6 spd - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > 6 spd
Stainless Steel Door Hinge PinsPoly Door Hinge BushingsRough Country Jeep Suspension Deals at Rockridge 4WD!
Unread 01-24-2015, 08:12 PM   #1
freckelman
6 spd
So I guess I should have bought the regular automatic lj unlimited instead of the 6spd rubicon lj .Wish I had done a little more research on them.For the people who have replaced the transmission are the the parts a little more stronger than the factory parts? Any info would be great. Fred
freckelman is offline   Reply With Quote Quick reply to this message
Unread 01-24-2015, 08:35 PM   #2
stwilson74
? Why do you say that? Its really mostly a personal preference type decision. Is something wrong with your transmission?
"Betsy" 2005 Unlimited Rubicon Sahara Edition #603 of 1000
[QUOTE=Necromancer_tat;12078965]I like having my panties in a wad though, because when I get DW they rub me in just the right way! :D Wadded panties plus DW equals Jeepgasm! :D :kiss:[/QUOTE]
stwilson74 is online now   Reply With Quote Quick reply to this message
Unread 01-24-2015, 08:38 PM   #3
freckelman
It's constantly popping out of reverse its like a 50/50 shot it will stay engaged.
Unread 01-24-2015, 08:58 PM   #4
Dave02TJ
Dave02TJ's Avatar
Do you have a body lift or have you lowered the transfercase?
Make sure the gearshift lever is not being prevented from fully going into gear.
Dave02TJ is offline   Reply With Quote Quick reply to this message
Unread 01-24-2015, 09:03 PM   #5
aagill225
Of all the miles jeeps see reverse has to be like 1%. I've seen lots of vehicles that don't like to stay in reverse. At least you're not driving across the country in reverse.
Try syncing with a forward gear before dropping into reverse. That helps me a lot. Every transmission has Pro and con. Shift on!! I think manual is the way to go IMO it doesn't matter what manual jeep trans you have they all seem to have very similar issues.
'99 WJ, 4.7L, completely bone stock, except for 245/65/16 tires
'76 Jeep Grand Waggy, 360cid Edle 660cfm/edle intake Quadratrac
'02 Exterra 3.3L, 5-spd, traded YJ for it :(
'89 YJ 2.5L, 5-spd, Borla header, dynomax super turbo muffler, Big-O XT 30x9.5r15
2004 Jeep Liberty Renagade 3.8L 2wd
'86 XJ 2.8L V6, 5-spd manual tranny (My 1st)
aagill225 is offline   Reply With Quote Quick reply to this message
Unread 01-24-2015, 09:56 PM   #6
Travis_
Take a look at your inner shift boot I would have that issue when I replaced it. I just had to manipulate it a little after that all is good.
Travis_ is offline   Reply With Quote Quick reply to this message
Unread 01-24-2015, 10:32 PM   #7
RubiconR6
The synchronizer might be bad. I put a 6 speed in mine and it does that I have not took it apart yet to see in side
RubiconR6 is offline   Reply With Quote Quick reply to this message
Unread 01-24-2015, 11:09 PM   #8
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
No TJ has a synchronized reverse gear...
Edit: I guess some do...
TSB Information: http://www.automd.com/tsb/jeep_m/wrangler_mm/2000_y/
Knuckelhead is offline   Reply With Quote Quick reply to this message
Unread 01-25-2015, 07:35 AM   #9
my996duc1
+1
I used to have some trouble finding reverse but now I can feel when reverse isn't properly engaging by how far the stick throws into reverse.
If it doesn't feel like it is engaging all the way I can throw it into a forawrd gear then usually it will glide right into reverse afterwards.
_
2005 LJ Rubicon Sahara #0090 / MetalCloak'd / Currie 4" Lift with AntiRock / 35x12.50 GoodYear Kevlars / UCF skids
My build : http://www.wranglerforum.com/f5/rubicon-sahara-build-chronicles-328649.html
my996duc1 is offline   Reply With Quote Quick reply to this message
Unread 01-25-2015, 07:45 AM   #10
98TJcomeonuh
Originally Posted by my996duc1
+1
_
Same here. I always just put it in neutral let off the clutch, press the clutch again and it glides into reverse. It rarely does it, but when it does that's what I do.
98TJcomeonuh is offline   Reply With Quote Quick reply to this message
Unread 01-25-2015, 08:27 AM   #11
RubiconR6
I didn't know that. Thanks for the information. I have mine out about to take it apart is there any need to look inside or is it just one of them things
Unread 01-25-2015, 08:58 AM   #12
jjvw
jjvw's Avatar
I'm curious now. Do any transmissions have a synchronized reverse? How could they when reverse turns in the opposite direction? The only exception might be some heavy equipment that has multiple reverse gears.
'03 Rubicon
jjvw is online now   Reply With Quote Quick reply to this message
Unread 01-25-2015, 10:19 AM   #13
RubiconR6
Here is a link for a reverse sync for the 6 speed
http://www.jeep4x4center.com/mopar-r...5134498aa.html
Unread 01-25-2015, 10:58 AM   #14
dustymc
orly?
dustymc is offline   Reply With Quote Quick reply to this message
Unread 01-25-2015, 11:01 AM   #15
jjvw
jjvw's Avatar
I don't understand. What does it synchronize to? Does a reverse synchro help bring the transmission to a stop before spinning in the opposite direction?
'03 Rubicon
