7 horsepower? believe it? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > 7 horsepower? believe it?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineCHASSIS SAVER™ Rust Preventive Paint Memorial Day Weekend RuffStuff Memorial Day Sale!
Unread 01-11-2007, 06:35 AM   #1
littleman66
http://www.angelfire.com/my/fan/IAT_sensor.html
2001 60th Anniversary TJ.
2" BB. 31" Goodyear Wrangler MTR's
Dana44 LSD. front Aussie Locker
homemade rear bumper with hitch, two recovery points
dual battery. 1750 watt inverter
Dukes of Hazard/Dixieland horn. Neoprene seat covers
littleman66 is offline   Reply With Quote
Unread 01-11-2007, 06:47 AM   #2
jzmtl
So 4 ftlb more than 200 of stock at 1500 rpm, is that even noticiable?
jzmtl is offline   Reply With Quote
Unread 01-11-2007, 08:25 AM   #3
Elwood
Some people have too much time on their hands.
Elwood is offline   Reply With Quote
Unread 01-11-2007, 09:25 AM   #4
Combatsylvania
wow, thats amazing... probably see the same power to weight increase by taking the back seat out.
Combatsylvania is offline   Reply With Quote
Unread 01-11-2007, 09:27 AM   #5
newbs
Jeepaholic
interesting
newbs is offline   Reply With Quote
Unread 01-11-2007, 10:02 AM   #6
bandit222
so instead of the resistor trick on the same line.. move the sensor itself.. seems like a more involved method of the simple resistor mod. and to have that much 0-whatever info he's probably testing this out all on a gTech or similar device.. no dyno sheet no hp/tq is my motto. cause if it truely put down legit gains someone would find a way to market this mod by now and make a zillion bucks off it!
[COLOR="Blue"][URL="http://www.junkmyride.com/mustang.html"]the [/COLOR]stang[/URL]
[URL="http://www.rottenpuppets.com/"]the puppets[/URL]
bandit222 is offline   Reply With Quote
Unread 01-11-2007, 10:57 AM   #7
BlackWidow TJ
They do make a kit to do this on Camaros and mustangs. I made my own for my camaro but it isn't hard at all.
One ton 04 Rubicon on 42's. 111WB and ready to party!
KEEP PUBLIC LAND OPEN TO THE PUBLIC!!!
BlackWidow TJ is offline   Reply With Quote
Unread 01-11-2007, 11:16 AM   #8
bandit222
i mean one that isnt an obvious radio shack hack job. when you start tricking the comps your just askin for trouble. for 7hp on a jeep? kinda worthless don't you think?
my buddy bought one on ebay like a moron for 30$ for his POS honda. i told him for 1.40$ we could just make it ourself but nobody listens... so after it does nothing we open it up and low and behold.. it's about 1.40$ in parts from radioshack...
Unread 01-11-2007, 11:52 AM   #9
BlackWidow TJ
Yes I meant a kit that you can buy through SLP, Jegs, Summit and such. It boils down to exacly what you said, its a connector for the sensor with extended wires. La De F-ing Da. I saved myself the disapointment and $30 and made my own. If you really beleive its worth 7hp, go for it. If it wasn't worth it in the end your only out $1.50.
Unread 01-11-2007, 12:08 PM   #10
amp77
This idea is really sketchy without dyno sheets of controlled back to back pulls including datalogging of a/f and advance. Who knows what this does to the fuel mix and timing. You'd be far better off in my opinion to buy a programmer and have a decent tuner dial you in a little leaner and advance the timing some. This way the computer can still adjust the tables properly and you can be sure that you will never be too lean and that timing is never through the roof.
For those of you that have already done this, has it thrown any codes back at you and have any of you actually measured a/f ratio and/or timing afterwards?
amp77 is offline   Reply With Quote
Unread 01-11-2007, 12:36 PM   #11
mike_dippert
hodophobic
mike_dippert's Avatar
put the intake manifold in a heat shield. and if the opportunity presents itself, wrap the exhaust manifold in some kind of heat shield material. heat problem solved, and the computer isn't being "tricked".
i tried the resistor trick a couple years ago...my mileage dropped by 3mpg (15-12), so i took the resistor out at the gas station. the next tank i was back up to 15. and i didn't notice any "by the the seat of your pants" power increase.
the same guy has the heat shield write-up too
http://www.angelfire.com/my/fan/manifold.html
You can't argue with ignorance.
Originally Posted by HurricaneRZA View Post
JF taught me that the 2.5L, Ax-5 and D35 together are so powerful that angels weep when I shift into 4LO.
The only thing a bicycle inner tube is good for, is tying a knot in the end of when you run out of condoms.
mike_dippert is online now   Reply With Quote
Unread 01-11-2007, 01:35 PM   #12
TexanTJ
All these mods do is trick the computer into running leaner, therefore picking up maybe a few hp due to the unsafe lean condition. IMO, this is unsafe for the engine and i would never perform a mod like this to my own jeep.
2005 Bright Silver Metallic X- Stolen on May 14, 2012
1988 MJ 2x4- AX15/4.0 ~ 318K miles and going
2006 GTO M6
TexanTJ is offline   Reply With Quote
