5.0 engine swap pictures - Page 51 - JeepForum.com
View Poll Results: What do you think?
Like it. 442 42.02%
Awesome wish mine had that. 454 43.16%
You just ruined a perfectly good jeep 69 6.56%
Why would you replace a 2.5 with a 5.0. 2.5 are the best 87 8.27%
Voters: 1052. You may not vote on this poll
 2Likes
post #751 of 1200 Old 03-03-2010, 09:11 PM
subzer008
Quick question. Just curious but from reading this thread it seems that doing this swap with an auto and not a manual would be a lot more simple. True statement?
subzer008 is offline
post #752 of 1200 Old 03-03-2010, 09:13 PM Thread Starter
472cid
yes and no, as far as motor bolting up yes but would have to find a c6 to 231 adapter to keep jeep transfer or run ford t case. Either way is not bad to do but i think all i have helped with have been sticks but one and he ran ford 205 transfer case
1997 Jeep Wrangler 5.0 ho gt40p motor w/ e303 cam, ax15 trans. 241j rock trac transfer case from 05 rubicon. 05 front rubicon 44 with yukon chromoly shafts and rear rubicon dana 44 and rubicon rims with 33x11.50x16 mtrs
472cid is offline
post #753 of 1200 Old 03-03-2010, 09:20 PM
subzer008
Noob question here but trying to learn as much as i can. This swap would be easier with an auto correct?
Oops didnt see the first one go through. Sorry about that. Just matching things up then. Seems simple enough.
post #754 of 1200 Old 03-05-2010, 10:19 AM
mschviuz
amos....ya'll running cats on your exhaust, or more than likely cat?
mschviuz is offline
post #755 of 1200 Old 03-05-2010, 03:40 PM Thread Starter
472cid
I had one on there earlier this fall, i think it crawled up there trying to stay warm but other than that no, or atleast i try not to.
472cid is offline
post #756 of 1200 Old 03-05-2010, 04:08 PM
mschviuz
I needed that today! Seriously though....
mschviuz is offline
post #757 of 1200 Old 03-06-2010, 11:03 AM Thread Starter
472cid
took it on big road trip on 4 lane highway about 400 miles yesterday and posted 14.44 mpg!!!!!!!!!!!!!
472cid is offline
post #758 of 1200 Old 03-08-2010, 08:36 AM
mschviuz
Sounds good.
I found a bellhousing yesterday so that is one more piece to the puzzle done!
mschviuz is offline
post #759 of 1200 Old 03-08-2010, 12:19 PM
TJLover99
looks really nice. im not a ford guy but i can appreciate good work when i see it, nice Jeep
TJLover99 is offline
post #760 of 1200 Old 03-08-2010, 02:22 PM
mschviuz
amos, do you have some close ups of the mounts you used on the frame for the engine? I'm searching through here trying to find a pic. Also, did you weld them on or bolt? I don't have a welder so I'd have to take it somewhere to have that done.....
mschviuz is offline
post #761 of 1200 Old 03-08-2010, 10:10 PM Thread Starter
472cid
welded but not real sure but i know a picture or two shows them but not real close
472cid is offline
post #762 of 1200 Old 03-09-2010, 12:50 PM
spark plug
I just finished making my motor mounts and I'll try post some pics for you.
Mines a YJ not a TJ. The TJ frame is not as wide. I'm happy with how mine turned out.
"93" YJ 3.5 BDS, 5/8" Boomerings, 1"BL
33"x12.5" Ford 5.0 8.8 AX-15 231 SYE
spark plug is offline
post #763 of 1200 Old 03-09-2010, 01:14 PM
mschviuz
sounds good...thanks
mschviuz is offline
post #764 of 1200 Old 03-09-2010, 03:05 PM
spark plug
Heres my motor mounts. 2.5 x 2.5 3/16" angle iron i also used 2x3 3/16"
tubing. I cut some metal also to place on the frame for added strength.
I purchased the round tube and bushings from M.O.R.E I put the motor where I thought it should be then I used card board to mock up the mounts before I cut the metal. Measure 5 or 6 times then cut once.
Rick
post #765 of 1200 Old 03-09-2010, 03:40 PM
mschviuz
that looks really good!
mschviuz is offline
5.0 , 5.0 liter , 5.0l , engine swap , ford , motor swap , v8
YJ to CJ dash swap write up with pictures rrisher YJ Wrangler Technical Forum 171 05-11-2015 05:53 PM
Engine swap pictures 5.7YJ YJ Wrangler Technical Forum 22 08-26-2012 06:05 PM
Another 4.0 Swap question...head swap vs. full engine swap Mol YJ Wrangler Technical Forum 11 10-18-2010 05:11 AM
My roll bar swap with pictures YJames90 YJ Wrangler Technical Forum 6 02-18-2008 06:18 PM
4.0L Swap Pictures Inside. ID89YJ YJ Wrangler Technical Forum 3 01-29-2007 07:58 PM
