6.1 Hemi LJ Madness and Mayhem - Page 8 - JeepForum.com
 1Likes
post #106 of 737 Old 05-13-2010, 11:08 PM Thread Starter
theGiantPanda
Swap This...
theGiantPanda's Avatar
okay... im off to the summit catalog and poly performance web site... $$$
Originally Posted by CCJ View Post
Jesus. This is what heaven on 4 wheels looks like.
Hospital? What, are you suffering from Overextended Jeepaphelia or something? :)
I've never been poor, only broke. Poor is a state of mind. Broke is a condition brought on by Jeep ownership and a heavy right foot.
2006 Unlimited Redicon Panda Edition
RRI Long Arm...14" Fox CO's Front and Rear...D60 KP Front and D60 FF Rear... 5.38s spooled...40" Maxxis Trepadors...
6.1 HEMI...Atlas 5.1
5.7 HEMI 400 hp TJ Build
6.1 HEMI Ultimate LJ Rubicon Build
2.5 to 4.0L swap and build up
4.0 to 2008 5.3L GM LS in the Taco'd TJ [frame off build].....
My new DD Build, lift, 4.0 motor swap, done in 6 days?....
the new shop...
conversion, parts and wiring systems
shop email....
LIKE US on facebook.....
adding more daily
redrockindustries.net
theGiantPanda is offline
post #107 of 737 Old 05-13-2010, 11:15 PM Thread Starter
theGiantPanda
Swap This...
i love poly performance, left click, right click... ahh solutions... very nice.
the new shop...
shop email....
adding more daily
post #108 of 737 Old 05-13-2010, 11:22 PM Thread Starter
theGiantPanda
Swap This...
tomorrow... swing by the dealer and get a new set of 6.1 exhaust gaskets.. seem to be the best and most suggested ones to use. slide the transfer case back in and check for clearance issues etc before i commit to anything further on the lift bracket positioning, trans xmember etc....
talked with chris at squier the other day, hes working on the wiring harness.
the new shop...
shop email....
adding more daily
post #109 of 737 Old 05-14-2010, 05:03 AM
LuckRider
LuckRider's Avatar
SO what size meats are you planning on running when this is all over? I do love that frame notch for the alternator.
Support Our Troops!
JFI Member #7:
BESRK Rear Bumper, Hella 500s
LuckRider is offline
post #110 of 737 Old 05-15-2010, 03:34 PM Thread Starter
theGiantPanda
Swap This...
man the natives were moving last night... wow.
i am looking at 40x13.5x17s and am still in the great debate over which to choose. kelvar mts, creepys, rockers... i keep bouncing between them.
i want to keep the jeep in as much of a stock exterior appearance [fenders flares] as possible. thats the goal at least.
the new shop...
shop email....
adding more daily
post #111 of 737 Old 05-15-2010, 05:06 PM
LuckRider
LuckRider's Avatar
You can't beat the MT/Rs, plus, they were factory tread (ok.... close enough now that it is with kevlar).
Support Our Troops!
JFI Member #7:
post #112 of 737 Old 05-15-2010, 05:21 PM
NoVaHunter
Just saw this and pitched a tent. Ill definately be camping out to watch this one
Originally Posted by KHoff90 View Post
Has anyone really been far even as decided to use even go want to do look more like?
NoVaHunter is offline
post #113 of 737 Old 05-15-2010, 05:23 PM
LuckRider
LuckRider's Avatar
It is funny, I read the first part and thought something completely different
Support Our Troops!
JFI Member #7:
post #114 of 737 Old 05-15-2010, 05:23 PM
Deacon
Shining Adonis
Deacon's Avatar
I <3 MTR Kevlars.
Deacon is offline
post #115 of 737 Old 05-15-2010, 05:34 PM
NoVaHunter
Double meaning, thats what I was going for
post #116 of 737 Old 05-15-2010, 05:55 PM
Recoil
Recoil's Avatar
1988 MJ Comanche
I thought the high clearance skid was more work for me but with what your running I can see its alot more for you. Its totally worth it though. Before I put my rear coil relocators in Im at 18 3/4" belly clearance running 50% tread 35s Should put me just under 20" after its all said and done. Ill be putting the UCF low profile trans mount on this weekend to help give me a little more room between the trans and the tunnel. It fits now but Its really tight and the tunnel gets hot. Im thinking maybe some high heat dynamat along the tunnel perhaps. You may want to look into the UCF mount as well.
Recoil is offline
post #117 of 737 Old 05-16-2010, 03:12 PM Thread Starter
theGiantPanda
Swap This...
tomorrow i measure all the key spots. where the jeep sits now, is where it sat with the 6" lift and 37s. my objective is to keep it as close to possible to this ride height if not a touch lower.
im stuck with having to fab a transmount. no choice. would love to run a UCF however no way any prefabbed part is working in this scenario. im going to mount the Xmember in the holes it lines up with. im considering 2 options. [1] i have a high perf mustang poly trans mount i can use with a little plate work or [2] using the standard sleeve and bushing type mount with a stand-off.
either way... preference and time. i am as usual begining to over engineer the mount... thinking about what i saw a guy do on pirate with dual sleeved bushings [one on either end and the mount plate between] to spread out the torque load on the mount. im also thinking about a rear mount as well
i beleive the mustang mount will twist less than a singe sleeved set up and the double sleeve would twist less than both.
my biggest issue right now with this portion of the build is the clocking of the factory 241. i have to stuff the transfer case waaaaaayyyyyy up there to clear the HC pan, even with a 1" body. part of me says sell the 241 for 1K and put it towards an atlas 2sp right now.
just empty every pocket...... savings account, paypal account and credit card
the new shop...
shop email....
adding more daily
post #118 of 737 Old 05-16-2010, 04:19 PM
Deacon
Shining Adonis
Deacon's Avatar
I may be interested in the 241...
Deacon is offline
post #119 of 737 Old 05-16-2010, 05:06 PM Thread Starter
theGiantPanda
Swap This...
give it some thought and let me know..... if so i will stop and move on to working on the suspension links and what nots.
the new shop...
shop email....
adding more daily
post #120 of 737 Old 05-16-2010, 06:25 PM
Recoil
Recoil's Avatar
1988 MJ Comanche
yeah I had to clearance the tunnel a little bit for the 241 and the high clearance skid. The linkage is STILL rubbing a little bit so Im going to have to get up there and clearance it a bit more.
Recoil is offline
6.1 , 6.1 liter , engine swap , hemi , motor swap , srt8 , v8
Vacuum Line Madness DThomas YJ Wrangler Technical Forum 8 10-04-2008 05:51 AM
Peugeot Madness sykojeep YJ Wrangler Technical Forum 20 06-30-2008 09:00 PM
Exhaust Header Madness!! bamato YJ Wrangler Technical Forum 9 03-14-2006 09:00 PM
Turn Singal Madness rick95 YJ Wrangler Technical Forum 4 02-10-2005 02:41 PM
Gas gauge madness, can dealer fix? AgentZed TJ Wrangler Technical Forum 13 08-08-2004 06:23 PM
