Quantcast 5.0 engine swap pictures - JeepForum.com
jeeppartsdept.com
Get your jeep parts here. Full line Jeep dealer. HUGE DISCOUNTS!
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > 5.0 engine swap pictures
View Poll Results: What do you think?
Like it. 424 42.23%
Awesome wish mine had that. 426 42.43%
You just ruined a perfectly good jeep 69 6.87%
Why would you replace a 2.5 with a 5.0. 2.5 are the best 85 8.47%
Voters: 1004. You may not vote on this poll
Old 08-21-2008, 03:25 AM   #1
472cid
5.0 engine swap pictures with full functioning gauges including tach!!
472cid is offline   Reply With Quote
Old 08-21-2008, 03:43 AM   #2
76flh
i think it look's good. i would clean up the rest of the loose wire's.
76flh is online now   Reply With Quote
Old 08-21-2008, 03:44 AM   #3
472cid
yea it isnt quite done yet just couldnt wait to post the pictures . more coming later
Old 08-21-2008, 07:30 AM   #4
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Very nice.
Its good to see something other than a Chevy motor.
I'm about to start a Grand Cherokee 4.7 V8 swap in mine.
98 TJ
Wheelin98TJ is offline   Reply With Quote
Old 08-21-2008, 07:36 AM   #5
kenbuck
A guy from Cape Cod Jeep CLub put a heavily warmed over 5 liter ford in his YJ with 37" Claws. You can check it out on their website on "member jeeps." i think it might be www.capecodjeepclub.org.
THe guy is one hell of a mechanic. His has the BBK intake, hes got aluminum heads, its one nasty beast.
Also, i'm lookin forward to seeing a 4.7l swap into a TJ.
02 TJ.
2.5" RC Progressive Lift
1" PA Body Lift
33" KM's
misc other stuff.....
kenbuck is offline   Reply With Quote
Old 08-21-2008, 08:49 AM   #6
vincec
I like it when I saw 5.0 engine swap I was hoping it was a 302 and not a 305.I think I one guy is right you could use some flex and some loom clams to clean the engine compartment.Still yet nice job.
vincec is offline   Reply With Quote
Old 08-21-2008, 10:15 AM   #7
4.0l sahara
now just add a new tb,upper and lower intake,cam and a new set of heads and it will be a real beast.
4.0l sahara is offline   Reply With Quote
Old 08-21-2008, 10:15 AM   #8
goldswim5
looks great...to bad you didn't make a how-to when you did it!
'99 Cherokee
'01 3/4 ton 6spd Powerstroke (The Tow Pig)
I wheel at SMORR
goldswim5 is offline   Reply With Quote
Old 08-21-2008, 11:41 AM   #9
krawler510
Looks sweet. I bet it sounds amazing
'The early bird may get the worm, but the second mouse gets the cheese.'
krawler510 is offline   Reply With Quote
Old 08-21-2008, 12:17 PM   #10
Laxstar46
I like it. I woudl love to see a 4.7L go into a jeep. or what I would also like to see is an old ford 300I6 to go in there. 4.9 liters of inline six power.....
1997 Jeep TJ Wrangler. 2.5L four cylinder with Five speed manual..... biggest POS i've ever owned. Will be replaced at the end of this month with a 2008 Dodge Ram 1500. Jeep no more baby couldn't be happier
Laxstar46 is offline   Reply With Quote
Old 08-21-2008, 12:25 PM   #11
patricknolan
Good job on that. I have a 2.5 also and my dad has a 5.0 out of a '66 tourino. Was thinking about putting it in there. Probably not though
patricknolan is offline   Reply With Quote
Old 08-21-2008, 12:33 PM   #12
AlTheKillerr
nicely done sir
AlTheKillerr is offline   Reply With Quote
Old 08-21-2008, 12:48 PM   #13
472cid
Yea i will clean it up more i was just impatient to take pictures i will post a couple more when i am finished completely. If anyone has questions i can answer them. I can tell you all the parts you need. It is not a hard swap. I took it done the freeway and it felt awesome to get in the fast lane AND PASS SOMEONE. Yes i said pass some one not get passed and a dirty look because the wind was keeping the 2.5 from the speed limit
Old 08-21-2008, 12:59 PM   #14
sourskittle
That's great !! I just made a post about this two days ago !!
Post up a parts list. THings that were a PITA. What adaptors, mounts ? How'd you deal with the clutch stuff ? Or did you swap the entire motor/trans ? AX-15 ? NV3550 ?
Overheating ? after market rad. ?
Parts sources ?
A/C ?
power steering adaptation ?
Keep/loose the air pump/EGR ?
Stock oil pan ?
Donor wiring harness or aftermarket ( if so who ).
As you can see, I'm really into this idea being my 4.0L is dead and a 5.0 engine set can be had for $300 ( complete ), the wiring harness ( aftermarket ) is $475, and adv. adaptors for the NV3550 is $275 with clutch. Where as the 4.0L by its self is $800 locally.
2002 TJ Apex edition with EFI ford 5.0L H.O., NV3550, 33'' Maxxis A/Ts, 5'' lift with custom built rear 4-link, Ford 8.8 LSD 4.10s, HP D30 with spartan locker 4.10s
sourskittle is offline   Reply With Quote
Old 08-21-2008, 01:41 PM   #15
87warrior
Looks good... Although you ruined a perfectly good Jeep with more ford parts... J/K.
Have you taken it down the road yet? That lil Jeep will be a rocket!
03 Rubicon(Rubicon build)
92 Comanche (92/99 Comanche Project)
87warrior is offline   Reply With Quote
5.0, 5.0 liter, 5.0l, engine swap, ford, motor swap, v8
Glock Forum
