Quantcast 8.8 Swap Into TJ Build Thread - Page 7 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > 8.8 Swap Into TJ Build Thread
Old 03-16-2008, 10:17 PM   #91
mjstranz
How did the LS work out for you, what trails did yall go up?
44/9 build :)FullWidths:)
http://www.jeepforum.com/forum/f9/college-kid-44-9-swap-470448/
Stuff for Sale lots of stuff.
http://bb.tennesseeoffroad.com/ubb/ultimatebb.php?ubb=get_topic;f=8;t=016824
GoTime Offroad Club
mjstranz is offline   Reply With Quote
Old 03-17-2008, 07:31 AM   #92
GreenJip
The LSD worked great. What trails?! The side trails were hard enough with low traction. I did play on the rock garden by the camp sight. We did a few hill climbs and water crossings. I had water up to my doors. Woolys like any park around here is different when its wet. Wish you could have been there.
/l ,[____],
l---L -OlllllllO-
()_)-()_)-o-)_)
8.8 Swap: http://www.jeepforum.com/forum/f9/8-8-swap-into-tj-build-thread-501704/
GreenJip is offline   Reply With Quote
Old 03-17-2008, 11:39 PM   #93
mjstranz
Ya another time, Im sure wet was pretty tough. Went to the new park in sparta, it will be sweet in a little while. Just let us cut some more trails.
http://www.jeepforum.com/forum/showthread.php?t=470448
GoTime Offroad Club
Old 04-05-2008, 03:03 AM   #94
ChiliPalmer
Bacon Ends & Pieces
ChiliPalmer's Avatar
[hijack]
And bringing it back for a question...
Any chance you can get a measurement for me? We started welding some brackets to a buddy's 8.8 today but the sway bar bracket is sitting way to high. Obviously the back side of the bracket is cut for the axle tube but if you place it on the axle using the current cut it's way to high and you'd never be able to get the UCA's in because they'd hit the top of the bracket!
I'm looking for the distance between the top of the sway bar bracket and the middle of the UCA bolt hole (between the two horizontal lines in the pic below). It would also help if you could measure from the top of the axle to the center line of the UCA bolt hole (the top horizontal line); this way we can verify the UCA brackets are correct.
Here's a couple of pics of our situation; they're MAD brackets by the way.
TIA for any help.
P.s. When the kit was ordered they forgot to ship the sway bar brackets so it's possible the wrong ones were shipped but if you go to their website it shows the same ones for their TJ kit - but they obviously won't work?
[/hijack]
If you want to help the sport of offroading visit the EnviroBeat Forum!
Blue Ribbon Coalition | Idaho State 4x4 Association | UFWDA | NAXJA | The KAT Team!
ChiliPalmer is online now   Reply With Quote
Old 04-05-2008, 08:54 AM   #95
onlyn8v
Really great work you did on the axle
But reading your cost list is says you are into the axle swap for $1408
Why do with the 8.8 instead of going with a 44 with some upgraded parts?
I ask because Im stuck trying to decide what to do myself.
Dave
04 Wrangler Sport 4.0
1990 VW Corrado Turbo
1998 VW Jetta TDI
1999 VW Jetta TDI 4 SALE!!
onlyn8v is offline   Reply With Quote
Old 04-05-2008, 09:12 AM   #96
GreenJip
Originally Posted by ChiliPalmer View Post
[hijack]
[/hijack]
Chilipalmer, I took some measurements this morning for you.
The distance between the top of the sway bar bracket and the middle of the UCA bolt hole is 2 1/4 "
The distance between top of the axle to the center line of the UCA bolt hole is 2 7/8".
The bracket does look strange in your picture. What is the effect if you flip it upside down and move it to the other side of the axle. Also, do a quick test fit and see if your sway bar will mount to that bracket. The holes look far apart in the picture. It could just be my eyes playing tricks on me in the morning!
I hope this helps.
/l ,[____],
l---L -OlllllllO-
()_)-()_)-o-)_)
8.8 Swap: http://www.jeepforum.com/forum/showthread.php?t=501704
Old 04-05-2008, 09:21 AM   #97
GreenJip
Thanks for your compliment! I really enjoyed this project.
The parts list I compiled includes everything I had to do to make an axle swap work correctly with the amount of lift I have. As far as the 8.8 build goes, the total cost for building just the axle is $704. The other costs are things like drive shaft, SYE, upper adjustables and so on. If you have a lift and swap in a Dana 44, you will likely want to do the SYE and CV shaft with adjustable suspension components later anyway. I mainly chose this not for the cost, but for the fun and challenge of doing it and the overall strength of the axle.
/l ,[____],
l---L -OlllllllO-
()_)-()_)-o-)_)
Old 04-05-2008, 10:29 AM   #98
ChiliPalmer
Bacon Ends & Pieces
I hope this helps.
Thanks dude; jeepinjoeapex (it's his axle) created a thread so instead of cluttering up this guy's thread I'm going to post over in Joe's.
http://www.jeepforum.com/forum/f9/mad4wd-8-8-tj-axle-mounting-brackets-542207/#post5046586
Old 04-06-2008, 01:17 PM   #99
Butch03tj
Well guys I am almost finshed with my swap all I like is the ebrake I'm going to fab some brackets like yours. Did you remove the oring from the combination/proportioning valve or not and how are your brakes working?
6in rc advance adapter sye coast cv 8.8
Butch03tj is offline   Reply With Quote
Old 04-06-2008, 08:44 PM   #100
GreenJip
I didnt do anything to the prop valve. The brakes are working great. Fabbing the ebrake bracket would have been a wiser financial choice for me.
/l ,[____],
l---L -OlllllllO-
()_)-()_)-o-)_)
Old 04-06-2008, 10:35 PM   #101
Butch03tj
yea but I would have not known how to make them if I had not seen yours thanks to you and mjstranz
Old 05-08-2008, 04:28 PM   #102
danielgoforth
Wow this looks killer, its bookmarked for reference now
1997 TJ with 4.5 Rubicon Express lift, Warn winch, sliders, 8.8, 5.7L LS1 V8, MTI X1 cam, long tube headers, tune, and a 4L60E.
danielgoforth is offline   Reply With Quote
Old 04-29-2009, 05:05 PM   #103
Osmosiz
1995 XJ Cherokee
where can i get that ebrake bracket so i can use my stock ebrake lines? is a adjustable rear track bar needed for sure?
99 XJ Sport - 3" lift, 31 BFG At's -DD
94 XJ Sport - 5" Lift, Locked on Swampers and beaten
I Just dropped in to see what condition my condition was in...
Osmosiz is offline   Reply With Quote
Old 04-29-2009, 05:59 PM   #104
littledevilTJ
nice build looks goods.
My OLD build thread:http://www.jeepforum.com/forum/f22/04-columbia-edition-project-935798/
Florida Specific Forum
www.floridajeepers.net
littledevilTJ is offline   Reply With Quote
Old 04-29-2009, 09:33 PM   #105
UTWeezul
Putting mine in this weekend! Did you have to do the cuts to make the sway bar fit or did you do it just to make it easier? If it has to be done, I'll be doing this tomorrow night I guess.
Also, the guy with the ZJ, was he from Knoxville? If so, I've gone wheelin' with him before when I used to live up there. Was his name Scott?
Enjoy life to the fullest each and every day!
http://www.midsouthjeeps.com/
UTWeezul is offline   Reply With Quote
Glock Forum
