#16 | ||
/l ,[____], l---L -OlllllllO- ()_)-()_)-o-)_) 8.8 Swap: http://www.jeepforum.com/forum/f9/8-8-swap-into-tj-build-thread-501704/ |
#17 |
nice build, are you gonna paint it?
-Andrew Low Output 4 Cylinder Jeep Club member #59 [QUOTE=Grewe02]No such thing. Eat **** and die.[/QUOTE] lifted with some extra's ......sold |
#18 |
Now for the brake work. The TJ uses a combination T-Fitting / Breather tube. I started to go this route, but found out quickly that I would have a difficult time setting up the hard lines like this. So, I used the original breather fitting on the 8.8 and drilled a 25/64" hole between the track bar mount and pumpkin. Then I threaded the hole with a 7/16" - 20 tap.
![]() For the T-Fitting, I used one that mjstranz had around. Its a stainless braided line. I don't know where he got it, maybe you can ask him. On top of the pumpkin there is a brake line retaining clip. I removed that bolt and again drilled the hole out with a 25/64" bit then threaded it with a 7/16" - 20 tap. I then secured the T-Fitting with a 7/16" - 20 X 1" bolt. In this pic, you can also see where I ground down the speed sensor so the sway bar would not hit. ![]() Before I ran the hard lines, I put everything on the axle (carrier, axles, diff cover, rotors, pads, calipers and the two passenger side hoses mentioned in the parts list) I used zip ties to hold the hoses in place so I could figure out how I wanted to run the hard lines. Diff Cover (Cheap on E-Bay) ![]() Driver Side ![]() Passenger Side ![]() I will probably splice some tubing to protect the brake line where it rubs the caliper. I also need to figure out the best way to weld some mounts for the brake line ends. If anyone has some ideas for this, I would greatly appreciate it. My first thought is to just weld some nuts to the tubing.
/l ,[____], l---L -OlllllllO- ()_)-()_)-o-)_) 8.8 Swap: http://www.jeepforum.com/forum/showthread.php?t=501704 Last edited by GreenJip; 01-03-2008 at 09:56 AM.. |
#19 |
Routing the hard lines proved to be a PITA for me. Maybe someone else will have better luck. At first, I wanted to cut and flare the lines to perfect length, but everytime I flared an end, it looked really bad. So I gave up and just used 30" lines with the 3/16" fittings. The Drivers side looks pretty good. The passenger side has an extra loop in it to make up fior the extra length. I will probably redo it later, because I hate the way it looks.
Hard Lines I Used ![]() Drivers Side ![]() Passenger Side ![]()
/l ,[____], l---L -OlllllllO- ()_)-()_)-o-)_) 8.8 Swap: http://www.jeepforum.com/forum/showthread.php?t=501704 |
#20 | |
The first thing I did was tear the axle back down, put the old diff cover on and capped the ends to keep water out. I also plugged that breather tube with that 7/16"-20 bolt. I used some Purple Magic to clean any grease and metal shavings off and let it dry in the sun. ![]() After it dried, I hit it with some primer to help hold the paint. ![]() Last, I finished it up with a coat of black. I thought that the cap indicated flat black, but it dried glossy. Oh well, I can always go back over it before the final install. ![]() This process took awhile, because I had to wait 30 minutes between coats. I have two coats of each. Then I let it dry for an hour before I moved it in the garage. Thats it for now. I am just waiting to get a welder lined up and have to save some hard earned cash for the other stuff I mentioned. I will post pics as progress continues, but for now the money train stops here!
#21 |
Looks like some good work, and like you are doing everything right THE FIRST TIME. Any plan for a locker in the rear? I went with 4.88s when I went with the 8.8 (4cyl) and welded the rear....but, if you are gonna use it as a DD i wouldnt suggest that. Again, nice work.
Jus Kiddin...but not really Travis |
#22 |
The axle is looking good. I'm glad you finally got to work on it. I will have to come by after work this week and check it out. My front axle should be ready tomorrow. Hopefully we can get it in soon and get out on the trails.
#23 | ||
#24 |
Spool it!!! I did. The brake lines are from polyperformance.com and are poly performance made, and DOT legal.
44/9 build :)FullWidths:) http://www.jeepforum.com/forum/f9/college-kid-44-9-swap-470448/ Stuff for Sale lots of stuff. http://bb.tennesseeoffroad.com/ubb/ultimatebb.php?ubb=get_topic;f=8;t=016824 GoTime Offroad Club
#25 |
What is your CV drive shaft length?
'02 TJ X Apex Edition '00 XJ Sport |
#26 | |
#27 |
Got any more work done dude?
44/9 build :)FullWidths:) http://www.jeepforum.com/forum/showthread.php?t=470448 Stuff for Sale lots of stuff. http://bb.tennesseeoffroad.com/ubb/ultimatebb.php?ubb=get_topic;f=8;t=016824 GoTime Offroad Club
#28 |
you and your friend should pick up a few more 8.8's at the junkyard, weld up the brackets and sell them on here
the work looks great
Click here --> - Buy popular magazines at discounted price, help my daughter for school DIY jeep highline guide -> click here DIY highline guide Save up to 40% off at advance auto parts by buying online, pick up at store free! |
#29 | ||
#30 | |
to tell the difference between cast steel and cast iron is if its cast steel there will be metal shaving if you drill a little hole some where if its cast iron drilling a hole it will be dust |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
