4x4 Linkage - JeepForum.com
post #1 of 6 Old 07-30-2012, 09:27 AM Thread Starter
brtnshrdr
4x4 Linkage
I currently have a 2000 Tj but I'm looking to "upgrade" to a more built '97. The only thing I'm concerned with is the seller says that the "4x4 shift linkage needs repair." I've tried looking it up but most of the results I get pertain to adapters to fit lifts. I'm hoping someone can help me as to what this problem could most likely mean?? That would be great!
Thanks!
1995 YJ Wrangler - 4" BDS Suspension w/ 2" Body Lift 33" Pro Comp Mud Terrains w/ 15" Alloy Wheels
2000 TJ Wrangler - 4" BDS Suspension Lift
brtnshrdr is offline
post #2 of 6 Old 07-30-2012, 09:42 AM
mdm
Farm Wheeler
Does it have a body lift? If so, the linkage may need to be adjusted and/or an adapter installed.
Other than that, it could mean anything. Bent or worn out pieces. Broken pieces. Missing pieces. It could even mean the internal shifter is messed up and he is blaming it on the linkage because he doesn't want to admit it or he doesn't know the truth.
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
post #3 of 6 Old 07-30-2012, 09:51 AM
TheRealKTrain
JK Wrangler
Distributor cap? Yuck. Stick with the 2000
"We are what we repeatedly do. Excellence, then, is not an act, but a habit." Aristotle
Μολὼν λαβέ
TheRealKTrain is offline
post #4 of 6 Old 07-30-2012, 10:26 AM
JEK3
JEK3's Avatar
I recommend you look into the Novak shift kit. It guts all the linkage pieces and replaces them with a cable that, once installed and adjusted, will work with any amount of body lift. They come highly recommended. I have one sitting in my basement (along with several other upgrades), just waiting for a free day to put it in.
JEK3 is offline
post #5 of 6 Old 07-30-2012, 10:47 AM
JrTjK
1978 FSJ Wagoneer
^Novak makes a nice one, as well as Advanced Adapters having one as well.
There is also the shift bushing repair kit http://www.quadratec.com/products/52207_0007.htm in case it's that simple.
JrTjK is offline
post #6 of 6 Old 07-30-2012, 02:44 PM Thread Starter
brtnshrdr
Thanks guys! I got some more information about it. He had actually disconnected the linkage because the alignment wasn't right with the lift! So he manually has to go put it in 4Hi or 4Lo! I've been seeing that Novak Linkage a lot in my searches and think its what I'm going to end up getting for it if this works out!
4x4 , linkage , repair , tj
Linkage zener6 TJ Wrangler Technical Forum 5 04-19-2009 07:07 PM
4x4 Linkage clemsonfan16 YJ Wrangler Technical Forum 4 12-05-2008 08:39 AM
TC linkage swingkid YJ Wrangler Technical Forum 5 01-11-2008 09:26 AM
AA linkage bracket/ linkage adjustment? Wrangler11 TJ Wrangler Technical Forum 1 06-01-2007 08:56 PM
4wd linkage highrisetj39.5 TJ Wrangler Technical Forum 2 09-02-2006 08:20 AM
