4wd light in dash does not work - JeepForum.com
post #1 of 11 Old 08-02-2010, 06:44 AM Thread Starter
BigBLue05X
Hi guys.
I recently picked up a 2005 Impact Orange LJ. Im working out the kinks before I go nuts with the quadratec catalog.
I figured since only the last 2 settings on the fan work, Im going to need a new blower resistor.
When I put it in 4wd, the 4wd light does not go on. Do I need a new 4wd switch? Anyone else have this problem?
Thanks
Dan
BigBLue05X is offline
post #2 of 11 Old 08-02-2010, 07:37 AM
frigginjeep
Yep...many of us have had this problem...and it was posted about just yesterday by somebody else...
http://www.jeepforum.com/forum/f9/aw...d-out-1080820/
frigginjeep is offline
post #3 of 11 Old 08-02-2010, 07:40 AM
autopc25
Check dash bulb first then switch.
autopc25 is offline
post #4 of 11 Old 08-02-2010, 02:03 PM
frigginjeep
like stated in the other thread...there is no dash "bulb"...it is an LED that is soldered to the circuit board and not easily replaceable...
DO NOT TRY TO PULL APART YOUR CLUSTER YOU WILL DAMAGE IT!!!
post #5 of 11 Old 08-02-2010, 02:53 PM Thread Starter
BigBLue05X
Oh No...Too late! Just kidding. I kind of knew it was the switch, I just needed other opinions.
My last TJ, I pulled the cluster out and went with blue LED bulbs. Might do the same with this one.
I think the Transfer case is a np231.
Thanks for everyone's information
post #6 of 11 Old 08-02-2010, 03:00 PM
jdhallissey
It is a annoying light. Leave it be- it is to much effort to have a light tell you your in 4wd. MHO
jdhallissey is offline
post #7 of 11 Old 08-02-2010, 03:57 PM
+GRAVES+
Corporate Whore
+GRAVES+'s Avatar
http://www.jeepforum.com/forum/f9/4x...-light-608616/
i believe mine was about $13 at 4 wheel parts, including the o ring
"The best advice I can give you is never listen to my advice"
+GRAVES+ is offline
post #8 of 11 Old 08-02-2010, 04:20 PM
freeskier93
Soldering's not really that hard to do. I've also removed my cluster to clean behind it (found like five pens back there once), I've also taken off the plastic cover to clean dust out from inside. AS LONG AS YOU AREN'T AN IDIOT YOU WON'T DAMAGE IT!!!
freeskier93 is offline
post #9 of 11 Old 08-02-2010, 06:24 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Don't have 2 low, do you?...
Knuckelhead is offline
post #10 of 11 Old 08-02-2010, 06:28 PM
vtx531
Here is the one you want: 4WD Light Electrical*Switch by Crown Automotive and Other Jeep Parts and Jeep Accessories by 4 Wheel Drive Hardware-RH3
It will work with your TJ even though it's not listed.
vtx531 is offline
post #11 of 11 Old 08-02-2010, 06:42 PM
roadkill
mine quit working at Big Bend Ranch State Park, assuming all teh wash board roads got it. drove 500 miles home, it was raining stuck it in 4wd so as not to rut out my road any more than it is and I look down at the dash and the lights working again. been workign ever since, I love it when problems fix themselves
roadkill is offline
dash , light , 4wd
Dash lights don't work link16 YJ Wrangler Technical Forum 13 11-07-2010 04:27 PM
Dash light wont work jeepin16 TJ Wrangler Technical Forum 5 11-19-2009 01:41 AM
Dash lights won't work?? DEspence YJ Wrangler Technical Forum 3 11-08-2009 08:53 AM
Turn signal dash light stuck on, warning chime, no shift light. bmlawless TJ Wrangler Technical Forum 7 10-21-2008 08:29 AM
4x4 light in dash doesnt work jjstroke TJ Wrangler Technical Forum 5 01-28-2004 08:18 PM
