8.8 Swap Brakes Question - JeepForum.com
post #1 of 6 Old 09-05-2012, 12:23 AM Thread Starter
Superfuman
So I picked up an 8.8 with drums for $50 today. It has drums. I know everyone says to get the disk 8.8 blah blah. I figure they're bigger than d35 drums, whatever. Anyways:
Do I need all the same brake lines as if I were doing a disk 8.8 swap. Or will my d35 hoses fit the 8.8? Same with the ebrake cable? I searched for this up and down, and got nothing but disk swaps, so I thought I'd ask.
2000 TJ - JB Headers FM Super 44. RC 3.25'' on 31s.
Superfuman is offline
post #2 of 6 Old 09-05-2012, 01:07 AM Thread Starter
Superfuman
Nevermind. Finally found my answer. Woop woop!
post #3 of 6 Old 09-05-2012, 05:05 AM
--chris--
--chris--'s Avatar
So whats the answer?
--chris-- is offline
post #4 of 6 Old 09-05-2012, 10:12 AM Thread Starter
Superfuman
Sorry. TJ lines and ebrake should hook right up to 8.8 drums.
post #5 of 6 Old 09-05-2012, 10:18 AM
brplatz
For some reason I thought the drum 8.8s were 29 spline and the discs, 31 splines?
The Second Amendment is in place in case they ignore the others.
That's like saying you wish your boyfriend was a bit less gay.
MOΛΩN ΛΑΒΕ
brplatz is offline
post #6 of 6 Old 09-05-2012, 11:06 AM Thread Starter
Superfuman
No, all 8.8 s from exploders(except those goofy truck like versions) use 31 splines. The ranger 8.8 used 28 or 29 splines and had drums.
8.8 , brakes , cables , swap
NEED HELP with mushy brakes after 8.8 swap stratostix YJ Wrangler Technical Forum 6 06-25-2012 06:01 PM
axle swap now no brakes y87j YJ Wrangler Technical Forum 14 01-04-2012 08:48 AM
2006 tj dana 44 rear with disc swap from a 05. Question on brakes treadway47025 TJ Wrangler Technical Forum 8 09-20-2009 07:30 AM
brakes suck after 8.8 swap?? daciuk55 YJ Wrangler Technical Forum 12 04-04-2008 05:22 PM
brakes on 8.8 swap blackmax YJ Wrangler Technical Forum 4 06-07-2007 03:55 PM
