8.8 e-brake cables - JeepForum.com
post #1 of 22 Old 01-07-2010, 10:49 PM Thread Starter
goldswim5
8.8 e-brake cables
I'm finally gonna get some ZJ cables to hook up my ebrake. Found some on Napa for a total of 65, and on Rock-auto totaling around 50. I guess it really doesn't matter what brand or anything I get, as long as they are ZJ ebrake cables right? I just want to make sure I don't end up ordering the wrong thing.
2005 Wrangler Unlimited
6 speed, hard top, bone stock
goldswim5 is offline
post #2 of 22 Old 01-07-2010, 10:56 PM
epeck87
i used rubicon tj brake cables. rubicons came with disc brakes in the rear. the cherokee cables will work too and are probably easier to find if ur not buying new
Associates Degree in automotive technology
A1-A8 ASE MASTER CERTIFIED TOYOTA MECHANIC
epeck87 is offline
post #3 of 22 Old 01-07-2010, 11:02 PM
wrangler2007
I believe these will work...and cheaper too...
1994-1998 Jeep Grand Cherokee Parking Brake Cable Crown Jeep Parking Brake Cable 52008904
1994-1998 Jeep Grand Cherokee Parking Brake Cable Crown Jeep Parking Brake Cable 52008905
Other Vehicles:
07 Mustang, Whipple, 465 rwhp, Magnaflow, Hurst , AVIC D3, Spec 3+, BMR CA's, Autometer, FRPP Springs
08 F150 5.4L, Super 40 SIDO, Roush Grille, Edge Evolution, Truxport, 2.5" AS Level, 1.5" AAL, 35x12.5x20 Nitto Trail Grapplers
wrangler2007 is offline
post #4 of 22 Old 01-07-2010, 11:15 PM Thread Starter
goldswim5
I actually crawled under my Cherokee a while back thinking of pirating the brake lines off it, but they're drum brakes so they won't work. Unless some Cherokee's had discs I'm not aware of?
post #5 of 22 Old 03-09-2010, 10:04 PM
seabass2020
So, parking brake cables to a wrangler with disk brakes is a direct swap for the 8.8?
seabass2020 is offline
post #6 of 22 Old 03-09-2010, 11:09 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Yes they are a direct swap. Any TJ with rear discs from 03 to 06 will fit perfectly as will the ones from a Grand Cherokee in the ZJ flavor which was from 95 to 98 that came with discs as standard equipment. Rear discs were optional in 93 and 94 on the GC.
I am Savvy
blackmagicbrakes.com
mrblaine is online now
post #7 of 22 Old 03-10-2010, 08:43 AM Thread Starter
goldswim5
Thanks for clearing that up Blaine, I didn't know the Wrangler cables would work too.
post #8 of 22 Old 04-05-2010, 08:12 AM
Lasher
I have an 8.8 out of a 2000 Explorer. I bought the cables noted above but they did not fit. They fit on the jeep side but would not work on the axle side. On the axle side it has a hook instead of the catch for the cylinder type end. I was going to make a loop in the end of the cable and cinch it but wasn't sure if it would fray the cable over time or make it to short causing the brakes to drag. Is there another cable that will work or a safe way to modify the ones above to fit?
Lasher is offline
post #9 of 22 Old 04-05-2010, 08:22 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
If you're referencing the Crown parts in the link above and they don't work, it's because Crown has the parts incorrect for the application. There were no drum brakes on the Grand Cherokee in the years listed in the description of the parts. So, they have the part wrong and need to fix it.
I am Savvy
post #10 of 22 Old 04-05-2010, 08:26 AM
99TJSahara
FORD 8.8 TJ ADAPTER E-BRAKE CABLES
-Joey
04 Grand Cherokee Overland
-sold
99TJSahara is offline
post #11 of 22 Old 04-05-2010, 08:30 AM
Lasher
The brakes I have are disc and I am referring to the e brake cable. Is there another cable that you know of that has the elongated hoop type connector on the end that works for the 8.8? What i am asking is there a stock type cable that will work for this application or would I have to modify one? Thanks for the help.
Lasher is offline
post #12 of 22 Old 04-05-2010, 08:31 AM
Lasher
Thanks 99TJ.
Lasher is offline
post #13 of 22 Old 04-05-2010, 08:45 AM
Lasher
So I found the one on Napa that might work.
Store Locator | NAPA Online P/N UP 95342
Store Locator | NAPA Online P/N UP 95547
Will these work?
Lasher is offline
post #14 of 22 Old 04-05-2010, 08:54 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
I've already answered this once in this thread- Again-
You can get the cables from the 94 ZJ as long as you specify rear discs.
Since you didn't get it the first time, parking brake cables from the following have the ball end at the tub and the rectangular loop at the axle AND the return spring and are a DIRECT SWAP as in PLUG AND PLAY as in NO MODIFICATIONS NEEDED.
03-06 TJ Rubicon
03-06 TJ with rear discs
94 Grand Cherokee with rear discs (you have to specify discs as drums were standard that year)
95-98 Grand Cherokee ANY as all had rear discs
If you have extended your wheelbase and need longer ones, any rear parking brake cables from an Unlimited will also work.
I am Savvy
post #15 of 22 Old 04-05-2010, 09:09 AM
Lasher
Now that makes more sense. Where I was getting lost was on the difference between the drum and disk on the ZJ. All I had to compare to was the cables on the D35. I assumed the mechanism was different on the ZJ and thats why they used the barrel ends. I wasn't asking for the disk break version when I bought the parts. I am not a mechanic by any means. But I did work on fighter Jets in the Navy so I have an understanding of how things work. Thanks for the more Brake Cables for Dummies explanation.
Lasher is offline
8.8 E brake cables BCJEEP TJ Wrangler Technical Forum 3 10-29-2007 04:22 PM
E-Brake cables docneon YJ Wrangler Technical Forum 9 07-06-2007 08:49 PM
Need help with E-brake cables for 8.8 in YJ k12lts YJ Wrangler Technical Forum 5 06-18-2007 03:30 PM
XJ D44 and E brake cables Blackhole TJ Wrangler Technical Forum 5 03-14-2006 07:11 AM
E brake cables?????? wml52 TJ Wrangler Technical Forum 1 03-25-2003 02:19 PM
