-   TJ Wrangler Technical Forum (http://www.jeepforum.com/forum/f9/)
-   -   590nm Jeep TJ Build+Life (http://www.jeepforum.com/forum/f9/590nm-jeep-tj-build-life-612930/)
Panici 09-30-2008 02:55 PM
Hey everyone. This is the build thread for my 2004 Jeep TJ.
If you're wondering about the title, it's because 590nm is the wavelength of yellow light ;)
I can summarize my Jeep simply.
It's not really good at anything, but mediocre at many things.
It has poor road compliance (solid axles front & rear), it's loud, gets poor fuel economy.
But it makes up for it by being decent offroad, and fun in the winter (RWD + 5-speed + snow = oversteer).
I seem to be able to fit anything I want in the back cargo area.
It also can pull a small trailer, and has pulled many cars via tow straps.
I've even pushed parts cars/project cars around with my front bumper. How many vehicles can do that without damage?
13/06/15 Update
- I fixed some of the pictures after I recovered the images from cardomain.com.
The rest of this first post is pretty much original from the thread creation in Sept 2008.
I'll start by listing my current modifications, (both big and very small) and then show you the changes my jeep has gone through in the 16 months i've had it.
Links:
I'd just like to note, that everything done to the jeep was done by myself, sometimes with the help of a few friends. All right in my own driveway. :thumbsup:
--Exterior Mods--
  • Fog relay pin bent.
  • Front license plate removed
  • Rear license plate bent around tub
  • Dealer and TJ badging removed
  • Safari Mirrors (Powdercoated) for when the doors are off.
  • IPF H4 Conversion Lenses
  • IPF X51 Fatboy Bulbs
  • SUVLIGHTS.COM HD H4 Harness
  • JKS 1.25" BL
  • M.O.R.E. 1" MML Bombproof mounts
  • Nate's 4x4 Model 1 Front bumper
  • Nate's 4x4 Rear bumper w/ tire carrier
  • Hella Rallye 1000 lights (Wired to OEM switch with a 12ga harness)
  • Half doors
  • Rokmen Frame Tie-ins
  • Mopar Trailer Wiring Harness
  • Hella 500 Fog lights (with 100w Yellowstar bulbs and 12ga harness)
  • Four Cooper ATR 31x10.50x15 tires
  • Colormatched (Solar Yellow) Shackles, Roll bars, RE Twin Tube Shocks
  • Rubicon Express 2" BB
  • Custom 3rd brakelight (14 red LEDs) / 55w reverse light / worklight
--Interior Mods--
  • Husky Liners front and rear
  • Bestop door and tailgate guards
  • Removed visor stickers, windshield frame plastic, dash buzzer, and shift light
  • Factory Rollbar Padding removed, and custom padding installed.
  • Drilled and tapped 8-Ball shifter
  • Quadratec domelight switch
  • Quadratec grab handles
  • LED Interior lights
  • Military 90-degree flashlight
  • Wheelskins leather steering wheel cover
  • JTspotlight LED flashlight
  • RadioShack Handheld CB
  • 2lb Fire Extinguisher
  • Custom switch panel (10 mini switches)
  • Two 50 Cal ammo cans (Containing tools and emergency supplies)
  • 1,000,000 Candlepower hand held spotlight
  • Hardwired Garmin 250W GPS
  • A/C compressor disable switch (2nd switch in my mini panel)
Back Story:
Ever since I was a little kid, i've wanted to go
off the beaten path. Somewhere along the way, I learned of the greatness that is Jeep, and right then I knew i'd eventually have one.
Over two years ago, I started the long hunt for my jeep. I knew I wanted a yellow one, with the 4.0 and 5 speed. After some research i started looking for one with a D44 rear end and 3.73 gearing. You'd be surprised at the lack of selection around here when it comes to jeeps, so I had to settle for the D35 rear end, but all my other criteria were pretty much met.
--Rig specs at time of purchase (May 9th 2007)--
  • Solar Yellow w/dual tops
  • 4.0L I6 w/NV3550
  • D30/D35 with 3.73 Gears
  • 7 Speaker stereo, A/C.
  • 76K Kms. (47K Mi.)
http://memimage.cardomain.com/member...085_1_full.jpghttp://i278.photobucket.com/albums/k...e.jpg~original
http://i278.photobucket.com/albums/k...k.jpg~original
http://i278.photobucket.com/albums/k...3.jpg~original
http://i278.photobucket.com/albums/k...a.jpg~original
http://memimage.cardomain.com/member...085_2_full.jpg
http://memimage.cardomain.com/member...085_4_full.jpg
Now i'm not totally sure when the mod bug bit me, but i'd say pretty much right after I got the jeep. I placed an order with quadratec for a bunch of small, mostly interior things.
Somewhere in there, I made a thread asking how to take the very stuck doors off (:laugh:) and went for my first drive doorless. Shortly after that, I finally got the hardtop off, and the soft top down. :thumbsup:
http://memimage.cardomain.com/member...085_7_full.jpg
http://i278.photobucket.com/albums/k...c.jpg~original
http://i278.photobucket.com/albums/k...q.jpg~original
http://i278.photobucket.com/albums/k...f.jpg~original
http://i278.photobucket.com/albums/k...m.jpg~original
http://i278.photobucket.com/albums/k...u.jpg~original
http://i278.photobucket.com/albums/k...r.jpg~original
http://i278.photobucket.com/albums/k...v.jpg~original
http://i278.photobucket.com/albums/k...2.jpg~original
Also got some flat end caps from the dealer, and did some poser flexing after disco'ing the swaybar.
http://memimage.cardomain.com/member...85_17_full.jpg
http://memimage.cardomain.com/member...85_16_full.jpg
Panici 09-30-2008 02:56 PM
...Continued
The jeep stayed pretty much stock for more then an entire year, while I gathered parts up in the basement, and waited until next spring to start the installs (Except for some free/cheap mods like rollbar padding removal, and spare tire removal in preparation for a new rear bumper) (Pictures: April 17/08)
http://memimage.cardomain.com/member...85_25_full.jpg
http://i278.photobucket.com/albums/k...g.jpg~original
http://i278.photobucket.com/albums/k...o.jpg~original
Until finally some mods started.
May 15/08 - 1.25" JKS Body lift
http://memimage.cardomain.com/member...85_28_full.jpg
http://i278.photobucket.com/albums/k...w.jpg~original
http://memimage.cardomain.com/member...85_32_full.jpghttp://i278.photobucket.com/albums/k...s.jpg~original
May 16/08 - M.O.R.E. 1" Bombproof motor mount lift
http://memimage.cardomain.com/member...85_31_full.jpg
http://memimage.cardomain.com/member...85_33_full.jpghttp://i278.photobucket.com/albums/k...b.jpg~original
http://i278.photobucket.com/albums/k...h.jpg~original
May 28th and 29th 2008 - Got some mild trail wheeling in, and took some poser flex pictures.
http://memimage.cardomain.com/member...85_34_full.jpg
http://memimage.cardomain.com/member...85_36_full.jpg
http://i278.photobucket.com/albums/k...z.jpg~original
http://i278.photobucket.com/albums/k...d.jpg~original
http://memimage.cardomain.com/member...85_35_full.jpg
http://memimage.cardomain.com/member...85_38_full.jpg
Panici 09-30-2008 02:58 PM
Camping
Now comes the fun part. In the space of about a week, after my final highschool exams, and before my camping trip, myself and some friends went crazy on the jeep. I ran out of time, so I had all the painting done at a shop, but I was just going to rattlecan everything.
  • Four 31"x10.50 Cooper ATR tires (GSAs were BALD and I needed tires before camping)
  • Nate's 4x4 front and rear bumpers
  • Hella 500 and Hella 1000 lighting with custom 12ga harnesses and switching
  • Colormatched Half doors, rollbars, and shackles
It turned out that my friend's boat broke, so we ended up wheeling every day for an entire week.
http://memimage.cardomain.com/member...85_39_full.jpghttp://i278.photobucket.com/albums/k...b.jpg~original
http://i278.photobucket.com/albums/k...p.jpg~original
http://i278.photobucket.com/albums/k...l.jpg~original
http://i278.photobucket.com/albums/k...0.jpg~original
http://i278.photobucket.com/albums/k...t.jpg~original
http://i278.photobucket.com/albums/k...x.jpg~original
http://memimage.cardomain.com/member...85_40_full.jpg
http://i278.photobucket.com/albums/k...7.jpg~original
http://memimage.cardomain.com/member...85_45_full.jpg
http://memimage.cardomain.com/member...85_46_full.jpg
http://memimage.cardomain.com/member...85_47_full.jpg
http://memimage.cardomain.com/member...85_49_full.jpg
http://memimage.cardomain.com/member...85_51_full.jpg
http://memimage.cardomain.com/member...85_60_full.jpg
http://memimage.cardomain.com/member...85_53_full.jpg
http://memimage.cardomain.com/member...85_57_full.jpg
We didn't stop often to take pics or vids outside of the jeep, there were bugs everywhere! However I do have some great footage on my YouTube account.
www.Youtube.com/PaniciJeep
Panici 09-30-2008 02:59 PM
...Camping Continued
On the very last day before we left to go home, we got stuck. My first stuck.
I took a line too far to the left where the trail had washed out.
http://i278.photobucket.com/albums/k...S7300300-1.jpg
http://i278.photobucket.com/albums/k...S7300301-1.jpg
Yes we were wheeling alone, but we were taking it pretty easy, being hundreds of miles from home and everything. Luckily my friend's buddy came and gave us a tug with an ATV.
http://i278.photobucket.com/albums/k...IM006540-1.jpg
We got back to camp and stripped most of the interior out, and hosed it off.
We got home uneventfully, and I washed out at least a few pounds of mud from under the jeep. ;)
During August, I mostly just drove around top and doors off.
http://memimage.cardomain.com/member...85_64_full.jpg
http://memimage.cardomain.com/member...85_62_full.jpg
http://memimage.cardomain.com/member...85_61_full.jpg
http://memimage.cardomain.com/member...85_63_full.jpg
Rebb
Over a few days at the end of august, a friend and myself completed a 2" Rubicon Express Budget Boost, and then got some flexing in during september.
http://memimage.cardomain.com/member...jpg?465015-241
http://memimage.cardomain.com/member...jpg?465015-241http://i278.photobucket.com/albums/k...i.jpg~original
http://i278.photobucket.com/albums/k...n.jpg~original
http://memimage.cardomain.com/member...jpg?353721-263
Towards the end of september, I got some maintance done, as well as a few misc mods.
http://memimage.cardomain.com/member...jpg?135119-267
http://memimage.cardomain.com/member...jpg?245419-267http://i278.photobucket.com/albums/k...m.jpg~original
http://i278.photobucket.com/albums/k...5.jpg~original
http://i278.photobucket.com/albums/k...y.jpg~original
http://memimage.cardomain.com/member...jpg?214913-274
August '08
Took the windshield down, enjoying the weather.
http://memimage.cardomain.com/member...jpg?265613-270
http://memimage.cardomain.com/member...jpg?265613-270http://i278.photobucket.com/albums/k...n.jpg~original
http://i278.photobucket.com/albums/k...8.jpg~original
I've had five 33x12.50 Cooper STTs waiting in the tire shop for almost 8 weeks now, waiting on my five Eagle Alloy 187s to arrive off of backorder.
My life.
Eat. Sleep. Jeep :thumbsup:
Panici 09-30-2008 03:01 PM
Placeholder #1
Took some random artsy photos today with the office SLR. (Oct. 1/08)
Full resolution pictures:
http://s278.photobucket.com/albums/k...Fall08/Trip01/
http://s278.photobucket.com/albums/k.../Photoshopped/
http://i278.photobucket.com/albums/k...0004edit-1.jpg
http://i278.photobucket.com/albums/k...0013edit-1.jpg
http://i278.photobucket.com/albums/k...0032edit-1.jpg
http://i278.photobucket.com/albums/k...0063edit-1.jpg
http://i278.photobucket.com/albums/k...69edit_2-1.jpg
http://i278.photobucket.com/albums/k...0080edit-1.jpg
Placeholder #2
Put the hardtop and full doors on this weekend, so I decided to go out and take some pics! (Oct. 20/08)
http://i278.photobucket.com/albums/k...005_ShopSM.jpg
http://i278.photobucket.com/albums/k...021_ShopSM.jpg
http://i278.photobucket.com/albums/k...032_ShopSM.jpg
http://i278.photobucket.com/albums/k...038_ShopSM.jpg
http://i278.photobucket.com/albums/k...043_ShopSM.jpg
http://i278.photobucket.com/albums/k...051_ShopSM.jpg
http://i278.photobucket.com/albums/k...056_ShopSM.jpg
http://i278.photobucket.com/albums/k...073_ShopSM.jpg
http://i278.photobucket.com/albums/k...081_ShopSM.jpg
http://i278.photobucket.com/albums/k...102_ShopSM.jpg
Full Resolution shots here:
http://s278.photobucket.com/albums/k...p03/Photoshop/
Panici 09-30-2008 03:07 PM
Placeholder #3
Custom 3rd brakelight (14 red LEDs) / 55w reverse light / worklight (Oct 28/08)
Today, I finished wiring my rear fog/backup light/3rd brake light :)
It's wired with a 3-position switch in my 10-mini switch panel, that allows me to turn the 55w light on manually, or have it come on automatically with the reverse lights, or disable it completely.
Sorry about the crappy cell phone pictures, i'll take some better ones tomorrow.
http://i278.photobucket.com/albums/k...p/IMG_0156.jpg http://i278.photobucket.com/albums/k...p/IMG_0157.jpg
http://i278.photobucket.com/albums/k...p/IMG_0151.jpg
Reverse light
http://i278.photobucket.com/albums/k...p/IMG_0153.jpg
Work light/Tailgater defence ;)
http://i278.photobucket.com/albums/k...p/IMG_0155.jpg
Summer '09.
Set of five 33x12.50 Cooper STTs
http://carphotos.cardomain.com/ride_...0105_large.jpg
http://i278.photobucket.com/albums/k...p/DSC_0048.jpg
imbezol 09-30-2008 03:21 PM
Nice pictures. How'd you do the one with the transparent hood?
Panici 09-30-2008 03:25 PM
Photoshop ;)
I placed the camera on a flat surface and took two pictures.
One with the hood closed, and one with it open, trying not to move the camera between the shots.
breckboarder55 09-30-2008 04:21 PM
Very nice build sheet so far. Looks like you have planned your mods well. Its clean.
Pick up the wave length of Yellow in a little physics class?
allanmacaulay 09-30-2008 05:48 PM
woot yellow jeep!
i can't wait to get as far as you have, you've made everything look really good.
Panici 10-20-2008 02:25 PM
Bump for new pictures :)
BomberJeep 11-10-2008 08:08 AM
Wish I had a nice area like those here in Va Beach to take some pics
The time now is 04:04 AM.
Copyright ©2000 - 2016, Jelsoft Enterprises Ltd.
