8.8 Build up questions - looking or some advice - JeepForum.com
post #1 of 4 Old 04-15-2005, 09:24 PM Thread Starter
BNovak
BNovak's Avatar
Ok, so I picked up an 8.8 from my local upullit today. $350 with brakes and even had the wheel spacers on it!
It's a 3.73 with an LSD, but the gears are gonna go. The axle had 96K original miles on it.
I figure before I install it I was going to tear it all down and rebuild anything that might need it. Anyone have any suggestions on what to do?
Here's what I was thinking
1 - ditch the factory cover and replace it with something beefy
2 - Lockers - Thinking ARB front and rear, so that's a no brainer.
3 - axle shafts - anyone know if the "Lincoln / Mercury" alloy shafts on Randy's R&P will fit in here or any other ones that are out there to make it a bit stronger?
4 - Bearings, seals, etc. Does anyone know if there is a master rebuild kit availabel that has everything in it?
Thanks guys! I'm going to tack weld the tubes to the housing tonite so that's out of the way, and tomorrow is cutting off the factory brackets. Yay
'97 Forest green. ~6" total lift, 8.8, etc. 36" TSL's, winch. You get the drill.
BNovak is offline
post #2 of 4 Old 04-15-2005, 11:32 PM
JSBlu974X4
well you need a diff cover cuz the stock one sucks, ARB yes. axle shafts not sure, make sure its 31 spline, was it out of a explorer?
2005 Unlimited Rubicon Hard N Soft Tops, Clayton Long Arm on RE Coils, Warn Bumper/Tire Carrier, Warn Winch N Bumper, Currie Steering, JKS Quicker Disconnects, JKS Front Trac Bar, Bilsteins, CO2 System..Yada Yada Yada
JSBlu974X4 is offline
post #3 of 4 Old 04-16-2005, 07:43 AM Thread Starter
BNovak
BNovak's Avatar
Yeah it's out of an exploder so it's a 31 Spline. I'll probably put a PSC rock ring on it for a diff guard.
Just need to find shafts and gears for it. Would like to do 4.88's but the only thing I could find was Reverse cut.
-BN
BNovak is offline
post #4 of 4 Old 04-16-2005, 08:50 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
There's tons of options for 4.88 gears for an 8.8. Are they just out of stock everywhere?
Also, keep in mind you'll need to run a modified cross-shaft pin or grind down the ring gear to run that low of gears.
You can get a nice set of axle shafts from Moser. But why not run the stock Ford shafts? They're plenty strong for most applications.
Wheelin98TJ is offline
02 Sahara Build, Advice Florida_Model TJ Wrangler Technical Forum 2 09-23-2009 11:39 AM
Build advice for a high-line type build The Rat YJ Wrangler Technical Forum 1 02-11-2009 02:21 PM
I've decided on a build.... any advice? Axl Jack YJ Wrangler Technical Forum 3 09-12-2008 02:30 PM
Ha, nearly done. One ton build. I have morer questions/advice Swampwalker3 YJ Wrangler Technical Forum 19 12-03-2007 05:34 PM
New Build and needing Advice Extreme_Jeep TJ Wrangler Technical Forum 28 02-13-2005 04:17 PM
