8.8 Brake question - connecting to the exisiting hard brake line? - JeepForum.com
post #1 of 3 Old 06-10-2005, 02:13 PM Thread Starter
BNovak
BNovak's Avatar
I thought I saw somwehere that the WJ brake lines work or something like that to connect to the main fitting on the frame and then down to the "T" on the axle.
Anyone know what I'm talking about? I've got all the mounts welded on, just need to figure out these brakes before going BACK to the auto parts store.
-BN
'97 Forest green. ~6" total lift, 8.8, etc. 36" TSL's, winch. You get the drill.
BNovak is offline
post #2 of 3 Old 06-10-2005, 02:22 PM
ryanrod
look at this
http://7slotgrille.com/tech/8.8/8.8.htm
and this
http://home.earthlink.net/~jetmanjay/id6.html
97 TJ 2.5L, 5 speed
4" Procomp Stage 2 lift w/ trac bar
33" Xterrains on Xtreme Alloys
Airaid Intake, Gibson Exhaust, Badass Stereo
RE rear trac bar, RE rear Control arms
Ford 8.8 axle in the rear
ryanrod is offline
post #3 of 3 Old 06-10-2005, 02:25 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
I just used 2 passenger side Explorer lines.
This gives you the necessary fittings to run the hard lines to the stock T fitting.
Wheelin98TJ is offline
How to replace hard brake line on frame rail seabass2020 TJ Wrangler Technical Forum 10 05-04-2011 08:57 AM
Need to Fabricate new hard brake line. What do I need? slate210 TJ Wrangler Technical Forum 3 08-26-2008 08:55 AM
Front brake line size-Hard line?? learfxr YJ Wrangler Technical Forum 4 07-14-2007 07:24 PM
Removing Brake hose from Hard brake line?? chupacabrah YJ Wrangler Technical Forum 11 03-19-2007 02:29 PM
Brake line and E-brake Question vdubstreets YJ Wrangler Technical Forum 43 12-28-2005 07:02 AM
