6-Speed Manual Oil Change Help - JeepForum.com
post #1 of 9 Old 11-26-2007, 10:23 AM Thread Starter
BPD119
I just purchased 2 bottles of the royal purple manual trans oil. This would be the first time I tried changing oil in a manual. can someone help me through this. is there a drain plug or anything. thanks
BPD119 is offline
post #2 of 9 Old 11-26-2007, 11:20 AM
JBWood05TJ
Cut to Fit-Paint to Match
JBWood05TJ's Avatar
The drain plug is on the bottom at the rear of the tranny. The fill plug is on the passenger side, toward the rear of the tranny, about halfway up. You need some large allen wrenches to remove these. I THINK a 15mm and a 17mm but I'm not absolutely sure about that off the top of my head. When I get home tonight, if no one has answered that part, I will check and get back to you.
EDIT: The FSM says you need 3.17 pints, or fill it to the bottom of the fill hole. I used nearly four pints and didn't reach the bottom of the fill hole. So if you use all of both quarts and it doesn't reach the fill hole, don't panic, you'll be fine.
We save dogs:
JBWood05TJ is offline
post #3 of 9 Old 11-26-2007, 11:24 AM
TheBoogieman
Made in the USA
TheBoogieman's Avatar
TheBoogieman is offline
post #4 of 9 Old 11-26-2007, 11:27 AM
JBWood05TJ
JBWood05TJ's Avatar
Originally Posted by Theboogieman
That's not the same transmission, though. The 6-speed manual is the NSG 370. I am not sure of the differences between the two transmissions in either size of drain/fill plugs, or fluid capacity.
We save dogs:
post #5 of 9 Old 11-26-2007, 11:38 AM
jeep06
jeep06's Avatar
2015 KL Cherokee
Nsg-370
The filler plug takes a 14mm hex bit socket and the drain plug takes a 17mm. It used the biggest part of two qts. when I changed mine, maybe a pint left over if that. I put a small amount of pipe dope on the drain plug threads to make sure it didn't leak, don't want to over tighten the plug in aluminum. Good luck,, it's an easy job!!
P.S. fill in your profile so we all know what your rig is.
2015 Cherokee Limited (granite) 4x4, 2.4L, 8.4AN, luxury group, wireless charge pad.
jeep06 is offline
post #6 of 9 Old 11-26-2007, 12:18 PM
chutta
solo, I used a squeeze bulb/hose on the jugs to fill. It'd be far easier with 2, one holding a tube in the tranny, other holding the jug, vented.
05x 4.0 6sp 30/35, aussie front, 3.73's, r/c 4"x lift, adv adptr sye, shifter bracket, tw cv ds, 33 t/c skid, 33x12.5 dunlop mud rovers on steelies, psc sport cage/rockers, warn fr bump/steer and 30 diff skid, sirius,cb, hand throttle 1"bl/mml 265/16's pepboys at's on orig moabs for street. Lowrance H20c for gps
chutta is offline
post #7 of 9 Old 11-26-2007, 12:27 PM
Black06X
Just a quick hint... Since the jeep is pretty new you shouldn't run into this problem, but, whenever I change anything with a fill hole and drain hole I always loosen the FILL HOLE FIRST...just as a precaution, because if you drain it first then find out you can't get the fill plug out, you're in trouble! Just a little tip.
2006 X, RE 4.5" SF lift (3.5" springs) AA SYE + Tom Woods CV shaft, SRC Front+Rear bumper+rock guards, Daystar 1" body lift, 32" X 11.50" BFG Muds on American Racing Teflon 15 X 8's, PIAA fogs, On the way: G2 dana 44's front/rear,Trutrac (rear) and ARB (front), OBA, rear disk brake conversion, BFG 35's
Black06X is offline
post #8 of 9 Old 11-26-2007, 02:15 PM Thread Starter
BPD119
thankyou you guys are the best. very good info. and i will work on my profile now haha
BPD119 is offline
post #9 of 9 Old 11-26-2007, 09:42 PM
jeep06
jeep06's Avatar
2015 KL Cherokee
Fill 'er up
I was racking my brains this morning when I wrote my post on what I used to fill the tranny back up. I used a piece of 3/8" clear hose that just slides on the tappered bottle cap. I first slid the hose on the tappered cap to see where to cut it off, then cut off the cap. That way it gives you some options on holding the bottle up when filling the tranny. Hand gets kind of tired squeezing the oil out, but I like that better than cleaning up $$$ oil off the floor.
jeep06 is offline
6 speed manual jlwells TJ Wrangler Technical Forum 20 04-23-2009 08:09 PM
do i have a five or six speed manual?? stoutameyer TJ Wrangler Technical Forum 8 10-03-2008 01:12 PM
Might Swap 6-speed manual for 4-speed auto... JeepinYahoo TJ Wrangler Technical Forum 14 11-15-2006 07:20 PM
Have 6-speed manual swap in a 4-speed Auto? JeepinYahoo TJ Wrangler Technical Forum 8 11-13-2006 03:18 PM
The new 6 speed manual czar97 TJ Wrangler Technical Forum 23 11-10-2004 04:26 AM
