4WD dash light not working - JeepForum.com
post #1 of 3 Old 04-07-2006, 11:21 PM Thread Starter
MyRig is Yellow
i just had some major work done to the jeep, and now when i engage 4WD it doesnt light up on my dash,is there a wire or sensor that controls this that i can take a look at to see if its disconnected or something along those lines?
02 TJ, 4.5 RE Lift, Ford 8.8, ARB, 4.88, Chromoly shafts & joints, 35 X 12.5 MT/R's, PSC Crusher corners and rockers, Warn Xi 9000, AA SYE, TW Drive shaft, Custom bumpers, JKS 1.25" BL, JKS Quicker Disco's, Flush tails, Herculined tub, Kilby on board air, Currie Tie Rod System, and so much more
MyRig is Yellow is offline
post #2 of 3 Old 04-07-2006, 11:42 PM
Stormtrooper
Stormtrooper's Avatar
Ya, there is a connectorized switch on the transfer case that turns on the dash indicator lamp. If your Tcase was removed, there's a good chance they forgot to reconnect the switch when they put it all back together. You'll have to crawl under, find the loose connector and plug it into the tcase 4wd indicator switch.
Cheers, Steve
Stormtrooper is offline
post #3 of 3 Old 04-09-2006, 10:26 AM Thread Starter
MyRig is Yellow
well i looked underneath pretty thouroughly and everything was connected, i forgot to mention before i had the new 8.8 put in that i took a pretty good dunk into some water and was stuck in the water for about 24 hours. i took the dash apart and the bulb was fine. any other suggestions?
4x4 dash light not working mattpm07 TJ Wrangler Technical Forum 5 01-10-2011 11:34 AM
4whl dash light not working David R TJ Wrangler Technical Forum 3 11-14-2007 09:12 PM
dash light not working haxsaw YJ Wrangler Technical Forum 9 03-05-2007 05:30 PM
dash light are not working samizx7 YJ Wrangler Technical Forum 5 02-16-2005 10:02 PM
running/dash light stopped working whitewrangler YJ Wrangler Technical Forum 8 02-02-2005 11:02 PM
