8.8 bracket weld locations… - JeepForum.com
post #1 of 3 Old 06-09-2003, 09:43 AM Thread Starter
TJSilverSport02
TJSilverSport02's Avatar
After searching and gathering info on the 8.8 axle swap I plan on doing I have a question about welding the brackets at the “neutral position”. Does this mean parallel to the ground once the correct pinion angle is set to the T/C?
Or is it best to level the pinion and the brackets then weld and use CA’s to adjust axle to T/C.
Does the M.O.R.E bracket kit happen to include measurements on where to locate the hardware on the axle? (Anything to save a little time helps!) Cant’ seem to get a hold of them right now from work phone.
Has anybody had any luck contacting this outfit about their ready to bolt in 8.8’s?
8.8 ready to bolt in!
Thanks for the help, Tom
Stroked/RELA/ARBs/etc,etc...
TJSilverSport02 is offline
post #2 of 3 Old 06-09-2003, 09:51 AM
Owen
Owen's Avatar
Re: 8.8 bracket weld locations…
I got some quotes from them...it was more expensive than the d44 that I found...I didn't want a ford axle under my jeep to be honest...I hate ford with a passion so I went with the d44...I can't remember the exact price but I emailed them and got a rather quick response.
Smuggler Re-Born.....
Owen is offline
post #3 of 3 Old 06-09-2003, 10:40 AM
dzp
dzp's Avatar
Have you checked Stu's site? He has some excellent info there
http://www.stu-offroad.com/otherwrit.../8.8axle-1.htm
Tyler, Texas
97 TJ, Red, 33" MTR's, Locked F/R, D30/Ford8.8, JKS Disco's, DT3000's, tinted Sailcloth top, 8k Ramsey, Custom bumpers/armor, Ramps 890 on 25degree ramp.
dzp is offline
Weld in Motor Mount Bracket jvandy98 TJ Wrangler Technical Forum 3 11-03-2009 02:23 PM
Tie Rod bracket weld broke driving to grocery store. *pics* DeepSky JK Wrangler Technical Forum 28 09-19-2008 12:14 PM
8.8 bracket locations goldswim5 TJ Wrangler Technical Forum 14 05-24-2008 10:13 PM
Bent LCA bracket: replace, weld, bend back? XJeffro TJ Wrangler Technical Forum 7 10-31-2007 06:16 PM
is it ok to tack weld the muffler with J&B weld? losfreddy TJ Wrangler Technical Forum 9 04-02-2006 10:22 PM
