#121 | |
Money got tight so I had to turn in a lease vehicle and start driving my jeep since its paid off. I didnt want to commute on the set up i had; so I sold the axle, lift and tires and swapped in my old stock springs. I got a good deal on some other stock components (dana 35 with 4:11 and shocks) and threw some 31's under it. I get better gas mileage and less wear and tear now. Plus I get to sand bag and reallocate that money I was paying on the lease. Now that my wife has been laid off, Im really glad I made the decision
/l ,[____], l---L -OlllllllO- ()_)-()_)-o-)_) 8.8 Swap: http://www.jeepforum.com/forum/f9/8-8-swap-into-tj-build-thread-501704/ |
#122 | |
USAF Trained Killer
Dane
"He is no fool who gives what he cannot keep to gain what he cannot lose" Fight Me HERE! |
#123 | |
To the best of my knowledge, I used two passenger side hoses. One for the left and one for the right. Why are they insisting on the driver side hose?
/l ,[____], l---L -OlllllllO- ()_)-()_)-o-)_) 8.8 Swap: http://www.jeepforum.com/forum/showthread.php?t=501704 |
#124 |
USAF Trained Killer
They aren't insisting, I was just online and they were pointing me to a driver and passenger hose and they were different. I figured the passenger would work, I just wanted tobe sure I didn't read your post wrong.
#125 |
I used two passenger side lines. Do not use the driver's side since it is longer and will have the three way valve.
1997 Jeep TJ 1983 Jeep CJ7 2011 JK Unlimited Rubicon |
#126 |
No Problem and thanks Max-Q for the confirmation.
#127 | |
1998 jeep Sahara 4.0L, 37s, 8.8, waggy 44, custom cage, highsteer.. still building this junk 1997 sport 33duratracs and a lil lift.. my dd |
#128 |
$$ Wrench for Hire $$
For instance, to center left to right. Look at (I had my tires on the axle) distance between the tire and the frame. I ended up about an 1/8 of center and that is fine because before the 8.8 I had over 1/4 due to the lift, even after and t-bar relocation bracket. Axle under TJ and TJ frame at ride height. Center It and attach mounts to the respective parts and you can tack weld them from there. or mark the crap out of it and tack weld them and test fitment. I was able to put the full weight of the TJ on the tack welded mounts. Just for measurements, I did not drive it that way lol.
For front to back I went from the lower control arm (either the bolt hole center or edge of arm, as long as you measure the same on both sides)to the axle (measurement). Take lots of measurements to be sure you are where you want to be. If you feel like It moved, and it will, remeasure! Hope that helps |
#129 |
Nice work on the 8.8 man. This makes me want to build one so bad.
#130 |
What Phreaq said will work. Im too lazy to think about what I did at the time, but just pick points you can measure with accuracy and confirm both sides are close to semetrical. Have fun!
#131 |
Thanks! It was a fun project and I might do it again one day or build a Dana 44. Who knows.
#132 |
what inspiration i have now...im picking up a 99 explorer or mountaneer 8.8 in the am for 125 bucks..complete with all parts and emergency cables just incase..
so far i see i need 2 pass side rubber lines im running a 4 inch lift,35,s and will have a sye,cv d.shaft and someday a tummy tuck.so im hinking 15 degrees pinion angle should be fine? when i have the axle sitting at 15 degrees on the stands the spring brakets are welded on level? i think? hopefully i will get it all right the first time as the turdy5 has been getting to much abuse and needs refreshing with the 8.8.. wish me luck..it will be a few weeks before i get all the brackets..i have a spare turdy5 but the heck with those brackets even tho i could cut them off very nice they are thin..
JACK OF ALL TRADES,,,MASTER OF NONE fla cracker head born and bred build- http://www.jeepforum.com/forum/f22/punishers-ezgo-build-thread-1065655/ |
#133 | |
#134 |
great writeup! hope to get one of these soon
Other Vehicles: 07 Mustang, Whipple, 465 rwhp, Magnaflow, Hurst , AVIC D3, Spec 3+, BMR CA's, Autometer, FRPP Springs 08 F150 5.4L, Super 40 SIDO, Roush Grille, Edge Evolution, Truxport, 2.5" AS Level, 1.5" AAL, 35x12.5x20 Nitto Trail Grapplers |
#135 |
What did you use for the driveshaft? XJ front, shortened?
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
