60k miles. What to get looked at? - JeepForum.com
post #1 of 2 Old 10-24-2012, 06:22 PM Thread Starter
bjrodriguez
I've had my 2002 wrangler sport for almost 6 months now and I'm coming up on the 60k mile mark. I've read that I need to change the differential and tcase fluids. Is there anything else I should get checked out?
Thanks
bjrodriguez is offline
post #2 of 2 Old 10-24-2012, 06:38 PM
2jhanna
Unless you know the history, along with the front/rear diffs and transfer case, also consider transmission fluid and anitfreeze/coolant, and engine oil and lube zert fittings should go without saying.
Other items to inspect and replace as needed, brake pads/shoes, serpentine belt, hoses, air filter, tires rotate/balance
jhanna
denton county, tx
2jhanna is offline
maintenance , service
