5.3L Vortec and 4L60E swap!! - JeepForum.com
post #1 of 86 Old 08-26-2007, 06:48 PM Thread Starter
UTIJeeper
Well here we go. I started my swap today. I got the 4.0L and ax-15 ready to pull tomorrow....4.0L and more for sale...check my thread on that. Here are some pictures
Wheelin'
UTIJeeper is offline
post #2 of 86 Old 08-26-2007, 06:50 PM Thread Starter
UTIJeeper
sorry about the image quality...the forum only allows 100kb....worthless lol
Wheelin'
post #3 of 86 Old 08-26-2007, 07:12 PM
TXjeepTJ
TXjeepTJ's Avatar
awesome man, what kind of hood do you have? i see 4 hood vents
LS1 powered TJ
C6 Z06 Corvette
TXjeepTJ is offline
post #4 of 86 Old 08-26-2007, 07:21 PM
Elwood
Elwood's Avatar
2016 JK Wrangler
I would LOVE to have a 5.3 in my Jeep. That is one of the best modern engines out there. Keep us posted on how it works out for ya!
A quote from my wife: "I don't even want to know how much it cost, I'm not in the mood to be that pissed off today."
Elwood is offline
post #5 of 86 Old 08-26-2007, 07:25 PM
cincytj
cincytj's Avatar
good luck with it. I would plan on removing the winch front buper and inner fenders, working around them will be 10 times more work than removing them. I wish I had removed my fenders when I did my swap.
03 Patriot Blue Sport
Rubi d44 both ends, Crane Diff Covers, Rock trac t-case
Tom Woods CV DS, Alloy USA rear axles (waiting for install) ARB front bumper, Rock-it-Man Rockers
knoblock rear bumper, OBA in process,
bestop tire carrier, 35-12.5-16 trXus MT's on MOABs with 1.25 spidertrax
Currie HD steering
Nth Degree 6" LA kit. Garvin Wilderness Rack w/hi-lift mnt
HEMI & 5spd Auto
cincytj is offline
post #6 of 86 Old 08-26-2007, 07:33 PM Thread Starter
UTIJeeper
Hey....I talked to you thru youtube awhile back about your swap..well here it goes. The hood vents i just put in yesterday...they are sweet..got them from genright. heres the link http://www.genright.com/ProductInfo....uctid=LVR-1009
Wheelin'
post #7 of 86 Old 08-26-2007, 11:26 PM
TXjeepTJ
TXjeepTJ's Avatar
sweet, i will get these. was the install pretty easy? just cut the holes and drop in the vents? how do they stay in there? tape? lol
LS1 powered TJ
C6 Z06 Corvette
TXjeepTJ is offline
post #8 of 86 Old 08-26-2007, 11:28 PM
raskull
raskull's Avatar
They come with color matched pop rivets.
(O|||||||O)
l_l*-----*l_l
Raskull - Metallic Silver '03 Jeep TJ Sport (
<- Write-ups on mods/maintenance/trips and a video/image gallery
raskull is offline
post #9 of 86 Old 08-26-2007, 11:33 PM Thread Starter
UTIJeeper
yah the install was easy..just cut out the holes and rivet them in.
Wheelin'
post #10 of 86 Old 08-27-2007, 12:43 AM Thread Starter
UTIJeeper
what did you guys do about fuel pressure..the 5.3 wants 55psi min and the jeeps pump only puts out 45psi..
Wheelin'
post #11 of 86 Old 08-27-2007, 05:33 AM
spyder6
Got that Toyota chit
spyder6's Avatar
2010
could put in an inline fuel pump somewere on the frame rail, that way it would be easy to change if it burnt up or something
My builds:
and
or follow us on
spyder6 is offline
post #12 of 86 Old 08-27-2007, 10:55 AM
cincytj
cincytj's Avatar
I switched in the 05 pump and tank, I think the pump alone would work though, it looked the same as my 03
Currie HD steering
HEMI & 5spd Auto
cincytj is offline
post #13 of 86 Old 08-27-2007, 04:41 PM Thread Starter
UTIJeeper
What is different about the 05 tank? also i have to run a return fuel line because the 5.3 has a fuel regulator at the rail and send the unused fuel back to the tank...do the newer jeeps use a return system...is that why you used the 05 tank?
Wheelin'
post #14 of 86 Old 08-27-2007, 06:52 PM
cincytj
cincytj's Avatar
the 05 tank gets rid of the return line, it changes the evap system to the newer NVLD which is the same as the 1500 ram. you wont need the tank for yours. I think the 05 pump runs at 58 psi at the injectors
Currie HD steering
HEMI & 5spd Auto
cincytj is offline
post #15 of 86 Old 08-27-2007, 08:53 PM Thread Starter
UTIJeeper
the 05 tank gets rid of the return line. I think the 05 pump runs at 58 psi at the injectors
It gets rid of the return line??? mine is a 97 and it dosn't have a return...Is there any year tj that did have a return.? if so i should get that tank
Wheelin'
5.3/4l60e swap complete, 11.5 mpg!!! lumpster TJ Wrangler Technical Forum 67 04-24-2015 08:10 AM
4.3 MPI and 4l60e trans swap question captainauti YJ Wrangler Technical Forum 5 06-11-2009 04:33 AM
5.3L Vortec and 4L60E swap!! UTIJeeper TJ Wrangler Technical Forum 11 08-19-2007 11:22 AM
1st post Getting ready for a 4.3&4l60e swap brockenshire YJ Wrangler Technical Forum 1 07-26-2007 08:32 PM
LS1 Engine with 4L60E Tranny Swap greatyanks23 YJ Wrangler Technical Forum 17 03-03-2006 04:12 PM
