Quantcast 8.8 Swap Into TJ Build Thread - Page 3 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > 8.8 Swap Into TJ Build Thread
Old 01-05-2008, 10:06 AM   #31
GreenJip
Originally Posted by REDTJ35
welding cast is not hard, just get the nickel electrode and weld up. cast iron now adays is so advance to where it easier to weld without cracking.
to tell the difference between cast steel and cast iron is if its cast steel there will be metal shaving if you drill a little hole some where if its cast iron drilling a hole it will be dust
Thanks for that info. Someone told me the other day that it was cast steel without looking and you confirmed that for me. I had shavings when I drilled and taped the pumpkin for the T-Fitting, so it is definitly cast steel. That gives me a better feeling about welding the tubes. Thanks again.
/l ,[____],
l---L -OlllllllO-
()_)-()_)-o-)_)
8.8 Swap: http://www.jeepforum.com/forum/f9/8-8-swap-into-tj-build-thread-501704/
GreenJip is offline   Reply With Quote
Old 01-05-2008, 11:20 AM   #32
ErikJordan
Pimp Hand
ErikJordan's Avatar
the 8.8 housing takes a weld just fine.
you can do it with your mig on the tubes.
having "shaved" mine, and welding it with a mig 2+ years and 100 trails ago, i'd say the diff will hold a weld just fine.
the tubes you propose to weld are a hell of a lot less suceptable to damage than the bottom of te diff.
go for it.
___________________________________________
What is all of this talk of Savvily designed products?
ErikJordan is offline   Reply With Quote
Old 01-05-2008, 12:14 PM   #33
mjstranz
Ya I can set it up, it would have to be in cook vegas and I would have to get the tools back, It would probably take me a weekend though...
Sweet shaved housing dude!
44/9 build :)FullWidths:)
http://www.jeepforum.com/forum/f9/college-kid-44-9-swap-470448/
Stuff for Sale lots of stuff.
http://bb.tennesseeoffroad.com/ubb/ultimatebb.php?ubb=get_topic;f=8;t=016824
GoTime Offroad Club
mjstranz is offline   Reply With Quote
Old 01-05-2008, 01:13 PM   #34
GreenJip
go for it.
I am having mixed answers about migging and sticking. I am going to have someone burn a nickle rod in it I think. How much clearance were you able to save by shaving that pumpkin and what gears are you running in it?
Good, we can do it together and maybe I'll learn something. Let me get the HP housing and see if I can find some gears on eBay.
/l ,[____],
l---L -OlllllllO-
()_)-()_)-o-)_)
8.8 Swap: http://www.jeepforum.com/forum/showthread.php?t=501704
Old 01-05-2008, 01:33 PM   #35
mjstranz
I its steel then why cant you just MIG it??? any input would be great.
Also wouldnt nickle rod make a weak weld in cast steel? Just a thought.
http://www.jeepforum.com/forum/showthread.php?t=470448
GoTime Offroad Club
Old 01-05-2008, 07:22 PM   #36
ErikJordan
Pimp Hand
ErikJordan's Avatar
i got about 1.25" by shaving it.
Old 01-08-2008, 05:43 PM   #37
Jeeptuber
Great job guys! A friend of mine is planning this very same swap so I'm going to direct him here.
Just one note of warning, now that you have this sturdy axle and bracket assembly - keep an eye on your upper control arm frame brackets. They're only 1/8" and they will break! Feel free to ask me how I know.
Mark
www.jeeptubes.com
Pre-bent tube for your fabrication projects
Jeeptuber is offline   Reply With Quote
Old 01-08-2008, 05:47 PM   #38
GreenJip
Please tell, this is an open thread untill I get more dinero to finish this up anyway.
I also need to know %100 without any doubt from more who have migged there housings if its ok to do so. We already know that mine is cast steel.
/l ,[____],
l---L -OlllllllO-
()_)-()_)-o-)_)
Old 01-08-2008, 05:58 PM   #39
Jeeptuber
[QUOTE=GreenJip]Please tell, this is an open thread untill I get more dinero to finish this up anyway.
A buddy of mine with an '01 TJ, D44, ripped his driver side bracket right off the frame, and I just happened to be crawling around underneath my '98, D44, yesterday and noticed my passenger side bracket is cracked in two places.
Since you asked.
Mark
www.jeeptubes.com
Old 01-08-2008, 06:26 PM   #40
PBR
yeah glad i could help a little bit
PBR is offline   Reply With Quote
Old 01-08-2008, 07:14 PM   #41
GreenJip
[QUOTE=Jeeptuber]
Since you asked.
Wasn't that a stock bracket that ripped? My brackets are 3/16" thick. They are frome M.O.R.E. I don't know that 1/16" is much of a difference, but I am not worried about these brackets or the welds.
/l ,[____],
l---L -OlllllllO-
()_)-()_)-o-)_)
Old 01-08-2008, 08:24 PM   #42
Chris_
He's not talking about your axle brackets. He's referring to the frame brackets.
'02 TJ X Apex Edition
'00 XJ Sport
Chris_ is offline   Reply With Quote
Old 01-08-2008, 10:28 PM   #43
GreenJip
Oh yeah, duh. My mind is not right tonight.
/l ,[____],
l---L -OlllllllO-
()_)-()_)-o-)_)
Old 01-09-2008, 03:31 PM   #44
mjstranz
Anyone else that has run steel wire through cast steel?
GoTime Offroad Club
Old 01-09-2008, 04:26 PM   #45
ErikJordan
Pimp Hand
ErikJordan's Avatar
mine is.
Glock Forum
