4WD Shakes Violently - JeepForum.com
post #1 of 5 Old 03-04-2009, 06:58 AM Thread Starter
BENGRFF
Hi,
2003 TJ
When it's in 2wd it is fine, but when I put it into 4wd it shakes violently.The jeep is undrivable in 4wd. The jeep is stock. Any help would be greatly appreciated. Thanks, Ben
BENGRFF is offline
post #2 of 5 Old 03-04-2009, 10:35 AM
john NC
john NC's Avatar
are you using 4WD on the road?
john NC is offline
post #3 of 5 Old 03-04-2009, 10:47 AM
FLATFENDER54
FLATFENDER54's Avatar
Good question
01 TJ Sahara 4"short arm/rear gas&tire
carrier bumper/front winch bumper winch/detroitEz
1954 WILLYS CJ3B (under construction)
FLATFENDER54 is offline
post #4 of 5 Old 03-04-2009, 12:18 PM
BomberJeep
2011 WK
If you are not being smooth with it it will buck. Mine likes to buck in first gear if I dont give it the throttle right. Second gear is smoother so I usually drive in that when Im wheelin
Never get between a man and his Jeep - Stacey David.
BomberJeep is offline
post #5 of 5 Old 03-04-2009, 12:32 PM Thread Starter
BENGRFF
I haven't been able to use 4wd since the middle of Winter. I did drive on the pavement in 4wd, but the roads are covered in snow all Winter long and it really is a neccessity to use 4wd. I've owned the TJ for three years, and haven't had a problem driving it this way, until this past Winter.Could the problem be a Ujoint or something like that? 2wd is fine, but when it's put into 4wd it shakes very violently right from the get go. It feels like the tires are going to fall off the jeep. Thanks, Ben
BENGRFF is offline
Front end shakes violently when braking.. yj40swapped YJ Wrangler Technical Forum 27 11-05-2015 03:31 PM
Jeep shakes violently when stopping!!! Pedro_Slick YJ Wrangler Technical Forum 4 11-17-2009 05:11 PM
Jeep violently shakes at 55+ Mitchin TJ Wrangler Technical Forum 2 04-30-2009 11:45 PM
front end shakes violently!!! letulle1 JK Wrangler Technical Forum 9 07-19-2008 03:53 PM
I need your advice - gas tank shakes violently! JoeW TJ Wrangler Technical Forum 5 09-23-2004 01:58 PM
