#76 | ||
......did you say tak everything up, bolt it in and drive on the front drive shaft before you weld it solid .....please don't drive your Jeep on a rear axle with tak welds on the brackets!
/l ,[____], l---L -OlllllllO- ()_)-()_)-o-)_) 8.8 Swap: http://www.jeepforum.com/forum/f9/8-8-swap-into-tj-build-thread-501704/ |
#77 |
I'd set the pinion angle at around 17-19 degrees with a standard SYE, and even then, that's probably not going to be enough. That's a lot of freakin lift.
'02 TJ X Apex Edition '00 XJ Sport |
#78 |
Id say even higher then that, maybe 20-25 degrees, dont be in a rush to get it done. If you can wait until he has space to work on it. You can set it up and weld everything in about 8 hours or so, if your miticulous like chris (greenjip) was and test fit it 3-4 times... lol I swear it fits better then the d35 does.
44/9 build :)FullWidths:) http://www.jeepforum.com/forum/f9/college-kid-44-9-swap-470448/ Stuff for Sale lots of stuff. http://bb.tennesseeoffroad.com/ubb/ultimatebb.php?ubb=get_topic;f=8;t=016824 GoTime Offroad Club
#79 | |
Ya, that sounded worse than i meant.. ![]() |
#80 |
Looks great,job well done I just picked up a 8.8 today going to break out the grinder tomorrow
6in rc advance adapter sye coast cv 8.8 |
#81 |
sweet send me a PM if you want some help
44/9 build :)FullWidths:) http://www.jeepforum.com/forum/showthread.php?t=470448 Stuff for Sale lots of stuff. http://bb.tennesseeoffroad.com/ubb/ultimatebb.php?ubb=get_topic;f=8;t=016824 GoTime Offroad Club
#82 |
Thanks for the compliment, I owe alot of credit to mjstranz for welding this thing up and TimBrown for helping with the final instal. Its very streetable. I am planning a trip 3/15 to test it out for the first time. I will post pics if I manage to snap any. Good luck with your project.
/l ,[____], l---L -OlllllllO- ()_)-()_)-o-)_) 8.8 Swap: http://www.jeepforum.com/forum/showthread.php?t=501704 |
#83 |
thanks i'll need all the luck I can get where do you wheel at
#84 |
Mostly in East and Middle Tennessee. Wheelin in the Country, Wooly's, Wind Rock and a creek in Cookeville. If I name the creek, I might get banned.
Stranz has been to a few other trails that I'd like to get to in the future. If I could trailer my Jeep, I would like to go to Gray Rock in AL or Tellico near Knoxville.
#85 |
What was the final length of your rear driveshaft?
'84 CJ-7 Junkyard TBI 360/T18/D300, 4" 4WDH Lift, D44 front with ARB and HS/D44 Rear w/ Detroit, 4.56s, 36" Iroks, TFI, TJ flares, Homemade rocker guards and bumpers with swing out, Optima Yellow Top, M8000, York OBA, 6pt cage "when you're up to your *** in alligators, it is hard to remember that your original intention is to drain the swamp" |
#86 |
sounds like the creek in baxter lol
#87 | |
20", its in post #49. Your set up may be different though, depending on lift and other things.
#88 |
The creek is a lot more hardcore then a lot of ppl give it credit for... Just go up the falls.
#89 |
GreenJip,
How was the trip to Wooly's? Was it as wet down there as it was up here? Post up some pics. or PM a couple to me please.
OlllllllO
#90 |
Wooly's was alot of fun this weekend. It was raining hard all the way down and when we got there it rained for about an hour before it let up. The whole place was a mud bath. All the access trails to the main trails were tough. because of the low traction. The LSD in the 8.8 worked well, I don't think I would have gone anywhere without it. Tims Jeep is locked, so he didn't have near as much trouble as I did. I found a little rock Garden to play in, and discovered that when my front driver tire drops, the yoke on the driveshaft hits the engine skid, This is because of the HP D30. I am going to have to cut that away to make room. We also hooked up with some guys in a ZJ. That was a really nice Jeep. I don't have many pics to show, it was one of those you had to be there things, but here are a few. The guy with the grand took some pics, I will get them from him later. My camera man took alot of sideways pics and they are hard to view. Most of the ZJ pics are blury.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
