4WD Light - JeepForum.com
post #1 of 4 Old 09-11-2012, 04:47 PM Thread Starter
BIRICON
4WD Light
I have an 03 Rubicon with a std transmission, 70k miles. When driving in 2WD, the 4WD indicator light in my dash is ON. When I engage the transfer case and am actually in 4H the light goes OFF. If I go to 4L the dash light comes back ON. I have been told that the Rubicon is wired differently from other models. Any idea how this got wacked out and what to fix to get it right again?
BIRICON is offline
post #2 of 4 Old 09-14-2012, 12:58 PM Thread Starter
BIRICON
A guy with an 07 Wrangler told me the 4WD dash light would need an ECM replacement to fix. Can this be right????? I figured some sensor on my 03 Rubicon had gone bad. Anybody have any ideas?
BIRICON is offline
post #3 of 4 Old 09-15-2012, 09:50 PM
mukluk
Your Rubicon uses a variable resistance switch for the transfer case shifter position, the PCM interprets the resistance within certain ranges to determine what mode the t-case is in. The sensor is installed on top of the t-case, above the t-case shifter arm. Check the resistance of the switch in each shift range to verify the switch hasn't gone bad.
2Hi - 1124 to 1243 ohms
4Hi - 650 to 719 ohms
N - 389 to 431 ohms
4Lo - 199 to 221 ohms
mukluk is offline
post #4 of 4 Old 09-15-2012, 09:53 PM
mukluk
You can see the switch and wire harness below and to the right of the arrow in the pic.
mukluk is offline
4wd , dash light
engine light on, temp guage fluxuating, electronic throttle response light Lynhalla JK Wrangler Technical Forum 1 03-01-2012 11:22 AM
tail light/break light/ dash light dont work handyman5150 TJ Wrangler Technical Forum 3 07-06-2011 03:24 PM
dome/interior Light and headlight chime linked to seat belt light? Redryan98 TJ Wrangler Technical Forum 8 09-09-2010 08:25 AM
keep blowing tail light, turning singnals and interrior light fueses on my TJ bigtime13 TJ Wrangler Technical Forum 1 11-06-2009 06:34 PM
Turn signal dash light stuck on, warning chime, no shift light. bmlawless TJ Wrangler Technical Forum 7 10-21-2008 08:29 AM
