-   TJ Wrangler Technical Forum (http://www.jeepforum.com/forum/f9/)
-   -   5.0 engine swap pictures (http://www.jeepforum.com/forum/f9/5-0-engine-swap-pictures-596831/)
472cid 08-21-2008 02:25 AM
5.0 engine swap pictures with full functioning gauges including tach!!
http://i355.photobucket.com/albums/r...78/50tj001.jpg
http://i355.photobucket.com/albums/r...78/50tj002.jpg
http://i355.photobucket.com/albums/r...78/50tj003.jpg
http://i355.photobucket.com/albums/r...78/50tj004.jpg:cheers2:
76flh 08-21-2008 02:43 AM
i think it look's good. i would clean up the rest of the loose wire's.
472cid 08-21-2008 02:44 AM
yea it isnt quite done yet just couldnt wait to post the pictures . more coming later
Wheelin98TJ 08-21-2008 06:30 AM
Very nice. :thumbsup:
Its good to see something other than a Chevy motor.
I'm about to start a Grand Cherokee 4.7 V8 swap in mine.
kenbuck 08-21-2008 06:36 AM
A guy from Cape Cod Jeep CLub put a heavily warmed over 5 liter ford in his YJ with 37" Claws. You can check it out on their website on "member jeeps." i think it might be www.capecodjeepclub.org.
THe guy is one hell of a mechanic. His has the BBK intake, hes got aluminum heads, its one nasty beast.
Also, i'm lookin forward to seeing a 4.7l swap into a TJ.
vincec 08-21-2008 07:49 AM
I like it when I saw 5.0 engine swap I was hoping it was a 302 and not a 305.I think I one guy is right you could use some flex and some loom clams to clean the engine compartment.Still yet nice job.
4.0l sahara 08-21-2008 09:15 AM
now just add a new tb,upper and lower intake,cam and a new set of heads and it will be a real beast.
goldswim5 08-21-2008 09:15 AM
looks great...to bad you didn't make a how-to when you did it!
krawler510 08-21-2008 10:41 AM
Looks sweet. I bet it sounds amazing
Laxstar46 08-21-2008 11:17 AM
I like it. I woudl love to see a 4.7L go into a jeep. or what I would also like to see is an old ford 300I6 to go in there. 4.9 liters of inline six power.....
patricknolan 08-21-2008 11:25 AM
Good job on that. I have a 2.5 also and my dad has a 5.0 out of a '66 tourino. Was thinking about putting it in there. Probably not though
AlTheKillerr 08-21-2008 11:33 AM
nicely done sir :2thumbsup:
472cid 08-21-2008 11:48 AM
Yea i will clean it up more i was just impatient to take pictures i will post a couple more when i am finished completely. If anyone has questions i can answer them. I can tell you all the parts you need. It is not a hard swap. I took it done the freeway and it felt awesome to get in the fast lane AND PASS SOMEONE. Yes i said pass some one not get passed and a dirty look because the wind was keeping the 2.5 from the speed limit
sourskittle 08-21-2008 11:59 AM
That's great !! I just made a post about this two days ago !!
Post up a parts list. THings that were a PITA. What adaptors, mounts ? How'd you deal with the clutch stuff ? Or did you swap the entire motor/trans ? AX-15 ? NV3550 ?
Overheating ? after market rad. ?
Parts sources ?
A/C ?
power steering adaptation ?
Keep/loose the air pump/EGR ?
Stock oil pan ?
Donor wiring harness or aftermarket ( if so who ).
As you can see, I'm really into this idea being my 4.0L is dead and a 5.0 engine set can be had for $300 ( complete ), the wiring harness ( aftermarket ) is $475, and adv. adaptors for the NV3550 is $275 with clutch. Where as the 4.0L by its self is $800 locally.
87warrior 08-21-2008 12:41 PM
Looks good... Although you ruined a perfectly good Jeep with more ford parts... J/K.
Have you taken it down the road yet? That lil Jeep will be a rocket!
The time now is 07:22 AM.
