Quantcast 5-Speed guys... Are you ready to have some FUN!! - JeepForum.com
jeeppartsdept.com
Get your jeep parts here. Full line Jeep dealer. HUGE DISCOUNTS!
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > 5-Speed guys... Are you ready to have some FUN!!
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGR8TOPS Introduces the Exogate HD Tire CarrierThe Original 3/8" Ruffstuff Diff Cover!
Old 06-23-2007, 10:45 AM   #1
DANSBIRD
The game is: "FIND THE BLEEDER SCREW"
Object: Look through the pictures supplied (i'm new so links will have to do) and see if you can find the bleeder screw for my Jeep. (01 TJ 4.0L 5-Speed)
http://img144.imageshack.us/img144/8051/dsc00910pk7.jpg
http://img464.imageshack.us/img464/4968/dsc00911nc2.jpg
http://img258.imageshack.us/img258/8793/dsc00912vf7.jpg
http://img464.imageshack.us/img464/6913/dsc00914sw4.jpg
http://img258.imageshack.us/img258/1994/dsc00912hs2.jpg
http://img144.imageshack.us/img144/9710/dsc00915kv2.jpg
http://img464.imageshack.us/img464/4088/dsc00917sb7.jpg
If someone would be so kind as to put some image tags infront & behind my pictures, it would be appreciated
Now, See if you can find a bleeder screw or not and if you can, please point it out for verification. Thanks for playing!
DANSBIRD is offline   Reply With Quote
Old 06-23-2007, 11:15 AM   #2
Shrek
Pardon my ignorance, what the heck is a bleeder screw?
97 TJ 4.0, AX15, E-Fan, 5" Full Traction Long Arm - D44s /4:88s, 36" TSL/SX Swampers on Cragar Bead Locks, Atlas ll, Outback Extreme OnBoard Air, Hand Throttle, Homemade Sliders, Homemade Rear Roll Cage, M.O.R.E. High Clearance Bumpers, Currie Currectlync Steering, Currie Anti rock, Warn 9.5XP, OR Fab Sport Cage Up Front, I've lost control.
Shrek is offline   Reply With Quote
Old 06-23-2007, 11:18 AM   #3
Shrek
Are you talking about your Hyd clutch system?
Old 06-23-2007, 11:19 AM   #4
cnt487
x2
I'm not really sure what I'm even looking at. I'm thinking it's down by the transfer case just cuz in one of the pics I thought I saw some linkage?? What are you trying to bleed?? A lil more info as to what your trying to do my help ya out on here buddy!!
cnt487 is offline   Reply With Quote
Old 06-23-2007, 11:22 AM   #5
[ITA]Tsunami
Italian Wheeler in Mexico
[ITA]Tsunami's Avatar
This way should be easyer to play
Originally Posted by mdm
However it is a strange twist in the cosmic thread that will not allow the driver of a Jeep that has experienced air bag deployment off-road to consume beef for 48 hours after the event. You can consume chicken, pork, turkey, or emu.
[ITA]Tsunami is offline   Reply With Quote
Old 06-23-2007, 11:42 AM   #6
dyna
Never had to deal with the clutch slave but I can say the Dodge trucks which are similar dont have a bleeder on the slave, there sealed units from the factory. How to bleed them I couldent say, your supposed to replace the master/slave and line in one shot.
dyna is offline   Reply With Quote
Old 06-23-2007, 12:39 PM   #7
dyna
I just put my 98 on the rack and on top of the slave in back is a allen head bleeder screw down in the plastic casting cog, pick out the mud and you`ll see it if its the same.
Old 06-23-2007, 01:57 PM   #8
DANSBIRD
I'm just trying to bleed the clutch... Was told to try that before replacing the master/slave cylinder.
Old 06-23-2007, 02:48 PM   #9
BlackJeephunter
It is a sealed unit. You are better to get the whole thing, slave, lines, M/C all in one and install it that way. My 98 manual calls it a sealed system.
Palmetto Tree Stickered Black Jeep Owners Club, Hunting Chapter Member #1110010
BlackJeephunter is offline   Reply With Quote
Old 06-23-2007, 05:57 PM   #10
DANSBIRD
well, don't that just suck. Great! I wonder how much the whole unit will run me.
Old 06-23-2007, 06:25 PM   #11
DANSBIRD
I'm curious... if its a sealed unit and you just replace the slave/MC all at one time, how do you bleed it once its in there?
Old 06-23-2007, 08:04 PM   #12
BlackJeephunter
I believe it comes filled and ready to go.
From the 98 manual
CLUTCH HYDRAULIC LINKAGE
The clutch master cylinder, slave cylinder and connecting
line are serviced as an assembly only. The
linkage components cannot be overhauled or serviced
separately. The cylinders and connecting line are
sealed units. Also note that removal/installation procedures
for right and left hand drive models are basically
the same. Only master cylinder location is
different.
Old 06-23-2007, 09:16 PM   #13
97JPTJ
yea its a sealed unit, it comes filled and ready to go...i bought one about 6 months ago from the dealer...i cant remember what the price was but i think it was around 230 bucks.
97 TJ Sport 5 speed, 4" ProComp lift, 33" ProComp Mud Terrains, 9000 lb Milemarker winnch, ARB Snorkel
97JPTJ is offline   Reply With Quote
Old 06-24-2007, 12:03 AM   #14
KINGZ
I just replaced the slave cylinder on my camaro a few months ago. It did not have a bleeder screw, first time I have ever seen one like this, and like an fool I had to dig in the trash for the instructions after I installed it, lol
what I had to do was hook all the lines up, but not the hard linkage, tilt the slave cylinder at 45deg, and move the shaft back and forth on the slave cylinder slowly a few times. Wile someone above looking at the reservoir to let you know when the bubbles stop. Once the bubbles stop, pump it a few more time, with the slave cylinder pushed in, close the reservoir, and hook everything up.
Remind you this was on my camaro not my jeep, the old slave cylinder had a bleed screw. as for price my camaro at the dealership was $180, at advance autoparts $115, since I use my friends commercial accounts the price was about $55. best bet is find someone with a commercial account they only pay 10% over cost from select autopart stores.
KINGZ is offline   Reply With Quote
Old 06-24-2007, 12:10 AM   #15
killas1mo
Originally Posted by KINGZ
I just replaced the slave cylinder on my camaro a few months ago. I did not have a bleeder screw, first time I have ever seen one like this, and like an fool I had to dig in the trash for the instructions.
what I had to do was hook all the lines up, but not the hard linkage, tilt the slave cylinder at 45deg, and move the shaft back and forth on the slave cylinder slowly a few times. Wile someone above looking at the reservoir to let you know when the bubbles stop. Once they stop pump it a few more time, with the slave cylinder pushed in, close the reservoir, and hook everything up.
X2 on the guy above. I replaced my slave the same way in my 97 TJ. It can be done but you have to fill the slave all the way up with fluid and connect it all up but not bolt it to the bell housing. Then pump up the slave by hand (not the clutch) until the bubbles stop coming out of the master. Add fluid if you need to and slap the cap back on. Your ready to go after bolting it to the bell housing!
97 TJ 4.0 5 speed
4.5" RE + 1" BL
33" BFG M/T's (going to 35" tires after 8.8)
Milemarker PE 8000 winch
Aussie in D30, damn D35 out back (8.8 time!)
killas1mo is offline   Reply With Quote
Glock Forum
