4wd problem - JeepForum.com
post #1 of 5 Old 06-25-2010, 10:27 PM Thread Starter
wdtran99
4wd problem
I recently bought my first wrangler it a 99 tj sport with an inline 6cyl. and the only problem im having with it is my 4wd wont disengauge, the dash light is off but the drive shaft itself is still locked in, i checked the linkages and they are fine, and no rust, im not sure where to go from here?
wdtran99 is offline
post #2 of 5 Old 06-25-2010, 10:31 PM
Benderff
Benderff's Avatar
The driveshaft always spins.
Benderff is offline
post #3 of 5 Old 06-25-2010, 10:46 PM Thread Starter
wdtran99
Ok thank u, iv always had broncos so im used to the transfer case disengauging not the axle, thanks again
wdtran99 is offline
post #4 of 5 Old 06-27-2010, 01:11 AM
BubbaNTx
Hey Dont feel Bad This Is My10th four wheel Drive and they all had Hubs my 97 isthe First without Hubs. Never had To Replce a Front Axle shaft U joint Had A Nasty Clunck and Chased it for days Found The Right Front Axle Joint Bad. Now I am Looking For A Post on How To replace it.
BubbaNTx is offline
post #5 of 5 Old 06-27-2010, 01:56 AM
MisfitSeven
MAiL Crawler.
MisfitSeven's Avatar
on TJs the Tcase is disengaged, and the axle is not. so you should be used to that.
Mail crawling.
MisfitSeven is offline
4wd , disengage
clutch problem ? Master / Slave Cylinder Problem rthompson48082 YJ Wrangler Technical Forum 34 11-30-2011 06:31 PM
Belt problem, blinker problem, and a random problem... Mike89db TJ Wrangler Technical Forum 10 12-14-2009 06:34 AM
brake pad problem, and front drive shaft problem bluejeep2088 TJ Wrangler Technical Forum 1 05-12-2008 10:34 AM
Brake Fluid problem or Jeep Drinking problem daledaniel TJ Wrangler Technical Forum 6 01-04-2008 10:11 PM
FINALLY! fixed idle problem and stalling problem Big-n-Broke-YJ YJ Wrangler Technical Forum 4 02-28-2006 08:50 PM
