4WD Problems - JeepForum.com
post #1 of 5 Old 06-25-2013, 02:50 AM Thread Starter
ek5soccer
4WD Problems
So I took my jeep off roading and got stuck in a pretty good sized puddle (see photo). Got it out the next day and power washed it off multiple times. Changed all of my fluids (both diffs, transfer case, transmission, and oil). Today when I checked to see if my 4WD was messed up. So I put it in 4 hi and started in first gear which seemed to work fine, but then when i shifted into second the 4wd seemed to pop out into neutral, so I stopped and put it back into 4 hi and tried to go again 1st gear worked well and then shifted to second and it popped down to 2wd. Didn't try 4 lo. Any idea on what might be wrong??
ek5soccer is offline
post #2 of 5 Old 06-25-2013, 04:24 AM
4banged
Check the linkage on the 4wd lever. It's easy...do a search for step-by-step instructions.
4banged is offline
post #3 of 5 Old 06-25-2013, 06:57 AM
NotURMailman
NotURMailman's Avatar
Do you have: BL, MML, raised belly skid, t-case drop?
equipped... And loving it!
I drive on the right side, what's wrong with you?
It's difficult to take you seriously. It's like you're an easily perturbed autistic teenager who's drunk typing the whole time.
NotURMailman is offline
post #4 of 5 Old 06-25-2013, 10:24 PM Thread Starter
ek5soccer
I am not sure.
post #5 of 5 Old 06-25-2013, 10:25 PM Thread Starter
ek5soccer
Yeah it looked like it was all hooked up properly just needed to be adjusted I guess.
4wd , 4wd shift , problem
