5.0 engine swap pictures - Page 6 - JeepForum.com
View Poll Results: What do you think?
Like it. 441 41.96%
Awesome wish mine had that. 454 43.20%
You just ruined a perfectly good jeep 69 6.57%
Why would you replace a 2.5 with a 5.0. 2.5 are the best 87 8.28%
Voters: 1051. You may not vote on this poll
 2Likes
post #76 of 1200 Old 11-05-2008, 11:03 PM
ericson89
ya i have 33s and my college budget will be hurting after this build so i would rather not get d44s even though i would love them
ericson89 is offline
post #77 of 1200 Old 11-06-2008, 12:59 AM Thread Starter
472cid
i found mine on the cheap and if your motor is still good you can sell it and recover some of your swap expense. should be able to pull this off for about $1400
1997 Jeep Wrangler 5.0 ho gt40p motor w/ e303 cam, ax15 trans. 241j rock trac transfer case from 05 rubicon. 05 front rubicon 44 with yukon chromoly shafts and rear rubicon dana 44 and rubicon rims with 33x11.50x16 mtrs
472cid is offline
post #78 of 1200 Old 11-06-2008, 07:10 PM
ericson89
maybe 1400 but i got the block for 250 bucks which i think was cheap. my 4.0L has just over 50k so its in great condition to re-sell.
post #79 of 1200 Old 11-06-2008, 08:03 PM
ffej
Anything you want to know about the Ford EEC-IV system:
http://www.fordfuelinjection.com/
If you don't mind spending the money, they sell a harness that is MUCH easier to use than adapting the stock Ford harness. Additionally, it already has the EGR and smog related delete items built in.
ffej is offline
post #80 of 1200 Old 11-07-2008, 03:26 AM Thread Starter
472cid
not to put that harness down as it is a great harness but cost is what comes into play as the 92-93 mustang ford harness are cake to adapt. The egr delete is detail on fordfuelinjection.com i would still recommend the 92-93 mustang harness as most people are trying to do this as a real world swap which means a limited budget and not dropping bucks here there and everywhere
472cid is offline
post #81 of 1200 Old 11-07-2008, 09:19 AM
lumpster
lumpster's Avatar
this is what i used when i put a 5.0 in my cj7, but 6 years ago when i did it the harness was only 217 dollars not 674. WTF??
http://store.summitracing.com/partde...5&autoview=sku
lumpster is offline
post #82 of 1200 Old 11-07-2008, 10:15 AM
sourskittle
guess I can't delete posts completely....
2002 TJ Apex edition with EFI ford 5.0L H.O., NV3550, 33'' Maxxis A/Ts, 5'' lift with custom built rear 4-link, Ford 8.8 LSD 4.10s, HP D30 with spartan locker 4.10s
sourskittle is offline
post #83 of 1200 Old 11-07-2008, 06:37 PM
ffej
If the budget is tight and/or you really enjoy modifying and tinkering the original, then this harness is not for you. However, if the funds are there, you want a much simpler install and you don't want to mess with chafed wires, open circuits and shorts in a 16+ year old harness, then the aftermarket harness is tough to beat. Especially in a Jeep where you can find yourself out in the middle of nowhere, a trouble-free system is invaluable. That is NOT to say that the FoMoCo stock harness can't be adapted reliably (I know people who have), but it does take a lot more care in the install.
The harness you bought six years ago is different than this one. The picture in that link looks like Ford has repackaged the fordfuelinjection.com harness. The original Ford harness had two large connectors (referred to as "salt and pepper shakers" because one was black and the other white, which were problematic). If you look on fordfuelinjection.com, they show the other different harnesses available.
BTW, I got my harness off of Ebay for less than $500. Works great.
ffej is offline
post #84 of 1200 Old 11-07-2008, 07:17 PM
lumpster
lumpster's Avatar
and your jeep doesnt look cobble up and ziptied together
lumpster is offline
post #85 of 1200 Old 11-07-2008, 11:09 PM Thread Starter
472cid
the harness ford used to sell with the black and white connectors is exactly what the 92-93 mustang harness is. the ford motorsports instructions is what i use to modify it as all the connectors are identical that u modify on the ford racing harness.
472cid is offline
post #86 of 1200 Old 11-08-2008, 01:34 PM
Contra
so did you just hook up the 5.0 to the stock trans and everything else
Ever Gone Geocaching?
Contra is offline
post #87 of 1200 Old 11-09-2008, 12:19 AM Thread Starter
472cid
ax15 231j w sye advance adapters plate to hook the ford truck bell to jeep trans
472cid is offline
post #88 of 1200 Old 11-09-2008, 12:39 AM
sourskittle
I'm using the NV3550, NP231, and no SYE.
Basiclly, stock + 33'' tires, 4.5'' lift, and a 5.0L.
post #89 of 1200 Old 11-09-2008, 12:42 AM
navman
Why is everybody useing the chevy 11" clutch and not the ford that matches the bellhousing/flywheel?
95 YJ 5.0 linked etc
navman is offline
post #90 of 1200 Old 11-09-2008, 03:12 AM Thread Starter
472cid
Just the chevy disc as the input shaft of the tranny is a chevy size 1 1/16" where ford is 1 1/8". you still use the ford pressure plate throwout beraing just a chevy disc in the center to go on the input shaft
472cid is offline
5.0 , 5.0 liter , 5.0l , engine swap , ford , motor swap , v8
YJ to CJ dash swap write up with pictures rrisher YJ Wrangler Technical Forum 171 05-11-2015 04:53 PM
Engine swap pictures 5.7YJ YJ Wrangler Technical Forum 22 08-26-2012 05:05 PM
Another 4.0 Swap question...head swap vs. full engine swap Mol YJ Wrangler Technical Forum 11 10-18-2010 04:11 AM
My roll bar swap with pictures YJames90 YJ Wrangler Technical Forum 6 02-18-2008 05:18 PM
4.0L Swap Pictures Inside. ID89YJ YJ Wrangler Technical Forum 3 01-29-2007 06:58 PM
