.75" spacers on back...need to put on 2" lift coils...need a good spring compressor?
#1 | |
So I worked on the rear end for about 1.5 hours today. No way in hell was I getting the springs (2" Ruty's Coils) out, much less putting them back in with a .75" spacer.
Am I missing something? I had the shocks undone, and the side of the axle jacked up (tires off of course). There was no way I was getting that sucker out. I went to Autozone to get a spring compressor and the onyl one they had was the one that has just one bolt that goes through the middle of the spring. Anyone know where I can get the one that is used in the famous REBB video with the "Balaniese" song at the end? It's uses 4 bolts on the outside of the spring. BTW....I'm all by myself on this.
#2 |
Was your rear swaybar disconnected?
See it is I who created the blacksmith who fans the coals into flame and forges a weapon fit for its work. And it is I who created the destroyer to wreak havoc; No weapon forged against you will prevail, and you will refute every tongue that accuses you. This is the heritage of the servants of the Lord and this is their vindication from me." says the Lord. -Isaiah 54:16-17 |
#3 |
I found that unhooking the sway bar and track bar (at one end) made the job waaaayyyy easier and I did not need the compressor. Just did the rear for my RE 3.5 springs and did the same thing w/o a compressor. Although I did need it for the front, but just barely.
[CENTER][COLOR=White]97 Sport [/COLOR] 4.0l Auto D30/D35 RE 3.5 SF, 1" BL, 1" MML, 285/75/16 (33") MTRs, 16x8 MT Classic Locks, 4.10 gears, Lockrite Front, Warn Front and Rear Bumper w/ Tire Carrier, Warn Diff Skids, Rock-it Man Rockers, Jeeperman Front Hoop, M8000, A to Z winch mount, Hella 500s, H4 Conversion [COLOR="Red"]Former 3.07 Gears Club Member #1[/CENTER][/COLOR] |
#4 |
tubework is cool...
I did my RE 3.5 springs by myself...with no spring compressors, and without unhooking the track bar...
unhook the shocks and the swaybar links (or quick disconnects)... have the frame on stands with the axle hanging loose...and then use the jack to lift one side up (by jacking on the knuckle)...and you ought to be able to do 2.5" springs and the spacer with no problem... Greg
2001 TJ 60th Anniversary Edition (details in Profile) www.carolinarockshop.com All the pics I have...including a Table of Contents |
#5 | |
the only thing I didn't do was unhook the swaybar. Would tha tmake much of a difference? |
#6 | |
#7 | |
There's your problem. ![]()
Thank you Jesus With all this talk about going "Green" I decided to buy a green Jeep. :) 07 Grand Cherokee Rocky Mountain Edition 4.7 V8 Jeep Green 255/70/17 Bridgestone Dueler A/T Revo's, http://i22.photobucket.com/albums/b3...d/DSCN0296.jpg |
#8 | |
tubework is cool...
Greg
#9 | |
I agree...put a jack under the pumpkin to hold it up, then use another jack on the opposite side your working on to flex the axle a little more...I got my spacers and springs in WITHOUT disconnecting my track bar...front and rear.
2006 [COLOR=Yellow]Solar YELLOW[/COLOR] UNLIMITED-6-Speed -Rusty's 2" spring kit w/Skyjacker Hydro 7000 shocks, 1" coil spacers up front and 3/4" coil spacers in rear, 32" BFG AT KO's on Ravines -Spidertrax 1.25" wheel spacers, Clear Turn Signals and Markers, Custom Front Bumper Hoop with upgraded hooks, Delta 50 Flowmaster, Code Alarm CA-670 Paging-Alarm with Motion Detector, K&N FIPK, JKS Discos, Procomp LCAs, Airaid TBS, Tuffy 055 rear section sub console, 4-Hella 500's, Fumoto Oil Drain Valve, Olympic Reverse-a-bars, Delta Headlight kit with black bezels, Edge Trail Jammer kit, Smittybilt Classic Tire Carrier, WARN Oil Skid, Skid Row steering skid, JKS adj. rear track bar, RC front adj. track bar. |
#10 |
does the sway bar simply unscrew and disconnect? Or do you have to pickle-fork it?
#11 |
for an extra inch or more you can step on the side you're trying to push down.
#12 | |
tubework is cool...
I'm assuming you still have the stock links... takes a T-55 torx bit and a socket (maybe a 3/4"?)...just unbolt them from the brackets on the axle... Greg
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
