4WD Dash Indicator Lights? - JeepForum.com
post #1 of 22 Old 12-28-2011, 06:14 PM Thread Starter
chitownjp
Can anyone tell me if the 4WD indicator lights on the dash are supposed to turn on when the key is turned to the "on" position? Similar to the other dash lights? I did some off-roading this weekend and when I kicked in the 4WD the lights on the dash didn't come on. It seems like the 4WD is working so I'm trying to trouble shoot what may be causing the problem. Either the bulb's burnt out or I've got an issue with the 4WD sensor. I'm hoping it's the bulb. Any help would be appreciated. Thanks!
chitownjp is offline
post #2 of 22 Old 12-28-2011, 06:18 PM
SaxManClay
You have a 4WD light?
If it were my Jeep, I wouldn't worry about it. I think a majority of the Jeeps on this forum don't have their 4WD light come on. I bought mine from an 80 year-old man who drove 5 miles a day, and mine didn't have it.
But to answer your question: If you really want to fix it, try the bulb first.
My Jeeps name is TUG!
What I'm all about.
SaxManClay is offline
post #3 of 22 Old 12-28-2011, 06:28 PM
4banged
I don't know about 97 but both my 2003 and my buddies 2001 both needed a new sensor/switch replaced on the transfer case . . . it's like a $12 part at the dealer and there are writeups on this forum if you search. It was both easy and difficult (simple job but you have to be a contortonist to get to the friggen thing without dropping the skid plate).
Have fun!
4banged is offline
post #4 of 22 Old 12-28-2011, 08:20 PM
Richlost
The next time you are in your Jeep, do this simple test.
1)Put key in ignition
2)Press and hold the odometer reset button
3) Turn key to "ON" position.... DO NOT START THE VEHICLE!!!!!!
The dash lights, and gauges will cycle thru a self check process, if during this process you see the 4wd light come on, then you know for sure that the switch needs to be replaced and not the bulb.
Edit: This test works on my 04 LJ, not sure if it works on other years.
Richlost is offline
post #5 of 22 Old 12-28-2011, 08:32 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
I think your wrong on that analisis...
Knuckelhead is offline
post #6 of 22 Old 12-28-2011, 08:45 PM
jwaller89
Mine is on in 2wd, goes off in 4wd, then back on in neutral. My switch is out, and I haven't felt like replacing it yet. It happens.
2004 Jeep Rubicon, Metalcloak Everything. 35's.
jwaller89 is offline
post #7 of 22 Old 12-28-2011, 09:46 PM
SaxManClay
Originally Posted by Knuckelhead View Post
I think your wrong on that analysis...
I might be, but from personal experience the only Jeep I've seen with a 4WD light indicator is my fiances 01 Cherokee. And it wouldn't be the first time I've been wrong on this forum.
What I'm all about.
post #8 of 22 Old 12-28-2011, 10:03 PM
Doty152
Mine is not coming on either, I said **** it and got a beer. I don't need a light to tell me what I already know.
Roses are red
Violets are blue
They don't think it be like it is,
But it do.
Alcohol may be mans worst enemy, but the Bible says to love your enemy.
ಠ_ರೃ
Doty152 is offline
post #9 of 22 Old 12-28-2011, 10:38 PM
Holm-z
Mine hasn't worked in years.
1998 TJ Sport 4.0L 5spd
3.75" RC
33x12.5x15 Goodyear Duratracs
Superwinch 10000lb
Monstaliner, CB, ARB Front locker, 4.56 gears
I understand.
IAFF Local 3265
Holm-z is offline
post #10 of 22 Old 11-29-2012, 11:00 AM
TriCountyKeith
My 93 YJ has the same problem. No light, but it goes into 4WD just fine. It would be nice to have an idiot light to let me know I was in 2WD when I get back on the pavement.
TriCountyKeith 93YJ
TriCountyKeith is offline
post #11 of 22 Old 11-29-2012, 11:11 AM
sweetbmxrider
My light does come on when I go into 4wd high, the part time light if I remember correctly. None of them light for bulb check. This is on an 01.
Originally Posted by TSEJEEPERS View Post
Why do you let your wife out of the kitchen?
sweetbmxrider is offline
post #12 of 22 Old 11-29-2012, 11:16 AM
RioRyan
My light comes on when I'm in in 4x4, and shuts off when I'm not. I guess I should be thankful lol
I do remember something about it coming on when the key is off and you flash the highbeams or something... can't remember if it has to be in 4x4 for that, but I know I thought there was something weird about that bit.
RioRyan is offline
post #13 of 22 Old 11-29-2012, 11:16 AM
wanabejeeper
1987 YJ Wrangler
I'm a nut about it. I bought the jeep and the shift fork was locked over. I bought the vacuum motor scrounged around and found the vacuum driven indicator switch and now the light wont go out... fixing it is on my list to do but when I'm done it wil work,
87 YJ The Original!
It goes in that barrel you wheel out to the street once a week.
My build thread
wanabejeeper is offline
post #14 of 22 Old 11-29-2012, 01:07 PM
1shotwonder
Dont know what the big deal is honestly.. If you can't tell it's in 4wd/forget you put it in 4wd.. it's your own issue... Why do you need a light to tell you something you already should know? I mean it's not like it automatically kicks in.. You have to manually put it in 4wd
Save 1000 elk. Smoke a wolf pack
Sometimes the light at the end of the tunnel is a muzzle flash
1shotwonder is offline
post #15 of 22 Old 11-29-2012, 06:13 PM
Knuckelhead
AFSOC Retired
With my 2-Low, the light comes in usefull...
4wd , 4x4 , dash , lights
Dash indicator lights southbound YJ Wrangler Technical Forum 9 01-02-2010 12:04 PM
Dash indicator lights Cross YJ Wrangler Technical Forum 8 11-22-2008 05:22 PM
Dash and Indicator lights denalione YJ Wrangler Technical Forum 0 05-17-2008 09:39 AM
4WD Indicator Lights on Dash CTKen TJ Wrangler Technical Forum 12 12-31-2007 03:46 PM
87 dash indicator lights wdhigh YJ Wrangler Technical Forum 7 05-12-2007 08:23 PM
