6" inch lift - Need upper control arm length - JeepForum.com
post #1 of 3 Old 11-27-2005, 03:11 PM Thread Starter
fisher836
fisher836's Avatar
I ran a search for this on the forum but it wouldn't work for me. i know it's had to have been posted before. I have dl vibrations. I'm currently at 6" lift with stock uppers. I was thinking about making a pair of upper control arms and was wondering if anyone had the rear upper control arm length of a TJ with 6" lift. either that or know of anywhere i can get a pair for less than $160. Those are the cheapest I've found.
Definition of Rubicon:
A limit that when passed or exceeded permits of no return and typically results in irrevocable commitment.
fisher836 is offline
post #2 of 3 Old 11-27-2005, 03:22 PM
Lefty
Just get a set of adjustables.
Lefty is offline
post #3 of 3 Old 11-27-2005, 04:28 PM
redrock4x4
redrock4x4's Avatar
Upper control arm length is unique to every Jeep, you don't want to ask what someone else is running.
If you make your own, you will want to remove your upper arms, jack up the pinion to where you want it, and build them to fit.
redrock4x4 is offline
Rear upper control arm length dodgetk81 TJ Wrangler Technical Forum 7 08-01-2011 10:22 PM
Lower control arm length question on RC 4" X lift dmgiff TJ Wrangler Technical Forum 9 06-15-2009 09:15 AM
adj upper rear control arm length? RJV TJ Wrangler Technical Forum 3 03-14-2009 05:59 PM
Front Upper Control Arm Length P89Jeeper TJ Wrangler Technical Forum 1 10-09-2007 03:09 PM
Upper Adjustable Control Arm-Proper Length? mossimo19 TJ Wrangler Technical Forum 2 05-30-2006 10:13 AM
