problems so far. I would replace the u-joints while you're under there too. Saving up for a SYE soon
*Jeep Wave*
TJftw is offline
post #7 of 31 Old 10-27-2010, 02:42 PM
jawalterusmc
2015 JK Wrangler
Just installed mine yesterday and I noticed the same thing and I to have vibes. Funny how I missed all that on the other write ups on installing the 8.8 under a TJ. First place I turned it in to for the alignment (not off by much if any) could NOT get the correct angle on the pinion. Said they didn't have the correct tools to do it right. However they got the vibration down to a bearable amount. I'll have to try my local Off Road shop tomorrow. But I do like the feel of the 8.8...heavier, smoother ride, less bouncy on the highway. Can't wait to get the pinion angle corrected and take her off roading.
Georgia Crawlers
jawalterusmc is offline
post #8 of 31 Old 10-27-2010, 02:44 PM
TJftw
yes it does feel different doesnt it
*Jeep Wave*
TJftw is offline
post #9 of 31 Old 10-27-2010, 03:28 PM
liredneck
jawalterusmc do you have adj control arms ? what did you do for the alignement ? are you talking in the rear or the front
post #10 of 31 Old 10-27-2010, 03:46 PM Thread Starter
alex_c
can anyone with a smaller lift and SYE chime in with the pinion angle they ended up using?
alex_c is offline
post #11 of 31 Old 10-27-2010, 06:24 PM Thread Starter
alex_c
bump?
alex_c is offline
post #12 of 31 Old 10-27-2010, 06:37 PM
Gary2
I set mine up for 17 degrees when welding up the brackets . I have both adjustable uppers and lowers . RC 2.5" springs with a 3/4" spacer. I think now that it is actually all mounted up it ended up being slightly less than 17 . I decided on 17 when welding it up after reading what seemed like a million articles about installing an 8.8 . worked out fine all said and done .
Gary2 is offline
post #13 of 31 Old 10-28-2010, 06:26 AM
jawalterusmc
2015 JK Wrangler
I have the RE 7000 4.5" lift which came with
Components
RE1142 - GEN2 DISCONNECTS 4.5"-7.5" TJ,
RE1155 - SWAY BAR END LINKS REAR TJ
RE1355 - COIL SPRINGS TJ 4.5" FRONT/PA
RE1360 - COIL SPRINGS TJ 4.5" REAR/PAI
RE1380 - BUMPSTOPS 2" FRONT LOWER
RE1385 - BUMPSTOPS 2" TJ REAR UPPER
RE1553 - BRAKE LINE SET SS FRONT 20"
RE1600 - TRACK BAR, FRONT XJ/MJ/ZJ/TJ
RE1602 - TRACK BAR BRACKET TJ REAR W/CV
RE3700 - CONTROL ARM SF2 LOWER FIXED
RE3780 - CONTROL ARM SF2 UPPER FT ADJUS
RE3783 - CONTROL ARM SF2 UPPER REAR ADJ
and later added rough country adjustable rear track bar and adjustable lower control arms.
The only thing I had to adjust when installing the 8.8 was the rear track bar. I ordered it from ECGS and it came with the TJ mounts preinstalled/welded for my lift (4-5"). Had to extend it 1/4 inch to line up with the hole in the new bracket. It drove true and wouldn't have noticed any difference if it hadn't been for the vibration from the drive shaft. They made only minute adjustments in the rear to align it and decreased most of the vibrations from the driveshaft but they didn't have any proper tools for measuring pinion angles. I'll will have to take it the local off road shop to fine tune it.
Georgia Crawlers
post #14 of 31 Old 11-17-2010, 05:29 PM Thread Starter
alex_c
with my 2" lift I ended up setting the pinion angle to 12*
I was able to use the stock DS, but it was pretty close to running out of slip with the axle at full bump. I now have an SYE and CV shaft in there. I would highly recommend both if you're under 2" of lift.
alex_c is offline
post #15 of 31 Old 11-21-2010, 10:28 PM
dlloydj
Just finished my install from ECGS. Got pinion to 18 degrees, totally aligned with driveshaft, but still minor minor vibes. Could the lateral pinion angle be the cause? The DS is clearly not straight into pinion, when looking directly upwards.
dlloydj is offline
Front pinion angle vs. driveline angle Jeepin' Rock Cl TJ Wrangler Technical Forum 19 11-01-2016 05:02 PM
CV drive shaft angle vs. pinion angle mdm TJ Wrangler Technical Forum 7 12-01-2009 06:36 AM
8.8 axle swap with 4 in lift pinion angle help pigglywiggly YJ Wrangler Technical Forum 5 03-15-2009 12:42 PM
4.10 axle swap D35, 3.5" lift, pinion angle help - Pics inside +Crusader+ YJ Wrangler Technical Forum 16 08-22-2008 03:16 PM
8.8 swap pinion angle question quitelifted TJ Wrangler Technical Forum 3 02-18-2006 09:21 AM
