6 inch to 4 inch lift - JeepForum.com
post #1 of 4 Old 12-19-2011, 08:31 AM Thread Starter
limeking
My cousins Jeep is running the 6 inch short arm Junk from Rough Country. I have 4 inch springs, The shocks came with the kit but are to short and will work with the 4 inch springs. It has a drop pitman arm and a trackbar drop, my question is can I drop to 4 inches and still use those drops temporarily until they are replaced with better parts?
If there wasn't stuff that sucked, how would we know what was cool? Beavis and Butthead
Jeremy : )
2004 Lime Rubicon, NV3550, JKS arms, and trackbars, UCF tummy tuck, LoPro and engine skid, 3 in tera springs 33 KM2s
1994 Red Wrangler, 2.5 in lift, 31 in no names, 4.0 ax15 30/35
limeking is offline
post #2 of 4 Old 12-19-2011, 08:46 AM
Dannn
I'd say you could just grab a stock pitman arm because they are cheap, throw that on and remove the track bar drop bracket. but then again i could be wrong and at 4" with everything dropped you might still have your track bar and drag link in line.
1998 TJ - 6.0 Vortec LQ4, 35's, Wheelies and Hurt Feelings Galore.
Dannn is offline
post #3 of 4 Old 12-19-2011, 09:39 AM
loaderopp
A drop to 4 inches from 6. Should be okay. But take a good look at your axle center. you may need to adjust your track bar. 2 inches will want to push your axle out from center.
you will also need to check for contact clearance between axle,steering and frame and re-adjust the toe in-out
Built not bought!!!
2005 Rubicon Unlimited, 5.5 inch custom long arm, 1 inch daystar body lift, River Raider Snorkel, Custom bumper/winch mount, sliders, tire carrier. 37x13.50 R17 Nitto Mudgraplers, Bushwacker flat fender. Custom 1/2 cab. Hyline hood vents. Custom tonnue cover and tool box. HID-X off road lights, LED driving lights custom rear bumper/m6000 rear monted winch.
loaderopp is offline
post #4 of 4 Old 12-19-2011, 10:57 AM Thread Starter
limeking
I would remove them both but he has to save money for a new front track bar since without the bracket it cannot bolt to the stock location. The whole supension is all outta wack, the track bar was to short anyway, for 6 inches, really wanna get it less squirly and better ride cheaply, then he can save to buy quality suspension parts, instead of peiceing together stuff.
Jeremy : )
limeking is offline
2 inch spacer lift vs 4 inch suspension lift and Death Wobble BadKarma1701 TJ Wrangler Technical Forum 37 03-10-2011 07:00 PM
1 inch body lift, 3/4 inch front spacer, 33's? vanner77 JK Wrangler Technical Forum 5 08-17-2009 02:38 PM
4 inch Suspension Lift 2 inch body = Slip Yoke/Driveshaft? ECUSAE20 TJ Wrangler Technical Forum 11 05-08-2009 10:12 PM
2003 rubicon: 1 inch body lift and 2 inch coil spacer lift. tire size? Bobski TJ Wrangler Technical Forum 6 10-05-2008 06:38 PM
Right rear tire extends inch farther out than left after 2 inch lift. blang158 TJ Wrangler Technical Forum 9 07-05-2006 12:15 PM
