Quantcast 55w Reverse Lamps - Page 2 - JeepForum.com
jeeppartsdept.com
Get your jeep parts here. Full line Jeep dealer. HUGE DISCOUNTS!
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > 55w Reverse Lamps
RUBICON EXPRESS Lift Kits and Accessories Available at BasSpartan Lockers FREE SHIPPING Excellent PricesFree Shipping on TIRES at KrawlOff-Road
Old 03-15-2006, 10:09 PM   #16
bigtar
Junior Member
Originally Posted by BarefootRubi
the jeep's harness isn't up to powering 55w lights. You really don't want to over heat those factory wires, have them melt their insulation & cook your jeep.
I was thinking of splicing the factory reverse light wire into the relay as the reverse switch, but powering the lights off the battery. Will this overload the wires?
Also, what is the function of the dimmer into the switch?
Regards,
Jason
Red Jeep Club Member #109
2000 TJ Sport
bigtar is offline   Reply With Quote
Old 03-15-2006, 10:33 PM   #17
Oman Jeep
even tired you read it right. I wanted them on any time I'm in reverse. The switch is just so I can turn them when i want (mostly when loading my cargo carrier or little trailer)
They have other uses too
Like I said - I don't want them on when cops are around as I don't know if they're legal for me - but I like them when backing into parking spots... they have a habit of putting palm trees and crap in parking spots to make the place look pretty... Didn't notice on one of them one night and by pure luck stopped HALF an inch from the tree. Didn't even know it was there... Now, with the lights, I know what's there
They also work great when someone gets on your bumper ... but again check the rear view mirror for cops first
Also good when someone else needs a tow... but kinda the same as hooking up with the trailer only now you're running with straps and trying to find their tow hooks...
Oman Jeep is offline   Reply With Quote
Old 03-15-2006, 11:58 PM   #18
dougolupski
It's Heep not Jeep
No that won't overload the factory wires at all. SOLONG AS YOU USE A RELAY. I had to make it loud so if some idiot burns his/her jeep down by wiring it wrong they can't blame me.
By the way sweet write up. I know we have a good community here, but that took alot of effort. Thanx.
It's some thing I have been looking at doing for a while. I have been throwing around the idea of rectangle holes in the bumper with flush mounted KC's.
Jeep: 07 Wrangler X 2DR Black
Crime Guard Alarm with 2way pager, AFE CAI, DynaPro Exhuast
M.O.R.E. Body Lift, Source Co2 Tank, Stubbied Stock Front Bumper
KMC XD 795 Hoss Black 17" wheels and Maxxis Bighorn 305/70/17 tires
Every mod in the write up section.
Old Jeep: 04 Wrangler X Yellow Built To The Hilt For Three Great Years.
POLISH JEEP OWNERS CLUB #2
dougolupski is offline   Reply With Quote
Old 03-16-2006, 03:54 AM   #19
jim ellsworth
Very nice set up, thanks for the write up also. Does anyone know the part numbers of the panel switches. My local dealer kills my for big $$$$ for small parts. Or a source on line for the switches? I think it actually gets darker with the factory back up lights. Nice set up.
If your not [B]living on the edge[/B], your taking up to much space.
jim ellsworth is offline   Reply With Quote
Old 03-16-2006, 05:04 AM   #20
bfr
that would be ok. I just used the wire in the mirror harness because of its location.
the factory fog switch hast two bulbs inside of it. One is on anytime the jeep's lights are on. It is the one behind the foglight "symbol" on the switch. This bulb is contolled by you panel dimmer(when you adjust the brightness of your gauges etc.) The second bulb is only illuminated when the switch is depressed. It is what lights the little green indicator.
2004 TJ
bfr is offline   Reply With Quote
Old 05-15-2006, 05:21 PM   #21
heezy101
i finally got around to getting a set of lights and im going to recess them into the rear bumper and wire them as you have in this write-up but......i don't have the the temp/compass on the rearview, you mentioned two other places to splice into the 12v that comes on when you put the jeep in reverse, does anyone have and other info on this, the best place to tap in? the color of the wire im looking for? any info will save me some time when tracing the wires out, thanks
heezy101 is offline   Reply With Quote
Old 05-15-2006, 05:49 PM   #22
crsmith
Nice write-up. I just wired a pair of 55 watt reverse lights as well. I hid the relay in the rear light housing on the left (driver's) side, so that it would be in waterproof location. Being located there, it was easy to tap into the wire going to the reverse light bulb, so that it would trigger the relay which illuminates the two reverse lights. I did a separate 12 volt feed on thick wire, so that there would be no problems. As well, I have a switch which will turn on the reverse lights if I want to use them while standing still; that is also wired into the relay in the tail light housing.
Charles
1985 CJ7 - Dark cherry red with a few mods
2005 Rubicon - Impact orange (The Pumpkin) with some additional stuff
crsmith is offline   Reply With Quote
Old 05-15-2006, 06:01 PM   #23
tjsooley
you could do what i did got some 1156 55w backup bulbs and put them is the stock backup local
[COLOR="Red"]______
l ,[____],
l---L –0lllllll0-
()_) ()_)--o-)_) [/COLOR]
[url]http://www.myjeepspace.com/profile.php?id=653[/url]
tjsooley is offline   Reply With Quote
Old 12-14-2006, 09:10 AM   #24
Combatsylvania
With no relay? Call the mechanic and book an appointment now, woudlnt hurt to give the firedepartment a heads up too,
Combatsylvania is offline   Reply With Quote
Old 12-14-2006, 01:32 PM   #25
Border Dave
I've been using the 55 Watt bulbs for several years now also. So far, so good. By the way, they really don't through any more usable light with the factory housings, but I was just to lazy too change them back to the factory bulbs. Maybe now I'll do this mod and put the factory bulbs back in.
Border Dave is offline   Reply With Quote
Old 12-14-2006, 02:30 PM   #26
Combatsylvania
Theres a great write up on stu-offroad.com about a kid that thought that. He ended up burning out a wire in the harness somewhere.. took weeks and lots of money to find the problem.. i beleive it was 55watt lights he used..
just a friendly warning, thats all.. I like my jeep to much to take that gamble.
Old 12-14-2006, 03:54 PM   #27
Border Dave
I think I'll do a little experiment. I'll put one of the stock bulbs back in tonight and take a comparison photo of one stock bulb and one 55 watt bulb while in reverse. I'll post the photo here tonight. I'm pretty sure you won't notice much of a difference. I will be putting the other stock bulb back in after I take the photo.
Old 12-14-2006, 04:23 PM   #28
IWantAGladiator
Nice write up! Its my next project.
I used the same switch to toggle my w/s mounted lites, and damn if the green LED doesnt come on when the lites are off, and vice versa. But it was the only way to wire the switch to "glow" when the dashlites were on. Gotta fix it... but any time you can keep the oem look, well done!
IWantAGladiator is offline   Reply With Quote
Old 12-14-2006, 04:25 PM   #29
SpaceWrangler
Gnarly Adventurer
SpaceWrangler's Avatar
Location: Where the Girls Dance Different With Familiar Grace
I have a pair of the small 55-watt lamps from Wally-World flush-mounted in my rear bumper.
"Two things are infinite... the Universe and human stupidity. And I'm not sure about the Universe."
-Albert Einstein
SpaceWrangler is offline   Reply With Quote
Old 12-14-2006, 04:48 PM   #30
Grewe02
Cant edit my user title
Grewe02's Avatar
1980 CJ5
I will eventually do an Auto / Off / On setup when I have enough electrical stuff to warrant a custom switch bank using Contura switches - but for now the PIAA switch only allows for on / off.
Anyone have a wiring write up for something like this? I'll probably stop by Radio Shack sometime next week and ask them.
Andy, KD8EIA
| USN Jeep Hull # 66 | ΜOΛΩΝ ΛΑΒΕ |
| My Jeep's Thread | My Photobucket | San Diego Jeepers!! | VBARC | Military Jeepers |
"Don't take life too seriously, You'll never make it out alive."
"A government big enough to give you everything you want
is a government big enough to take from you everything you have"
- Gerald R. Ford in an address to a joint session of Congress on August 12, 1974
Grewe02 is offline   Reply With Quote
Glock Forum
