5.0 engine swap pictures - Page 7 - JeepForum.com
View Poll Results: What do you think?
Like it. 441 41.96%
Awesome wish mine had that. 454 43.20%
You just ruined a perfectly good jeep 69 6.57%
Why would you replace a 2.5 with a 5.0. 2.5 are the best 87 8.28%
Voters: 1051. You may not vote on this poll
 2Likes
post #91 of 1200 Old 11-09-2008, 05:51 AM
muskyslayr
Originally Posted by lumpster View Post
and your jeep doesnt look cobble up and ziptied together
Tell ya what, if you can't contribute to this thread other than nitpicking, why don't you just zip it!
muskyslayr is offline
post #92 of 1200 Old 11-09-2008, 07:14 AM
lumpster
lumpster's Avatar
you mean ziptie it? calm down there bucko
lumpster is offline
post #93 of 1200 Old 11-09-2008, 07:15 AM
lumpster
lumpster's Avatar
btw i just told the originator of the post that he might want to clean up the wiring, because diagnosing a problem later would be hard with butt-connectors for pcm wires and stuff.
lumpster is offline
post #94 of 1200 Old 11-09-2008, 09:29 AM
ET48
Here is my swap.
http://www.jeepforum.com/forum/f8/ford-5-0-1978-jeep-cj-7-a-578581/
I swaped a Ford 302 from a 1988 Cougar into my 1978 CJ-7. I bought the RJM harness and recommend that to anyone!!!!!! If you have any trouble or questions about hooking up anything, you can call them and they are awesome. Definately the way to go. My pics are on the swap thread if you want to take a look.
ET48
1986 CJ-7 LAREDO, 4.2L, 5 speed, 3.31 Gears, D30, D44, 2.5" ProComp lift, 3" BL, 33" TSLs.
1998 TJ SAHARA, 4.0L, 5 speed, 4.11 Gears, D30 (Aussie Locked), Ford 8.8, 4.5" Custom LA, XRC8, AA SYE, TW DS, ZJ tie-rod, Full-Traction front adj. track bar, 35" KM1s.
ET48 is offline
post #95 of 1200 Old 11-09-2008, 10:26 AM
navman
Originally Posted by 472cid View Post
Just the chevy disc as the input shaft of the tranny is a chevy size 1 1/16" where ford is 1 1/8". you still use the ford pressure plate throwout beraing just a chevy disc in the center to go on the input shaft
Ahh I see, I'm using an np435 ford tranny so the issue never arose. Thanks for the reply
95 YJ 5.0 linked etc
navman is offline
post #96 of 1200 Old 11-09-2008, 10:52 AM
Moses2564
What's the HP and Torque rating for the 5.0? I'm looking to upgrade the 4.0, but if the gain isn't significant, I may just stick with the 350sb.
2000 Solar Yellow TJ
2000 Ford F250 Super Duty
2006 Volvo S40
1997 Arctic Cat ZRT 600
Moses2564 is offline
post #97 of 1200 Old 11-09-2008, 11:16 AM
navman
most late 80's early 90's ho's are rated 215-225 hp and 285-300 lbs tq. The motor is significantly more compact than a sbc350 and lighter than a jeep 4.0 by a bunch. The efi harness is also much easier to deal with than an efi chev.
Robm225 likes this.
navman is offline
post #98 of 1200 Old 11-09-2008, 11:48 AM Thread Starter
472cid
ANd 302parts are just as cheap as small block chevy and performance parts can be had on the cheap(thanks mustang guys) on average when i use the 92-93 mustang harness which is the same as the first ford racing harness they offered it takes about 25-30 minutes to install.
1997 Jeep Wrangler 5.0 ho gt40p motor w/ e303 cam, ax15 trans. 241j rock trac transfer case from 05 rubicon. 05 front rubicon 44 with yukon chromoly shafts and rear rubicon dana 44 and rubicon rims with 33x11.50x16 mtrs
472cid is offline
post #99 of 1200 Old 11-11-2008, 01:15 AM
sourskittle
Honestly... There isn't a SBC factory fuel injection we can use.
A) carb'd. SBC 350 ( old school ) we all know how great that is, if your in love with gas smell, bad fuel mileage, poor reliability, and year round drivability changes. And that's not even getting into its off-road draw-backs.
B) The early-mid 90s TBI. Basiclly, its a carb with injectors in it. Besides being 1984 technoloy, its got about the same draw-backs as the carb, and its got these stupid plastic line thingys that always crack and cost a ton to replace ( like $850 for GM parts ).
C) 93-97 LT-1 stuff from a camaro. Its a good motor IMO, but its got some nice draw-backs too. #1 ( and its the biggest reason ), they used what's called an "opti-spark" on the front of the engine. Basiclly, a seemly china designed dizzy on the front of the motor. Even on camaros, its goes out almost consistantly without ever spashing or driving through water, so how long is it going to last in a jeep ? Mean while, the opti-spark is only worth buying from GM, since all the cheap ones on e-bay last about 3 weeks. Guess what... Its about $250 a pop. Besides that, its got slightly more wiring than the classic ford EFI, and its also got "VATS" with is "the chip in the key" crap, which means sending your ECU to be "de-Vats" which equals money, and compilates the "parts avaliability" part.
D) LSx ( aka: LS1, LS2, LS3, LS6, LQ4, LS7, and now LS9 ). Basicly, I'll saw this is when GM did it right. It took them 12 years, but they finally did an EFI that's better than ford's 1986 multiport EFI. Its a fantastic engine IMO. But its a simple matter of cost at this point in the game... I estimated $3000 for an LQ4 ( 6.0L esculade 345hp motor ), and I estimated $800 for my ford swap ( currently prob. somewhere in the $1200 range now). If you can afford it, do this engine !!!
The EFI roller 5.0L swap was a no-brainer to me. I can't imagine why anyone would want a 350 over a 302.
The 302: fits better. Runs cooler naturally. IMO is cheaper, and has more readily avaliable factory upgrade ( GT-40, cobra stuff ), and as meantioned is the only one you can get with a reliable EFI without going the $$$LSx$$$ route.
The jeeps 190hp engine I think is a bit "optimistic", while the 225 is too, its not quiet "AS optimistic". Either way, the 302, even in "HO" form is ALL TORQUE. Its makes nothing but torque !!!!
Update on my project... I'm cleaning/painting/detailing every part of the motor. I got carried away, and took it down to the long block with morning... Hopefully, I'll stop making posts about how GM dropped the ball for 15 years on fuel injection ( other than the buick GN ), and I'll get some sleep so I can post some "pretty shots".
2002 TJ Apex edition with EFI ford 5.0L H.O., NV3550, 33'' Maxxis A/Ts, 5'' lift with custom built rear 4-link, Ford 8.8 LSD 4.10s, HP D30 with spartan locker 4.10s
sourskittle is offline
post #100 of 1200 Old 11-11-2008, 02:35 AM Thread Starter
472cid
You missed gms better and easy to swap injection. tuned port injection and 86 cars will bolt right on any chevy cylinder heads. wiring harness are not bad to modify and really easy over all to set up. my buddies are all not that bright as they are chevy guys so have done many of these are although not as easy as the 5.0 mustang motor they are not bad. In a jeep i would still prefer the ford motor as things fit and line up better and no special radiator or nothing either. the tpi chevy motors or tbi rule out running a stick in the factory location as firewall distrubtor clearence will be a problem
472cid is offline
post #101 of 1200 Old 11-11-2008, 12:36 PM
Moses2564
So the 302 will bolt straight up to a factory Jeep transmission, including the NV3550? I'm interested in doing this swap sometime in the future.
I would assume that the motor mounts need to be changed, and have you had any problems with the increased HP and torque effecting your stock axles? If I can get away with just adding chromolly shafts to the D30, being that I already have a D44 in the back, I think it would make everything a lot easier.
2006 Volvo S40
post #102 of 1200 Old 11-11-2008, 02:19 PM
sourskittle
You have to buy an adaptor from advanced adaptors for $250-ish, but it includes the plate, TO bearing, poilt bushing, and aliment tool. Just add a late 80s-early 90s ford F-series bell housing and presure plate, and that's it. Motor mounts can be found, but I didn't like any of them, I'm building my own.
And about the TPI... I actully did think about it later, but desided that its such a POS that it wasn't worth editing my post. Racers have known that for years, but a recent episode/build of horsepower TV proved them right. They took a TPI camaro and bolted about everything possible to it ( from electric water pump, to header back exhuast, to upgraded TPI intake, to ECU tuning ) and it made less than 200whp. I think they finally swapped in a fresh motor, went with an aftermarket injection, and heads and made..... 230whp !!!!
I reallize that jeeps aren't about horsepower, but I think I'd actully perfer the 4.0L jeep I6 over the TPI GM engines. I think it defeats the purpose of swapping in a V8. Its got all the hassles of the EFI ford, but its harder to fit, and makes a good 50 less WHP stock vs stock.
In my entire life I've seen one fast "Joe dirt" camaro. It was a fully built 383 with TPI, a T56 from a newer camaro, and a 225shot in a gutted car. It ran 10.8. Other than that, the only fast 83-92 camaros you'll see have completely different engines/drivelines or a carb.
I think I'd actully take a carb over the TPI engines, and that's coming from a guy that built an electric riding mower b/c he was sick of dealing with a carb.
The LT-1 was a good motor, it made way more power stock vs stock than a 5.0 H.O., don't think I'm just haten on chevys... Its just that the EFI 302 is about the only thing Ford ever did right, and I think they should get credit
post #103 of 1200 Old 11-12-2008, 01:41 AM
sourskittle
I couldn't resist, I added up what I've spent so far...
Motor: $200 ( 70K 94' Mustang GT from an auto car that ran and had good A/C )
Adaptor/clutch: $230
Harness/ECU/modification: $230
Bell housing/slave/presure plate from a 80's 4.9L I6: $70
FLywheel, brand new: $60
shorty truck headers: $160
rear main seal/timing cover set and seal/upper intake manifold gasket, oil pan gasket : $80
O2 sensors direct fit: $90
Paint: $10
oil filter, oil, PVC: $20
New melling oil pump: $30
New 130A alternator, New water pump, New truck starter: $180
Stant 180degree Thermostat and gasket: $15
Used balencer/Damper: $20 egay ( scored a deal )
Valve cover gaskets/ upper manifold+ gasket kit: $30
Dayon serp. belt: $25
$1450.... So far... Ouch... A lot of this could be "by-passed" possibly, but I just couldn't let this motor go in without doing some of those things.
Pics of the motor mocked up after paint, still waiting on some parts
post #104 of 1200 Old 11-12-2008, 11:53 AM Thread Starter
472cid
not crazy about the mower but the motor is looking good. i wish i would not have rushed mine and painted everything. Butthen again you have the luxury of knowing everything you need and pretty mush not being on a deadline. It is all looking great and thank crank pulley looks familar. Werll keep up the good work and i am waiting on some pics of it sitting in the jeep. also when you set it in there and go to weld you mounts make sure it is raised higher than mine or you will pry get some vibes
472cid is offline
post #105 of 1200 Old 11-12-2008, 12:37 PM
C2U5H
C2U5H's Avatar
i mean 1500 for a motor swap is pretty damn good, whether or not you sell your stock engine to recoupe some of that dough and do the work yourself.
nice work! looks great cleaned up ... i'm really interested in some video!! wanna hear that thing when its done!!!
2012 Crush JK Rubicon on 2.5" and 37s
- see sidebar
C2U5H is offline
5.0 , 5.0 liter , 5.0l , engine swap , ford , motor swap , v8
YJ to CJ dash swap write up with pictures rrisher YJ Wrangler Technical Forum 171 05-11-2015 04:53 PM
Engine swap pictures 5.7YJ YJ Wrangler Technical Forum 22 08-26-2012 05:05 PM
Another 4.0 Swap question...head swap vs. full engine swap Mol YJ Wrangler Technical Forum 11 10-18-2010 04:11 AM
My roll bar swap with pictures YJames90 YJ Wrangler Technical Forum 6 02-18-2008 05:18 PM
4.0L Swap Pictures Inside. ID89YJ YJ Wrangler Technical Forum 3 01-29-2007 06:58 PM
