Quantcast 4X4 part-time & Gear Ratios - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > 4X4 part-time & Gear Ratios
Old 01-05-2006, 10:56 AM   #1
wrangler2002
This is probably a stupid question but here it goes...
My assumption so far has been that my front diff (dana30) has a gear ratio of 3.07:1 (between the ring and pinion gears) and the rear (dana44) has a 3.73:1.
How is it possible, when 4-wheel drive is engaged, for the front wheels to rotate at the same speed as the rear wheels (not during a turn but driving in a perfectly straight line).
I always assumed that part-time 4wheel drive shouldn’t be used on dry pavement because it's hard on the tcase during turns… but it just hit me that its straining the tcase on straight lines as well…
If the 2 drive shafts spin at 1000RPMs then the front tires should spin at ~325 RPMs and the rear ~270 RPMs which is a significant enough diff that the jeep should not even be drivable on dry ground without a whooole lot of bucking/skidding. But I feel no bucking what so ever in a straight line. Turning is a different story.
wrangler2002 is offline   Reply With Quote
Old 01-05-2006, 11:05 AM   #2
BigJeepJay
It isn’t possible unless you have different size tires on your front than your rear. You do not have 3.73’s and 3.07’s in your Jeep. I believe if you have an 4.0L auto you have 3.73’s both front and rear but if you have the 5-speed than you definitely have 3.07’s. If you only drive in 2WD then only your rear gears matter but when engaging 4WD both axles need to be geared them same for the same size tires.
Pics...
[URL="http://smg.photobucket.com/albums/v516/JeepJay/"]http://smg.photobucket.com/albums/v516/JeepJay/[/URL]
TJ Stretch Thread...
[URL="http://www.jeepforum.com/forum/showthread.php?t=348220&page=3"]http://www.jeepforum.com/forum/showthread.php?t=348220&page=3[/URL]
BigJeepJay is offline   Reply With Quote
Old 01-05-2006, 11:11 AM   #3
T.H's TJ
U can have 3.73 in a 5sp. Crawl under your jeep and check out the tag on the diff it will tell ya.
T.H's TJ is offline   Reply With Quote
Old 01-05-2006, 11:11 AM   #4
BigJeepJay
When did that come from the factory?
…nevermind I think it possibly came as a option with the oversize (30”) tire group.
Pics...
Old 01-05-2006, 11:11 AM   #5
TJeeper
You made a bad assumption. Both the front and rear diffs are the same gearing (or as close as possible considering the physical size of the r&p, e.g. 4.10 and 4.11). If they weren't, your transfer case would have been destroyed a long time ago.
Never use part time 4WD on the road. Even though the diffs are geared the same, and it is ok to go in a straight line, when you turn the front and rear driveshafts are going to rotate at different speeds. If they are locked together (as they are in 4WD), and the tires are not allowed to slip (like on dirt or snow), the transfer case will bind up, which could damage it.
Patrick
'99 TJ "Big Jeep"
'98 ZJ "Little Jeep"
TJeeper is offline   Reply With Quote
Old 01-05-2006, 11:17 AM   #6
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
3.07 is a possibility for an auto 4.0L.
Thats what mine had originally.
98 TJ
Wheelin98TJ is offline   Reply With Quote
Old 01-05-2006, 11:18 AM   #7
BigJeepJay
That seems pretty high for an auto...surprising.
Pics...
Old 01-05-2006, 11:22 AM   #8
wrangler2002
For the 2002 Sport i'm pretty sure if you upgraded to the 30inch tires you also got the dana44 plus the 3.73 gear ratios... i had just assumed that the 3.73 was for the rear only.
Thanks for clearing it up.
Old 01-05-2006, 11:23 AM   #9
wrangler2002
atleast for the manual. don't know for the auto
Old 01-05-2006, 01:45 PM   #10
RafaelSmith
My 2000 4.0l w/ 3sp Auto came with 3.07 as well.
Wasnt to bad with stock tires...for the week I had them =P
But when i put 31's on it really sucked.
re-geared to 3.73 and its nice both on road and offroad.
2008 Silver JK 2DR X, 4sp auto, 3.73 gears
Rubicon Express 2" Coil Spacer w/Shocks
285/70/17 BFG AT
Rear Trac-Lock
Sunrider softtop.
RafaelSmith is offline   Reply With Quote
Old 01-05-2006, 01:49 PM   #11
Varnish
Moab dreamin'
Varnish's Avatar
From what I can tell its a crapshoot, my friend and I had the exact opposite, 3.07s in my auto & 3.73 in his 5 speed. If anything, the auto is more likely to have 3.07s due to the lack of overdrive, but who knows without checking the axle.
'98 TJ (see profile)
'88 YJ with 4.0/AW4 swap & CJ front end
'97 XJ 4.0/aw4/3.5" lift/33x10.5 BFG ATs
'80s CJ Resto-mod ('80s CJ frame/front end, YJ tub, '00 XJ 4.0)
Varnish is offline   Reply With Quote
Old 01-05-2006, 02:22 PM   #12
outdrsman
I just purchased my first jeep last March. I have an 01 with the 4.0 and 3sp auto and 3.07 gears. I'm running 33's on it. I went to the dealer and they gave me a printout.
outdrsman is offline   Reply With Quote
Glock Forum
